Glossary
activity rule
The criteria by which an object progresses from one given point to the next in a flow.
data structure
A collection of data items used to pass data to other components of the same application or to another application entirely. Data structures are composed of data items defined in the data dictionary.
embedded event rule
An event rule that is specific to a particular table or application. Examples include form-to-form calls, hiding a field based on a processing option value, and calling a business function. Contrast with the business function event rule.
event rule
A logic statement that instructs the system to perform one or more operations based on an activity that can occur in a specific application, such as entering a form or exiting a field.
media storage object
Files that use one of the following naming conventions that are not organized into table format: Gxxx, xxxGT, or GTxxx.
processing option
A data structure that enables users to supply parameters that regulate the running of a batch program or report. For example, you can use processing options to specify default values for certain fields, to determine how information appears or is printed, to specify date ranges, to supply runtime values that regulate program execution, and so on.
table access management (TAM)
The JD Edwards EnterpriseOne component that handles the storage and retrieval of use-defined data. TAM stores information, such as data dictionary definitions; application and report specifications; event rules; table definitions; business function input parameters and library information; and data structure definitions for running applications, reports, and business functions.
