Use this procedure to uninstall the Transaction Server RTE Software Component using Server Manager.
Log on to the Server Manager console.
Click on the managed home location.
Select the Transaction Server Real Time Events (RTE) instance.
Click the Remove Instance button.
Post Uninstallation. If after you uninstall the Transaction Server RTE instance, this folder is present, you must manually delete it:<WAS_ PROFILE_LOC>\filestores\ORABus-<RTE_INSTANCE_NAME>
