| Skip Navigation Links | |
| Exit Print View | |
man pages section 3: Library Interfaces and Headers Oracle Solaris 11 Information Library |
SMHBA_GetAdapterAttributes(3LIB)
SMHBA_GetAdapterPortAttributes(3LIB)
SMHBA_GetBindingCapability(3LIB)
SMHBA_GetDiscoveredPortAttributes(3LIB)
SMHBA_GetFCPhyAttributes(3LIB)
SMHBA_GetPersistentBinding(3LIB)
SMHBA_GetPortAttributesByWWN(3LIB)
SMHBA_GetProtocolStatistics(3LIB)
SMHBA_GetSASPhyAttributes(3LIB)
SMHBA_GetVendorLibraryAttributes(3LIB)
SMHBA_GetWrapperLibraryAttributes(3LIB)
SMHBA_RegisterForAdapterAddEvents(3LIB)
SMHBA_RegisterForAdapterEvents(3LIB)
SMHBA_RegisterForAdapterPhyStatEvents(3LIB)
SMHBA_RegisterForAdapterPortEvents(3LIB)
SMHBA_RegisterForAdapterPortStatEvents(3LIB)
SMHBA_RegisterForTargetEvents(3LIB)
SMHBA_RemoveAllPersistentBindings(3LIB)
SMHBA_RemovePersistentBinding(3LIB)
- category macros
#include <locale.h>
The <locale.h> header provides a definition for the lconv structure, which includes the following members. (See the definition of LC_MONETARY in locale(5).)
char *currency_symbol char *decimal_point char frac_digits char *grouping char *int_curr_symbol char int_frac_digits char int_n_cs_precedes char int_n_sep_by_space char int_n_sign_posn char int_p_cs_precedes char int_p_sep_by_space char int_p_sign_posn char *mon_decimal_point char *mon_grouping char *mon_thousands_sep char *negative_sign char n_cs_precedes char n_sep_by_space char n_sign_posn char *positive_sign char p_cs_precedes char p_sep_by_space char p_sign_posn char *thousands_sep
The <locale.h> header defines NULL (as defined in <stddef.h>) and the following as macros:
LC_ALL LC_COLLATE LC_CTYPE LC_MESSAGES LC_MONETARY LC_NUMERIC LC_TIME
The preceding expand to distinct integer constant expressions, for use as the first argument to the setlocale() function. See setlocale(3C).
Additional macro definitions, beginning with the characters LC_ and an uppercase letter, can also be specified here.
setlocale(3C), localeconv(3C), stddef.h(3HEAD), attributes(5), locale(5), standards(5)
