Glossary
fast path
A command prompt that enables the user to move quickly among menus and applications by using specific commands.
in-your-face error
In JD Edwards EnterpriseOne, a form-level property which, when enabled, causes the text of application errors to appear on the form.
MailMerge Workbench
An application that merges Microsoft Word 6.0 (or higher) word-processing documents with JD Edwards EnterpriseOne records to automatically print business documents. You can use MailMerge Workbench to print documents, such as form letters about verification of employment.
media storage object
Files that use one of the following naming conventions that are not organized into table format: Gxxx, xxxGT, or GTxxx.
message center
A central location for sending and receiving all JD Edwards EnterpriseOne messages (system and user generated), regardless of the originating application or user.
processing option
A data structure that enables users to supply parameters that regulate the running of a batch program or report. For example, you can use processing options to specify default values for certain fields, to determine how information appears or is printed, to specify date ranges, to supply runtime values that regulate program execution, and so on.
QBE
An abbreviation for query by example. In JD Edwards EnterpriseOne, the QBE line is the top line on a detail area that is used for filtering data.
selection
Found on JD Edwards EnterpriseOne menus, a selection represents functions that you can access from a menu. To make a selection, type the associated number in the Selection field and press Enter.
visual assist
Forms that can be invoked from a control via a trigger to assist the user in determining what data belongs in the control.
