| Skip Navigation Links | |
| Exit Print View | |
Sun Storage Common Array Manager Software Release Notes, Release 6.9.0, June 2013 Update |
1. Sun Storage Common Array Manager Software Release Notes
Licensing Optional Premium Features
Best Practices for Browser Performance
Supported Host Operating Systems
2500 Array Support for VMware ESX 4.1 with Firmware 07.35.55.10 and later
6540, 6140, and FLX380 Arrays Upgrade
Sun Storage F5100 Flash Array Notes
Controller Smart battery replacement procedure
Array loses communication during registration when IPV6 is enabled
Battery nears expiration: 06.xx write back cache should not be disabled
Both RAID controllers reboot after 828.5 days--2500/6000 arrays
Reboots occur due to ancient I/O being aborted in large configurations
Reregister Auto Service Request for CAM
Auto Service Request advisory note: DTS Listener transfer
Array name remains unchanged after a full array reset
Access Configuration: Cascaded J4400 issues
Access Configuration fails with error: java.util.HashMap cannot be cast to java.util.Properties
Access Configuration: non-zoned SAS2 wide port aggregation FRU Report display—F5100 + 6Gb/sec HBA
Array lock key must be set before configuration files are imported
ComponentInsertEvent not generated for disk drive inserted into J4200
Current Jobs page can take more than five minutes to display
Expander firmware 5.3.73 does not persist a SAS zone group
Replication status incorrect when primary volume fails
Service Advisor: replacing failed SIM with dual path configurations
Volumes not deleting from the Single Page window
Attempt to delete partner replication set on secondary array fails
Incorrect sscs add notification description in CLI guide
2500 Series Release Notes: Simplex vs. Duplex Configurations
Disk Locked description is inaccurate in online help
Firmware upgrade fails with error: FWR_UPGRADE_FAILURE,6 for J4200/J4400 arrays
Firmware upgrade fails on J4400 SATA drives
Firmware upgrade fails when expander and disks are upgraded together
Firmware upgrade not recognized by GUI until agent runs
Sun Blade 6000 firmware upgrade fails with down-level expander
Sun Blade 6250 and 6270—upgrading network expansion modules fails
Installation and Upgrade Issues
Error occurs when upgrading 2510 controller and drive firmware
Installation fails on SUSE 10.3 32-bit and 64-bit hosts
Performance Enhancer for 2500-M2
Enabling Try and Buy license using the CLI
“Require-Stop” not working in SUSE11.1 innserv jexec init.d script
Logging in to CAM on SUSE11 using invalid password
Adding or removing SATA drives requires host boot
Sun Storage J4000 and F5100 Flash arrays—Linux hot plug issues
Solaris with Veritas DMP or other host type
Error—”no execute access to opt/SMgr/agent/ notifysmagent.sh”—occurs during system boot-up
UTM LUNs Controlled by “Solaris Traffic Manager” 6000/2500 arrays
Add License error using the CLI
Support Data does not save using Windows 2008 R2 SP1 Servers
Controller firmware 07.84.47.10 for 6180, 6580/6780, 2530-M2, 2540-M2 arrays
Disk firmware updates:
For 2500-M2 arrays: HUS1530SCSUN300G and HUS1560SCSUN600G to A700 H109060SESUN600G to A31A
For 6000 series and FLX380 arrays: HUS1530FCSUN300G and HUS1561FCSUN600G to E700 and ST31000NSSUN1.0T to 0712
For F5100 arrays: MARVELL SD88SA02 to D138
New drives available for 6000 series and FLX380 arrays:
ST1000NM0011 and ST2000NM0011
Download the latest patches from My Oracle Support (MOS). For detailed patch download steps, see the Knowledge article 1296274.1 available on MOS:
How to Download Common Array Manager (CAM) Software and Patches ID 1296274.1
Note - You must install the platform patch and the firmware patch to successfully upgrade the 2500-M2 and 6x80 arrays to firmware 07.84.47.10.
Table 1-1 Platform and Firmware Patch IDs
Note - Each array should be managed by one CAM management host only. Installing the management software on more than one host to manage the same array can cause discrepancies in the information reported by CAM.
See Documentation to find information about installation, configuration, and more.
See Patches for information about the latest software updates.
Visit https://support.oracle.com/CSP/main/article?cmd=show&type=NOT&doctype=HOWTO&id=1296274.1 to get details about array firmware, and find out more about downloading Common Array Manager software and its patches.
Join or start a discussion with Oracle experts and industry peers in the My Oracle Support Community for Storage Disk 6000 and 2000 Series RAID Arrays at: https://communities.oracle.com/portal/server.pt/community/storage_disk_6000_and_2000_series_raid_arrays/465.
Sun Storage Common Array Manager Contents lists the version information for the software included in this release.
Table 1-2 Sun Storage Common Array Manager Contents
