Access provisioning is the process of setting up user and role profiles in EnterpriseOne in order for users to gain access to EnterpriseOne and the particular applications and features they are authorized to use. After you set up user and role profiles, you can create sign-in security records for each user. You also have the option to set up a single sign-on configuration or configuring EnterpriseOne to manage users through third-party, LDAP-enabled systems. See Part IV, "EnterpriseOne Authentication Security" for more information.
In addition, you use user and role profiles to create security records for authorizing access to particular EnterpriseOne applications, features, and data. See Part V, "EnterpriseOne Authorization Security" for more information.
This part contains the following chapter:
