| Skip Navigation Links | |
| Exit Print View | |
Programming Interfaces Guide Oracle Solaris 11 Information Library |
2. Remote Shared Memory API for Oracle Solaris Clusters
3. Session Description Protocol API
Broadcasting and Determining Network Configuration
Sending IPv4 Multicast Datagrams
Receiving IPv4 Multicast Datagrams
Sending IPv6 Multicast Datagrams
Receiving IPv6 Multicast Datagrams
Stream Control Transmission Protocol
9. Programming With XTI and TLI
11. Transport Selection and Name-to-Address Mapping
12. Real-time Programming and Administration
This chapter presents the socket interface. Sample programs are included to illustrate key points. The following topics are discussed in this chapter:
SunOS 4 Binary Compatibility discusses binary compatibility with the SunOS 4 environment.
Socket creation, connection, and closure are discussed in Socket Basics.
Client-Server architecture is discussed in Client-Server Programs.
Advanced topics such as multicast and asynchronous sockets are discussed in Advanced Socket Topics.
Interfaces used to implement the Stream Control Transmission Protocol (SCTP) are discussed in Stream Control Transmission Protocol.
Note - The interface that is described in this chapter is multithread safe. You can call applications that contain socket interface calls freely in a multithreaded application. Note, however, that the degree of concurrency that is available to applications is not specified.
