This appendix contains the following topic:
This table lists the web runtime cookies that the HTML Server sends to a web browser when running JD Edwards EnterpriseOne web applications.
| JD Edwards EnterpriseOne Web Runtime Cookie | Purpose | Life Span | Turn ON/OFF |
| com_jdedwards_LastLayout | This cookie stores the Portal Workspace (WORKSPACEID) that was last accessed by a user (USERID).
Note: This cookie is only applicable to Portal users. |
The life span of the cookie is one year. | You cannot turn off this cookie. |
| com_jdedwards_CSN | This cookie stores the information to implement critical state functionality for the HTML Client Component running inside the Portal. | 10000 milliseconds. | You cannot turn off this cookie. |
| advancedState | This cookie stores the information about whether to display the Environment and Role fields on the JD Edwards EnterpriseOne sign-in screen. | Seven days. | This cookie is created only if the DisplayEnvironment property defined in the [LOGIN] section of the JAS.INI is not set to "HIDDEN". |
| jdeLoginCookie | This cookie stores the username, password, role, language code and rtlLayout information about a user's login in an encrypted format. | The life span of the cookie depends on the value of CookieLifeTime property defined in the [SECURITY] section of the JAS.INI file. If this property is not defined, then by default, this cookie's life span is set to seven days. | This cookie is not created if the UseLogonCookie property defined in the [SECURITY] section of the JAS.INI is set to false. The system does not create this cookie by default. |
| AutoPopulate | This cookie stores a user's preference of whether to auto populate the grid on a form. A user can turn the autopopulate grid option on/off by using the AutoPopulate option in the Tools menu on a form. | The life span of the cookie one year. | You cannot turn off this cookie. |
| maxLogLength | This cookie determines the maximum number of javascript debug statements that can be logged using JSMonitor.log() API. The default value for this cookie is 15. A developer can turn on the logging by clicking the Enable JSMonitor button after pressing Ctrl+D. | This cookie never expires. | You cannot turn off this cookie. |
