This chapter contains the following topic:
JD Edwards EnterpriseOne OMW automates many of the object management tasks that users perform in the software. Much of this automation requires careful configuration by the system administrator through the Object Management Workbench Configuration program (P98220).
Use P98220 to configure these features:
| Option | Description |
| Constants | Enables you to set general constants pertaining to JD Edwards EnterpriseOne OMW projects. |
| SAR System Integration | Enables you to disable SAR system integration with JD Edwards EnterpriseOne OMW and, thus, JD Edwards EnterpriseOne development tools. |
| Logging System | Enables you to specify the project and object events to be logged. In the event that logging fails, you can also disable development or allow development but disable transfers. |
| Object Action Notification | Enables you to enable and disable Object Action Notification, which sends a notification message when an action such as checkin or checkout is performed on an object. |
| Notification Setup | Enables developers to be notified, using subscription, when actions are performed on an object. |
| Activity Rules | Enables you to add and modify project statuses and object transfer activity rules. |
| User Roles | Enables you to maintain user roles. |
| Allowed Actions | Enables you to assign to a user role the actions allowed for each object type during a specific project status. |
| Save Locations | Enables you to add, modify, and delete the locations where you save objects. |
For instructions on how to perform these JD Edwards EnterpriseOne OMW administrative tasks, see JD Edwards EnterpriseOne Tools Object Management Workbench Guide.
