1 Getting Started with Delta Process
This chapter contains the following topics:
1.1 JD Edwards EnterpriseOne Delta Process Overview
Delta Process is used to determine the development changes that have occurred in translation tables.
1.2 JD Edwards EnterpriseOne Delta Process Implementation
This section provides an overview of the steps that are required to implement Delta Process.
In the planning phase of the implementation, take advantage of all JD Edwards sources of information, including the installation guides and troubleshooting information.
1.2.1 Delta Process Implementation Steps
This table lists the steps for the Delta Process implementation.
  1. Set Delta Process for each release.
    See Understanding the Delta Process.
  2. Set up default location and printers.
    See "Working with Report Printing Administration" in the JD Edwards EnterpriseOne Tools Report Printing Administration Technologies Guide.
