Skip Navigation Links | |
Exit Print View | |
man pages section 3: Library Interfaces and Headers Oracle Solaris 11 Information Library |
SMHBA_GetAdapterAttributes(3LIB)
SMHBA_GetAdapterPortAttributes(3LIB)
SMHBA_GetBindingCapability(3LIB)
SMHBA_GetDiscoveredPortAttributes(3LIB)
SMHBA_GetFCPhyAttributes(3LIB)
SMHBA_GetPersistentBinding(3LIB)
SMHBA_GetPortAttributesByWWN(3LIB)
SMHBA_GetProtocolStatistics(3LIB)
SMHBA_GetSASPhyAttributes(3LIB)
SMHBA_GetVendorLibraryAttributes(3LIB)
SMHBA_GetWrapperLibraryAttributes(3LIB)
SMHBA_RegisterForAdapterAddEvents(3LIB)
SMHBA_RegisterForAdapterEvents(3LIB)
SMHBA_RegisterForAdapterPhyStatEvents(3LIB)
SMHBA_RegisterForAdapterPortEvents(3LIB)
SMHBA_RegisterForAdapterPortStatEvents(3LIB)
SMHBA_RegisterForTargetEvents(3LIB)
SMHBA_RemoveAllPersistentBindings(3LIB)
SMHBA_RemovePersistentBinding(3LIB)
- XSI interprocess communication access structure
#include <sys/ipc.h>
The <sys/ipc.h> header is used by three mechanisms for interprocess communication (IPC): messages, semaphores, and shared memory. All use a common structure type, ipc_perm, to pass information used in determining permission to perform an IPC operation.
The ipc_perm structure contains the following members:
uid_t uid /* owner's user ID */ gid_t gid /* owner's group ID */ uid_t cuid /* creator's user ID */ gid_t cgid /* creator's group ID */ mode_t mode /* read/write permission
The uid_t, gid_t, mode_t, and key_t types are defined as described in <sys/types.h>. See types.h(3HEAD).
Definitions are provided for the constants listed below.
Mode bits:
Create entry if key does not exist.
Fail if key exists.
Error if request must wait.
Keys:
Private key.
Control commands:
Remove identifier.
Set options.
Get options.
