This chapter contains the following topics:
WebCenter Spaces portals provide two arenas for the presentation of resources and information: a Space and the Home Space.
Spaces are typically used to create portals and communities that are scoped to a specific audience, for example, a specific division, department, project, or community.
The Home Space provides each user with a private work area for storing personal content, viewing and responding to business process assignments, maintaining a list of online buddies, and performing many other tasks relevant to his or her unique working day.
The WebCenter administrator will determine which users will be able to create Spaces based on the role and permissions assigned to each user.
Login into WebCenter Spaces using the user name and password provided to you. If you do not have user name and password, register yourself.
The user name for the portal you are using must match the user name for the EnterpriseOne environment that the portlets are running on.
E.g. If the user name and password for PY900 is AB1234, then the portal user name and password for the WebCenter/Collaborative Portal running PY900 portlets must be AB1234.
If WebCenter user name is not a valid E1 user name:Map WebCenter user name to E1 user name.
Launch P0092|W0092P from Fast Path.
Click Add.
Enter E1 user in EnterpriseOne UserID field, WebCenter user in Enterprise UserID field. Username must be entered in upper case even though the actual WebCenter user name has lower case characters.
These are the steps to create a Space:
Once you login to the WebCenter, click on the Spaces link which will display a menu of actions that can be performed on Spaces. Click on the Create a Space menu item.
Enter the name of your Space and click Next.
Select the level of access; either Public, Private, or Hidden, then click Next.
Select the type of template to be used. In this example, select the Portal Site template and click the Create button.
After the Space is created, click on the arrow to the right of the screen to access the drop down menu. Click Manage, and then click All Settings.
Click the Members tab. If people need to be added, click the Add People tab. For now, we will not be adding any members to the Space.
Select the General tab.
Fill the following details:
Display Name: Oracle Self Service Space
Description: Oracle Self Service Space
To add a logo to the work space, browse to the location of the logo.
Select the logo file and click Open.
Configure the other details. Set the Default Language and Site Template to Maximized, so that the Space will display the page with the logo we have chosen and will not have the default page settings. Set Copyright to add any copyrights to the page.
By default, Home and Settings pages will be available. Go back to the Home page. The following image shows the Home page. The Home page will have the instructions to Edit and Create pages as well as instructions to enable and disable services for this space. Select the down arrow, click Create, and then click Page.
The portal pages can be made available or unavailable by enabling/disabling the display of portal pages on the spaces.
To disable the display of the Home portal pages:
Click on the down arrow on the right of the screen and click Manage, and then click Pages, which will display the list of Portal pages on the current Spaces.
To disable a portal page, uncheck the Show page property for the corresponding portal page.
In this case, the Search and Activity Stream pages are unchecked:
WebCenter Spaces also provide a variety of page layouts (called styles) that can used to create different types of pages with different layouts. Page types may restrict the type of content that can be added to a page, such as text only, wiki only, blog only, and the like. Page layouts define the number of columns and content areas that define a page's geometry. Layouts are initially determined by the style that is selected while creating the page. Some page styles inherently allow switching to another page layout, such as wikis or blogs.
In addition to the layouts available through page styles, the user can create their own layouts using the layout components available through the Resource Catalog.
In this section, we are going to build a Buyer Workspace page, as shown in this image:
Follow these steps to create the Buyer Workspace page:
Log into WebCenter and access the Oracle Self Service Space the was created in the previous section.
Click the Page Actions dropdown arrow, select Create, and then Page.
Enter the Page Name as “Buyer Workspace” and let the Scheme be Blank and click Create button. This will show Buyer Workspace page in Edit mode having only one column.
Click on Add Box Right.
Click Add Content to add E1 portlets.
Click on Portlets to open the Portlets catalog.
Select stg_oracle_webcenter (this name could be different based on the setup) to see the list of EnterpriseOne portlets available.
Add the Configurable_SRM Component portlet from the list of portlets available, and then click the Close button.
Click on the edit button of the portlet and select the Display Options tab. Set the property Render Portlet in I Frame to true. Click the OK button.
Save and close the page. Click on the Edit Configuration link.
Click the Add arrow to add the selected alerts from the Available Alerts grid to the Selected Alerts grid.
Click Next. This will allow the user to override all of the alert names as desired.
The images below list all of the alert name overrides.
Figure 8-3 Purchase Orders Awaiting Acknowledgement Past Due Alert
Figure 8-4 Purchase Orders Awaiting Shipment Past Due Alert
Figure 8-5 Purchase Orders in Status Alert
Figure 8-9 Purchase Orders At Route Step Alert
Figure 8-10 Inventory Advanced Search Alert
Figure 8-11 Search for Receipt Lines Alert
Figure 8-12 Search for Payment Information Alert
The user can still add new alerts to the Selected Alerts grid from the Available Alerts grid. Also, the user can change the order by using the Move Up or Move Down icons as shown in the image below.
The user can update the new alert added by clicking the edit box provided.
Click the Next button as shown below after the editing is done. Click the Cancel button provided to exit from the configuration screen.
Choose Page Actions, and then Edit Page.
Click Add Content.
Follow the steps 5, 6 and add the Configurable_HTML_URI_IURI_Component from the available list.
Click the Configuration icon.
Select HTML Portlet from the available list and click Next.
Enter the Name as BWS and Title as BWS and paste following text in HTML Code text area and click the Next button.
<P><Font Color="#336699"></p><b><big>Procurement Tasks</big></b><br>
<A HREF="javascript:RunOWApp('P4310_W4310I_ZJDE0001');">Enter SRM Purchase Order</a><br>
<A HREF="javascript:RunOWApp('P4310_W4310G_ZJDE0001');">Manage Open Purchase Orders</a><br>
<A HREF="javascript:RunOWApp('P4310_W4310I_ZJDE0003');">Receive PO</a><br>
<A HREF="javascript:RunOWApp('P01012_W01012A_ZJDE0005');">Buyer's Info</a><br>
<A HREF="javascript:RunOWApp('P43090_W43090A_ZJDE0001');">Supplier Item information</a><br>
<A HREF="javascript:RunOWApp('P04012_W04012D_ZJDE0002');">Purchasing Instructions</a><br>
<A HREF="javascript:RunOWApp('P43041_W43041A_ZJDE0001');">Purchasing Ledger</a><br><br>
<br>
<P><Font Color="#336699"></p><b><big>Quote Tasks</big></b>
<br>
<A HREF="javascript:RunOWApp('P4310_W4310I_ZJDE0002');">Quote Order Entry</a><br>
<A HREF="javascript:RunOWApp('P4310_W4310G_ZJDE0002');">Open Quote Inquiry</a><br>
<A HREF="javascript:RunOWApp('P4334_W4334B_ZJDE0001');">Enter Quote Responses</a><br>
<A HREF="javascript:RunOWApp('P43360_W43360H_ZJDE0001');">Generate PO's From Quotes</a><br>
<br>
<P><Font Color="#336699"></p><b><big>Buyer Shop Floor Tasks</big></b>
<br>
<A HREF="javascript:RunOWApp('P3016_W3016A_ZJDE0001');">Kanban Master</a><br>
<A HREF="javascript:RunOWApp('P3157_W3157A_ZJDE0001');">Manage Kanban Orders</a><br>
<A HREF="javascript:RunOWApp('P3157_W3157A_ZJDE0001');">Check-Out Kanban-Consumption</a><br>
<A HREF="javascript:RunOWApp('P3157_W3157A_ZJDE0002');">Check-in Kanban-Supply</a><br>
Set required permissions and click Done.
Save the changes made to the portal page and close.
WebCenter Spaces also provides a variety of page layouts (called styles) that you can use to create different types of pages with different layouts. Page types may restrict the type of content that you can add to a page, such as text only, wiki only, blog only, and the like. Page layouts define the number of columns and content areas that define a page's geometry. Layouts are initially determined by the style you select when you create the page. Some page styles inherently allow switching to another page layout, such as wikis and blogs.
In addition to the layouts available through page styles, you can create your own layouts using the layout components available through the Resource Catalog.
The Customer Self Service portal page is created using eight EnterpriseOne FDA portlets. The following three images comprise the Customer Self Service Space:
To create the Customer Self Service page:
Click the Page Actions dropdown arrow, then select Create, and then Page.
Enter the Page Name as Customer Self Service and let the Scheme be Blank and click Create button. This will show Customer Self Service page in Edit mode having only one column.
Click Add box below.
Click Add box right.
Click the Add Content button to add EnterpriseOne portlets.
Click Portlets to open the Portlets catalog.
Select stb_oracle_webcenter (this name could be different on your setup) to see the list of E1 portlets available.
To add the CSSCustomerAlerts portlet to the left pane, search for the string CSSCustomerAlerts to find the list of CSSCustomerAlerts portlets available and select one.
Follow the steps 5, 6 and 7 on the right pane of the EnterpriseOne portlet and add the CSS Search portlet from the list of CSS Search portlets available.
Follow the steps 5, 6 and 7 on the right pane of the EnterpriseOne portlet and add the CSS Tasks portlet from the list of CSS Tasks portlets available.
Click on Add box below.
Click Add Content.
Click Layout to open the Layout catalog.
Select Text.
Format the text as shown in these images:
Click on Add Box Below.
Click Add Content to add the EnterpriseOne portlet as shown in the image below for the left pane.
Follow the steps 5, 6 and 7 on the left pane of the EnterpriseOne portlet and add the Sales Order Status portlet from the list of Sales Order Status available.
Click Add Content to add EnterpriseOne portlet as shown in the image below for the center pane.
Follow the steps 5, 6 and 7 on the center pane of the E1 portlet and add the CSS Shipment Status Tracking portlet from the list of CSS Shipment Status Tracking available.
Follow the steps 5, 6 and 7 on the right pane of the E1 portlet and add the CSS Shipment Delivery portlet from the list of CSS Shipment Delivery available.
Click Add Content to add layout portlet.
Follow steps 13 and 14 and format the text as shown in the following images:
Click on Add box right.
Follow the steps 5, 6 and 7 on the left pane of the E1 portlet and add the CSS Account Balance portlet from the list of CSS Account Balance available.
Follow the steps 5, 6 and 7 on the right pane of the E1 portlet and add the CSS Account Aging portlet from the list of CSS Account Aging available.
WebCenter Spaces also provides a variety of page layouts (called styles) that you can use to create different types of pages with different layouts. Page types may restrict the type of content that you can add to a page, such as text only, wiki only, blog only, and the like. Page layouts define the number of columns and content areas that define a page's geometry. Layouts are initially determined by the style you select when you create the page. Some page styles inherently allow switching to another page layout, others, such as wikis and blogs.
In addition to the preceded layouts available through page styles, you can create your own layouts using the layout components available through the Resource Catalog.
The Employee Self Service portal page is created using nine EnterpriseOne FDA portlets. The following images comprise the Employee Self Service portal page.
To create the Employee Self Service page:
Enter the Page Name as Employee Self Service and let the Scheme be Blank. Click the Create button. This will show Customer Self Service page in Edit mode with only one column.
Open the Portlets catalog.
Select stb_oracle_webcenter (this name could be different on your setup to see the list of E1 portlets available.
This image shows the beginning of the list of available portlets:
On the Employee Self Service page, the left pane has these portlets in this order:
HR - My Profile
HR - Paid Time Off
HR - Employee Career
HR - eRecruit
To add the HR - My Profile portlet to the left pane search for the string HR_MyProfile to find the list of HR_MyProfile portlets available and add the required portlet from the list to the portal page.
To add the HR - Paid Time Off portlet to the left pane search for the string HR_Paid to find the list of HR_PaidTimeOff portlets available and add the required portlet from the list to the portal page.
To add the HR - Employee Career portlet to the left pane search for the string HR_Employee to find the list of portlets starting with the string HR_Employee and add the required HR - Employee Career portlet from the list to the portal page.
To add the HR - eRecruit portlet to the left pane search for the string HR_eRecruit to find the list of HR_eRecruit portlets available and add the required portlet from the list to the portal page.
After adding all the required portlets to left pane click the Close button.
Notice that the portlets are arranged on the left pane of the portal page in reverse order. We can move the portlets up or down so that the portlets are arranged as given in the sample portal page. Follow the steps below to move the portlets.
All of the portlets on WebCenter have the Action menu which has the menu item to move up/down and to refresh. Since the HR - eRecruit portlet has to be at the bottom of the left pane, click on the Move Down menu action.
Continue to move the HR_eRecruit portlet down until it reaches the bottom on the left pane.
Similarly arrange the positions of other portlets by moving up or down as required.
The portlets can also be arranged by drag and drop.The following portlets need to be added to the Right pane in the order given below:
HR_Payroll
HR_TimeEntry
HR_Payment Review
HR Employee Performance Management
HR Enhance Employee Self Service
To avoid re-arranging the portlets on the right pane, add the portlets to the right pane in the reverse order starting with HR - Enhance Employee Self Service.To remove the Portlet header:
Click the Edit button on portlet.
Select the Display Options tab and then uncheck Display Header.
For EnterpriseOne portlets to work on WebCenter, the property Render Portlet in I Frame which is available on the Display Options of Component properties should be set to true. To set the property click on the edit button of the portlet and select the Display Options tab. Set the property Render Portlet in I Frame to true as shown in the image below.
The following image represents the Supplier Self-Service portal page:
Follow these steps to create the Supplier Self-Service page:
Enter the Page Name as Supplier Self-Service and let the Scheme be Blank and click Create button. This will show Supplier Self-Service page in Edit mode having only one column.
Select STG_WSRP_DEN60201JEMS8390 (this name could be different based on the setup) to see the list of EnterpriseOne portlets available.
Add the Configurable_SRM Component portlet from the list of portlets available.
Save and close the page. Click on Edit Configuration link.
Add the alerts as shown in the image using the arrow to move them from the Available Alerts grid to the Selected Alerts grid.
Click on Next. This will allow the user to override all the alert names as desired.
The images below list the alert name overrides:
Figure 8-13 Purchase Orders At Status Alert
Figure 8-14 Purchase Orders Awaiting Shipment Alert
Figure 8-15 Purchase Orders Awaiting Acknowledge Alert
Figure 8-16 Purchase Orders At Status Alert
Figure 8-17 Purchase Orders Awaiting Acknowledge Alert
Figure 8-18 Purchase Orders At Status Alert
Figure 8-19 Purchase Orders At Route Step - Orders in Inspection Alert
Figure 8-20 Purchase Orders at Route Step - Orders at Dock Alert
Figure 8-21 Purchase Orders At Route Step More Than X Days
Figure 8-22 Adhoc Schedule Advanced Inquiry
Figure 8-23 Adhoc Schedule Committed Not Equal Planned Alert
Figure 8-24 Adhoc Schedule No Response From Supplier in X Days Alert
Figure 8-25 Blanket Schedule Advanced Search Alert
Figure 8-26 Blanket Schedule Committed Not Equal Planned Alert
Figure 8-27 Blanket Schedule No Response From Supplier in X Days
Figure 8-28 Inventory Advanced Search Alert
Figure 8-29 Search for Receipt Lines Alert
Figure 8-30 Search for Payment Information Alert
User can change the order in which alerts are displayed using the Move Up or Move Down icons.
Click on Edit Page options available under page actions.
Click on Add Box Down.
Click on Add Content to add E1 portlets.
Follow the steps 5, 6 and add Configurable_HTML_URI_IURI_Component from the available list as shown in the following image.
Click on the edit button of the portlet and select the Display Options tab. Set the property Render Portlet in I Frame to true as shown in the screen shot below.
Enter the Name as SSS and Title as SSS and paste following text in “HTML Code” text area and click “NEXT” button.
<P><Font Color="#336699"></p><b><big>Supplier Maintenance</big></b>
<br>
<A HREF="javascript:RunOWApp('P01012_W01012B_ZJDE0001');">Address Book Information Maintenance</a><br>
Click on Add Content to add EnterpriseOne portlets.
Follow the steps 5 and 6 and add Supplier Self Service Search from the available list.
The sample My Workspace portal page layout has portlets arranged in two columns. The page has two EnterpriseOne FDA portlets one Configurable HTML portlet and two WebCenter portlets, as shown below.
Follow these steps to create the My Workspace portal page:
Enter Page Name as My Workspace and let the Scheme be Blank. Click the Create button. This will show My Workspace page in Edit mode having only one column.
Since the sample page has two columns click on Add Box Right as shown in this image.
Click Add Content on the left pane to add portlets.
Open stb_oracle_webcenter (this name could be different based on the setup) to see the list of E1 portlets available.
Add two Configurable HTML portlets. To add the Configurable_HTML_URI_IURI_Component portlet to the left pane, search for the string Configurable_HTML to find the list of portlets, starting with the string Configurable_HTML.
To add the HR - My Profile portlet to the left pane, search for the string HR_MyProfile to find the list of HR_MyProfile portlets available, and then add the required portlet from the list to the portal page.
Add the required portlet from the list to the portal page, and then click the Close button to close the catalog.
To change the header of the Configurable HTML portlet, click the Edit button on Configurable HTML portlet as show below.
On the Display Options tab, set Title as Employee Self Service - My Task.
To configure the Configurable HTML portlet, click the Configure icon on the portlet. Make sure that the steps given under the topic Required WebCenter EnterpriseOne Portlets Setup are completed for the configurable portlet to work.
Make sure that Create a new portlet of portlet type radio button is selected and select HTML Portlet from the list.
Enter the Name as ESS_MyTask and Title as ESS My Task and paste following text in the HTML Code text area. Click Next.
<A HREF="javascript:RunOWApp('P087715_W087715A_ZJDE0001');">Daily Diary</a><br>
<A HREF="javascript:RunOWApp('P07620_W07620A_ZJDE0001');">Global Leave Director</a><br>
Set required permissions. Click Done.
To change the header of the second Configurable HTML portlet, click the Edit button on the Configurable HTML portlet.
On the Display Options tab, set the Title as My Organizational Chart.
To configure the Configurable HTML portlet, click the Configure icon of the portlet. Make sure that the steps given under the topic Required WebCenter EnterpriseOne Portlets Setup are completed for the configurable portlet to work.
Make sure that Create a new portlet of portlet type radio button is selected. Select HTML Portlet from the list.
. Enter the Name as My Org and Title as My Organizational Chart. Paste the following text in the HTML Code text area. Click Next.
<A HREF="javascript:RunOWApp('P08713W_W08713WB_ZJDE0001');">View Chart</a><br>
Adding Portlets to the Right Pane
To add portlets to the right pane follow these steps:
Click Add Content on the right pane.
Open the Layout catalog.
Add the Movable Box portlet.
Go to the Portlets folder.
Select stb_oracle_webcenter (this name could be different based on the setup) to see the list of EnterpriseOne portlets available.
To add the Print Queue Center portlet to the right pane, search for the string PrinQueueCenter in order to find the list of PrinQueueCenter portlets available, and then add the required portlet from the list to the portal page.
Follow these steps to add contents to the Movable Box portlet:
Click the Add Content button on the Movable Box portlet.
Add three hyperlink portlets.
Close the Catalog.
Follow these steps to configure the hyperlink portlets added in the previous step:
Click Edit on the hyperlink portlet.
On the Display Options tab, set Title as Check E-mail and set Destination with the URL of the Web mail. Make sure that Open in a new window is checked so that the web mail opens in a new window.
On the Style tab set the Font and Font Size as shown below. Click OK.
To configure the second hyperlink portlet, click Edit on the hyperlink portlet as shown below.
On the Display Options tab, set Title as Employee Handbook and set Destination with the URL of the Employee Handbook. Make sure that Open in a new window is checked so that the Employee Handbook opens in a new window.
On the Display Options tab, set Title as My Oracle Support and set Destination with the URL of the My Oracle Support. Make sure that Open in a new window is checked so that the My Oracle Support opens in a new window.
To remove heading of the Print Queue Center portlet, click on the edit button on the portlet, and then select the Display Options tab and uncheck Display Header as shown below.
To change the heading of the Movable Box portlet follow these steps.
Click on the Edit button on the Movable Box portlet.
Set Text as Quick Forms and Links.
Save the changes made to the portal page.
