This chapter contains the following topic:
To run the web server, the server must have access to a set of serialized Oracle's JD Edwards EnterpriseOne JAS objects. These objects can be generated directly from Oracle's JD Edwards EnterpriseOne objects using the appropriate set of JD Edwards EnterpriseOne specifications.
Generating JD Edwards EnterpriseOne serialized objects requires a specific machine configuration. While it is possible to configure a web server to generate JD Edwards EnterpriseOne serialized objects, the recommended method is to dedicate a separate generation machine for this process.
The eGenerator software can change with each Tools Release.See the Generating JD Edwards EnterpriseOne Serialized Objects appendix in theJD Edwards EnterpriseOne Tools HTML Web Server Installation Guide.
There are eight versions of this guide which depend on platform and application server.
