This chapter contains the following topics:
Section 3.1, "Understanding the Deployment Server Installation"
Section 3.3, "Using the Oracle Software Delivery Cloud to Acquire Updates"
Section 3.4, "Installing the Software Update on the Deployment Server"
For ASUs, service packs, and tools releases, follow the instructions included with each update.The Deployment Server is the central hub for distribution of Oracle's JD Edwards EnterpriseOne objects to servers and users. The update process delivers changes to the deployment server to integrate with that distribution process. Each update type has a slightly different method of completing this task but the outcome is the same.
The installation process for the deployment server includes these tasks:
Acquiring the update from the Update Center, Oracle Software Delivery Cloud portal.
Installing the objects from the CDs or the Web.
Link to the Update Center through My Oracle Support or use Oracle's JD Edwards EnterpriseOne and World Change Assistant from your desktop to acquire all ESUs and updates for other Oracle JD Edwards EnterpriseOne and World products. JD Edwards EnterpriseOne and World Change Assistant streamlines the update process. This versatile new tool simplifies the installation and deployment of ESUs and other updates.
See Also:
If you already have JD Edwards EnterpriseOne 9.0 software and want to acquire an update, go to the Oracle Software Delivery Cloud portal at https://edelivery.oracle.com, or contact your local Customer Care Center. The Oracle Software Delivery Cloud portal enables you to obtain your software electronically. At this portal, you will find instructions for use, available languages, access to download software, and a list of releases that are available for download.
The following process installs the software update on the deployment server. This installation may be from a CD or a download from the Update Center via My Oracle Support or JD Edwards EnterpriseOne and World Change Assistant.
Before you run the installation program, shut down all programs running on the deployment server that could cause Dynamic Link Library (DLL) conflicts (such as Internet Explorer or Adobe Reader).
This table lists the requirements for installing the software update on the deployment server:
| Action | Tasks |
| Personnel | Installer |
| Logon status | Logged on to the deployment server with administrator rights. You must log off JD Edwards EnterpriseOne before completing this task. |
| Prerequisites | You must create the JDE user. |
| Concurrent Tasks | None |
To install an ESU that was downloaded from the Update Center:
Locate the downloaded JLnnnnn.exe file.
Double-click the JLnnnnnn.exe file. The Client Workstation Setup Screen appears.
Click Next, the package size is calculated. The Installation Setup Type appears.
Click Finish.
To install ASUs from a CD:
Insert the setup CD into the CD drive.
Double-click the InstallManager.exe file. The Installation Setup Screen appears.
Click Next, and the package size is calculated. The Installation Setup Type appears.
Click Finish.
See Also:
After completing this step, the update is ready to deploy to an environment. JD Edwards EnterpriseOne updates (ASU and ESU) are located in a folder under the Planner path code (..\Planner\Package\package name).Note:
Complete your Impact Analysis at this time and then continue with deployment using JD Edwards EnterpriseOne and World Change Assistant, the JD Edwards EnterpriseOne Software Updates application, or special instructions included with your update.
