The charts in this section illustrate the directory structures for JD Edwards EnterpriseOne on the Deployment Server, the Enterprise Server, and Workstations. You must understand these directory structures to verify that you installed or upgraded Release 9.1 correctly.
Assuming you use the recommended shared path names, the process does not delete or overlay your previous release. You will have the Release 9.1 directories in addition to your existing directories.
The recommended configuration is for all business functions to be mapped to the server. The only exception to this rule is a client development environment in which case all business functions should be mapped locally.
This chapter discusses:
After you install Release 9.1 on the Deployment Server, you should have the following directory structure:
JDEdwardsE910\CD Templates JDEdwardsE910\CD Templates\Esu & Asu JDEdwardsE910\CD Templates\Esu & Asu\planner JDEdwardsE910\CD Templates\Esu & Asu\planner\Package JDEdwardsE910\CD Templates\Esu & Asu\planner\Package\PKGNAME JDEdwardsE910\cfgtoollogs JDEdwardsE910\cfgtoollogs\cfgfw JDEdwardsE910\cfgtoollogs\oui JDEdwardsE910\Change Assistant JDEdwardsE910\Change Assistant\Downloads JDEdwardsE910\Change Assistant\Downloads\CopiedESUs JDEdwardsE910\Change Assistant\Downloads\ESUs JDEdwardsE910\Change Assistant\Downloads\logs JDEdwardsE910\Change Assistant\SupportAssistant JDEdwardsE910\client JDEdwardsE910\database JDEdwardsE910\database\Oracle JDEdwardsE910\database\SQL JDEdwardsE910\database\UDB JDEdwardsE910\diagnostics JDEdwardsE910\diagnostics\config JDEdwardsE910\diagnostics\config\registration JDEdwardsE910\path_code JDEdwardsE910\path_code\bin32 JDEdwardsE910\path_code\include JDEdwardsE910\path_code\ini JDEdwardsE910\path_code\ini\sbf JDEdwardsE910\path_code\java JDEdwardsE910\path_code\java\sbfjars JDEdwardsE910\path_code\lib32 JDEdwardsE910\path_code\make JDEdwardsE910\path_code\obj JDEdwardsE910\path_code\PACKAGE JDEdwardsE910\path_code\PACKAGE\DATA JDEdwardsE910\path_code\PACKAGE\DATACOMP JDEdwardsE910\path_code\PACKAGE\path_codeFA JDEdwardsE910\path_code\PACKAGE\path_codeFA\bin32 JDEdwardsE910\path_code\PACKAGE\path_codeFA\include JDEdwardsE910\path_code\PACKAGE\path_codeFA\java JDEdwardsE910\path_code\PACKAGE\path_codeFA\java\sbfjars JDEdwardsE910\path_code\PACKAGE\path_codeFA\lib32 JDEdwardsE910\path_code\PACKAGE\path_codeFA\make JDEdwardsE910\path_code\PACKAGE\path_codeFA\obj JDEdwardsE910\path_code\PACKAGE\path_codeFA\res JDEdwardsE910\path_code\PACKAGE\path_codeFA\res\actionbmps JDEdwardsE910\path_code\PACKAGE\path_codeFA\res\AVI Files JDEdwardsE910\path_code\PACKAGE\path_codeFA\res\FormLines JDEdwardsE910\path_code\PACKAGE\path_codeFA\res\Icons JDEdwardsE910\path_code\PACKAGE\path_codeFA\res\images JDEdwardsE910\path_code\PACKAGE\path_codeFA\res\treebmps JDEdwardsE910\path_code\PACKAGE\path_codeFA\source JDEdwardsE910\path_code\PACKAGE\path_codeFA\spec JDEdwardsE910\path_code\PACKAGE\path_codeFA\spec\runtimeCache JDEdwardsE910\path_code\PACKAGE\path_codeFA\work JDEdwardsE910\path_code\PACKAGE\path_codeFA\work\sbf JDEdwardsE910\path_code\PACKAGE\path_codeFA\work\sbf\oas JDEdwardsE910\path_code\PACKAGE\path_codeFA\work\sbf\oas\META-INF JDEdwardsE910\path_code\res JDEdwardsE910\path_code\res\actionbmps JDEdwardsE910\path_code\res\AVI Files JDEdwardsE910\path_code\res\FormLines JDEdwardsE910\path_code\res\Icons JDEdwardsE910\path_code\res\images JDEdwardsE910\path_code\res\treebmps JDEdwardsE910\path_code\source JDEdwardsE910\path_code\spec JDEdwardsE910\path_code\spec\runtimeCache JDEdwardsE910\path_code\work JDEdwardsE910\path_code\work\sbf JDEdwardsE910\path_code\work\sbf\oas JDEdwardsE910\path_code\work\sbf\oas\META-INF
In the preceding paths, thepath_code portion is DV910, PD910, PS910, or PY910.Note:
ThePACKAGE\path_code directory contains the same sub-structure as this parent directory:
JDEdwards910\path_code
JDEdwardsE910\E1InstallerLibs JDEdwardsE910\install JDEdwardsE910\inventory JDEdwardsE910\inventory\Actions21 JDEdwardsE910\inventory\Actions21\e1FileActions JDEdwardsE910\inventory\Actions21\e1FileActions\10.2.0.3.0 JDEdwardsE910\inventory\Actions21\e1GeneralActions JDEdwardsE910\inventory\Actions21\e1FileActions\10.2.0.3.0 JDEdwardsE910\inventory\Actions21\e1PackageActions JDEdwardsE910\inventory\Actions21\e1PackageActions\10.2.0.3.0 JDEdwardsE910\inventory\Actions21\fileActions JDEdwardsE910\inventory\Actions21\fileActions\11.2.0.2.0 JDEdwardsE910\inventory\Actions21\generalActions JDEdwardsE910\inventory\Actions21\generalActions\10.2.0.9.0 JDEdwardsE910\inventory\Actions21\ntServicesActions JDEdwardsE910\inventory\Actions21\ntServicesActions\10.2.0.6.0 JDEdwardsE910\inventory\Actions21\ntw32FoldersActions JDEdwardsE910\inventory\Actions21\ntw32FoldersActions\10.2.0.3.0 JDEdwardsE910\inventory\Actions21\SpawnActions JDEdwardsE910\inventory\Actions21\SpawnActions\10.1.0.3.4 JDEdwardsE910\inventory\Actions21\w32RegActions JDEdwardsE910\inventory\Actions21\w32RegActions\10.2.0.1.0 JDEdwardsE910\inventory\backup JDEdwardsE910\inventory\checkpoints JDEdwardsE910\inventory\Clone JDEdwardsE910\inventory\Components21 JDEdwardsE910\inventory\Components21\com.e1.bpm JDEdwardsE910\inventory\Components21\com.e1.bpm\1.0.0.0.0 JDEdwardsE910\inventory\Components21\com.e1.bpm\1.0.0.0.0\resources JDEdwardsE910\inventory\Components21\com.e1.deployment.data JDEdwardsE910\inventory\Components21\com.e1.deployment.data\1.0.0.0.0 JDEdwardsE910\inventory\Components21\com.e1.deployment.data\1.0.0.0.0\resources JDEdwardsE910\inventory\Components21\com.e1.deployment.development JDEdwardsE910\inventory\Components21\com.e1.deployment.development\9.1.0.0.0 JDEdwardsE910\inventory\Components21\com.e1.deployment.development\9.1.0.0.0\resources JDEdwardsE910\inventory\Components21\com.e1.deployment.e1files JDEdwardsE910\inventory\Components21\com.e1.deployment.e1files\9.1.0.0.0 JDEdwardsE910\inventory\Components21\com.e1.deployment.e1files\9.1.0.0.0\resources JDEdwardsE910\inventory\Components21\com.e1.deployment.oh4a JDEdwardsE910\inventory\Components21\com.e1.deployment.oh4a\1.0.0.0.0 JDEdwardsE910\inventory\Components21\com.e1.deployment.oh4a\1.0.0.0.0\resources JDEdwardsE910\inventory\Components21\com.e1.deployment.planner JDEdwardsE910\inventory\Components21\com.e1.deployment.planner\9.1.0.0.0 JDEdwardsE910\inventory\Components21\com.e1.deployment.planner\9.1.0.0.0\resources JDEdwardsE910\inventory\Components21\com.e1.deployment.top JDEdwardsE910\inventory\Components21\com.e1.deployment.top\9.1.0.0.0 JDEdwardsE910\inventory\Components21\com.e1.deployment.top\9.1.0.0.0\resources JDEdwardsE910\inventory\Components21\com.e1.features JDEdwardsE910\inventory\Components21\com.e1.features\1.0.0.0.0 JDEdwardsE910\inventory\Components21\com.e1.features\1.0.0.0.0\resources JDEdwardsE910\inventory\Components21\com.e1.foundation JDEdwardsE910\inventory\Components21\com.e1.foundation\1.0.0.0.0 JDEdwardsE910\inventory\Components21\com.e1.foundation\1.0.0.0.0\resources JDEdwardsE910\inventory\Components21\oracle.jdk JDEdwardsE910\inventory\Components21\oracle.jdk\1.6.0.21.51 JDEdwardsE910\inventory\Components21\oracle.jdk\1.6.0.21.51\resources JDEdwardsE910\inventory\Components21\oracle.swd.opatch JDEdwardsE910\inventory\Components21\oracle.swd.opatch\11.2.0.0.2 JDEdwardsE910\inventory\Components21\oracle.swd.opatch\11.2.0.0.2\resources JDEdwardsE910\inventory\Components21\oracle.swd.oui JDEdwardsE910\inventory\Components21\oracle.swd.oui\11.2.0.2.0 JDEdwardsE910\inventory\Components21\oracle.swd.oui\11.2.0.2.0\resources JDEdwardsE910\inventory\Components21\oracle.swd.oui.core JDEdwardsE910\inventory\Components21\oracle.swd.oui.core\11.2.0.2.0 JDEdwardsE910\inventory\Components21\oracle.swd.oui.core\11.2.0.2.0\resources JDEdwardsE910\inventory\ContentsXML JDEdwardsE910\inventory\ContentsXML\ConfigXML JDEdwardsE910\inventory\Dialogs21 JDEdwardsE910\inventory\Dialogs21\standardDialogs JDEdwardsE910\inventory\Dialogs21\standardDialogs\10.2.0.1.0 JDEdwardsE910\inventory\Queries21 JDEdwardsE910\inventory\Queries21\areasQueries JDEdwardsE910\inventory\Queries21\areasQueries\10.2.0.1.0 JDEdwardsE910\inventory\Queries21\e1DBQueries JDEdwardsE910\inventory\Queries21\e1DBQueries\10.2.0.3.0 JDEdwardsE910\inventory\Queries21\e1FileQueries JDEdwardsE910\inventory\Queries21\e1FileQueries\10.2.0.3.0 JDEdwardsE910\inventory\Queries21\e1GeneralQueries JDEdwardsE910\inventory\Queries21\e1GeneralQueries\10.2.0.3.0 JDEdwardsE910\inventory\Queries21\e1PackageQueries JDEdwardsE910\inventory\Queries21\e1PackageQueries\10.2.0.3.0 JDEdwardsE910\inventory\Queries21\fileQueries JDEdwardsE910\inventory\Queries21\fileQueries\10.1.0.3.0 JDEdwardsE910\inventory\Queries21\generalQueries JDEdwardsE910\inventory\Queries21\generalQueries\10.2.0.2.0 JDEdwardsE910\inventory\Queries21\w32RegQueries JDEdwardsE910\inventory\Queries21\w32RegQueries\10.2.0.1.0 JDEdwardsE910\inventory\Queries21\WindowsGeneralQueries JDEdwardsE910\inventory\Queries21\WindowsGeneralQueries\10.2.0.1.0 JDEdwardsE910\inventory\Scripts JDEdwardsE910\inventory\Scripts\ext JDEdwardsE910\inventory\Scripts\ext\jlib JDEdwardsE910\inventory\Scripts\ext\lib JDEdwardsE910\inventory\Templates JDEdwardsE910\inventory\Templates\OPatch JDEdwardsE910\inventory\Templates\oui JDEdwardsE910\inventory\Templates\oui\bin JDEdwardsE910\inventory\Templates\system JDEdwardsE910\inventory\Templates\system\OC4J JDEdwardsE910\inventory\Templates\system\OC4J\j2ee JDEdwardsE910\inventory\Templates\system\OC4J\j2ee\home JDEdwardsE910\inventory\Templates\system\OC4J\j2ee\home\applications JDEdwardsE910\inventory\Templates\system\OC4J\j2ee\home\applications\webclient.ear JDEdwardsE910\inventory\Templates\system\OC4J\j2ee\home\applications\webclient.ear\webclient JDEdwardsE910\inventory\Templates\system\OC4J\j2ee\home\applications\webclient.ear\webclient\WEB-INF JDEdwardsE910\inventory\Templates\system\OC4J\j2ee\home\applications\webclient.ear\webclient\WEB-INF\classes JDEdwardsE910\jdk JDEdwardsE910\jdk\bin JDEdwardsE910\jdk\include JDEdwardsE910\jdk\include\win32 JDEdwardsE910\jdk\jre JDEdwardsE910\jdk\jre\bin JDEdwardsE910\jdk\jre\bin\client JDEdwardsE910\jdk\jre\bin\new_plugin JDEdwardsE910\jdk\jre\bin\server JDEdwardsE910\jdk\jre\lib JDEdwardsE910\jdk\jre\lib\applet JDEdwardsE910\jdk\jre\lib\audio JDEdwardsE910\jdk\jre\lib\cmm JDEdwardsE910\jdk\jre\lib\deploy JDEdwardsE910\jdk\jre\lib\deploy\jqs JDEdwardsE910\jdk\jre\lib\deploy\jqs\ff JDEdwardsE910\jdk\jre\lib\deploy\jqs\ff\chrome JDEdwardsE910\jdk\jre\lib\deploy\jqs\ff\chrome\content JDEdwardsE910\jdk\jre\lib\deploy\jqs\ie JDEdwardsE910\jdk\jre\lib\ext JDEdwardsE910\jdk\jre\lib\fonts JDEdwardsE910\jdk\jre\lib\i386 JDEdwardsE910\jdk\jre\lib\im JDEdwardsE910\jdk\jre\lib\images JDEdwardsE910\jdk\jre\lib\images\cursors JDEdwardsE910\jdk\jre\lib\management JDEdwardsE910\jdk\jre\lib\security JDEdwardsE910\jdk\jre\lib\servicetag JDEdwardsE910\jdk\jre\lib\zi JDEdwardsE910\jdk\jre\lib\zi\Africa JDEdwardsE910\jdk\jre\lib\zi\America JDEdwardsE910\jdk\jre\lib\zi\America\Argentina JDEdwardsE910\jdk\jre\lib\zi\America\Indiana JDEdwardsE910\jdk\jre\lib\zi\America\Kentucky JDEdwardsE910\jdk\jre\lib\zi\America\North_Dakota JDEdwardsE910\jdk\jre\lib\zi\Antarctica JDEdwardsE910\jdk\jre\lib\zi\Asia JDEdwardsE910\jdk\jre\lib\zi\Atlantic JDEdwardsE910\jdk\jre\lib\zi\Australia JDEdwardsE910\jdk\jre\lib\zi\Etc JDEdwardsE910\jdk\jre\lib\zi\Europe JDEdwardsE910\jdk\jre\lib\zi\Indian JDEdwardsE910\jdk\jre\lib\zi\Pacific JDEdwardsE910\jdk\jre\lib\zi\SystemV JDEdwardsE910\jdk\lib JDEdwardsE910\jdk\lib\visualvm JDEdwardsE910\jdk\lib\visualvm\etc JDEdwardsE910\jdk\lib\visualvm\platform11 JDEdwardsE910\jdk\lib\visualvm\platform11\config JDEdwardsE910\jdk\lib\visualvm\platform11\config\ModuleAutoDeps JDEdwardsE910\jdk\lib\visualvm\platform11\config\Modules JDEdwardsE910\jdk\lib\visualvm\platform11\core JDEdwardsE910\jdk\lib\visualvm\platform11\core\locale JDEdwardsE910\jdk\lib\visualvm\platform11\docs JDEdwardsE910\jdk\lib\visualvm\platform11\lib JDEdwardsE910\jdk\lib\visualvm\platform11\lib\locale JDEdwardsE910\jdk\lib\visualvm\platform11\modules JDEdwardsE910\jdk\lib\visualvm\platform11\modules\ext JDEdwardsE910\jdk\lib\visualvm\platform11\modules\ext\locale JDEdwardsE910\jdk\lib\visualvm\platform11\modules\locale JDEdwardsE910\jdk\lib\visualvm\platform11\update_tracking JDEdwardsE910\jdk\lib\visualvm\profiler3 JDEdwardsE910\jdk\lib\visualvm\profiler3\config JDEdwardsE910\jdk\lib\visualvm\profiler3\config\Modules JDEdwardsE910\jdk\lib\visualvm\profiler3\lib JDEdwardsE910\jdk\lib\visualvm\profiler3\lib\deployed JDEdwardsE910\jdk\lib\visualvm\profiler3\lib\deployed\jdk15 JDEdwardsE910\jdk\lib\visualvm\profiler3\lib\deployed\jdk15\windows JDEdwardsE910\jdk\lib\visualvm\profiler3\lib\deployed\jdk16 JDEdwardsE910\jdk\lib\visualvm\profiler3\lib\deployed\jdk16\windows JDEdwardsE910\jdk\lib\visualvm\profiler3\lib\locale JDEdwardsE910\jdk\lib\visualvm\profiler3\modules JDEdwardsE910\jdk\lib\visualvm\profiler3\modules\locale JDEdwardsE910\jdk\lib\visualvm\profiler3\update_tracking JDEdwardsE910\jdk\lib\visualvm\visualvm JDEdwardsE910\jdk\lib\visualvm\visualvm\config JDEdwardsE910\jdk\lib\visualvm\visualvm\config\Modules JDEdwardsE910\jdk\lib\visualvm\visualvm\core JDEdwardsE910\jdk\lib\visualvm\visualvm\core\locale JDEdwardsE910\jdk\lib\visualvm\visualvm\modules JDEdwardsE910\jdk\lib\visualvm\visualvm\modules\locale JDEdwardsE910\jdk\lib\visualvm\visualvm\update_tracking JDEdwardsE910\mediaobj JDEdwardsE910\mediaobj\Composer JDEdwardsE910\mediaobj\Composer\html JDEdwardsE910\mediaobj\Composer\html\Images JDEdwardsE910\mediaobj\Composer\Visio JDEdwardsE910\mediaobj\ComposerCBT JDEdwardsE910\mediaobj\ComposerCBT\Order_to_Cash JDEdwardsE910\mediaobj\ComposerCBT\Procure_to_Pay JDEdwardsE910\mediaobj\ComposerCBT\ShowMe_Eapxxxxx JDEdwardsE910\mediaobj\ComposerCBT\ShowMe_Eapxxxxx\graphics JDEdwardsE910\mediaobj\ComposerCBT\ShowMe_Earxxxxx JDEdwardsE910\mediaobj\ComposerCBT\ShowMe_Earxxxxx\graphics JDEdwardsE910\mediaobj\ComposerCBT\ShowMe_Ecoxxxxx JDEdwardsE910\mediaobj\ComposerCBT\ShowMe_Ecoxxxxx\graphics JDEdwardsE910\mediaobj\ComposerCBT\Standard_Graphics JDEdwardsE910\mediaobj\Distribution JDEdwardsE910\mediaobj\Financials JDEdwardsE910\mediaobj\htmlupload JDEdwardsE910\mediaobj\Human Resources JDEdwardsE910\mediaobj\Manufacturing JDEdwardsE910\mediaobj\MISC JDEdwardsE910\mediaobj\Misc Animations JDEdwardsE910\mediaobj\Misc Images JDEdwardsE910\mediaobj\Oleque JDEdwardsE910\mediaobj\OMW JDEdwardsE910\mediaobj\SelfService JDEdwardsE910\mediaobj\Text JDEdwardsE910\MISC JDEdwardsE910\OneWorld Client Install JDEdwardsE910\OneWorld Client Install\install JDEdwardsE910\OneWorld Client Install\install\access JDEdwardsE910\OneWorld Client Install\install\access\jdk JDEdwardsE910\OneWorld Client Install\install\access\jdk\jre JDEdwardsE910\OneWorld Client Install\install\access\jdk\jre\bin JDEdwardsE910\OneWorld Client Install\install\access\jdk\jre\lib JDEdwardsE910\OneWorld Client Install\install\access\jdk\jre\lib\ext JDEdwardsE910\OneWorld Client Install\install\resource JDEdwardsE910\OneWorld Client Install\Misc JDEdwardsE910\OneWorld Client Install\Misc\SBFServer JDEdwardsE910\OneWorld Client Install\Stage JDEdwardsE910\OneWorld Client Install\Stage\Actions JDEdwardsE910\OneWorld Client Install\Stage\Actions\dbActions JDEdwardsE910\OneWorld Client Install\Stage\Actions\dbActions\10.1.0.2.0 JDEdwardsE910\OneWorld Client Install\Stage\Actions\dbActions\10.1.0.2.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1FileActions JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1FileActions\10.2.0.3.0 JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1FileActions\10.2.0.3.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1GeneralActions JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1GeneralActions\10.2.0.3.0 JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1GeneralActions\10.2.0.3.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1ISeriesActions JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1ISeriesActions\10.2.0.3.0 JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1ISeriesActions\10.2.0.3.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1PackageActions JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1PackageActions\10.2.0.3.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Actions\fileActions JDEdwardsE910\OneWorld Client Install\Stage\Actions\fileActions\11.2.0.2.0 JDEdwardsE910\OneWorld Client Install\Stage\Actions\fileActions\11.2.0.2.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Actions\generalActions JDEdwardsE910\OneWorld Client Install\Stage\Actions\generalActions\10.2.0.9.0 JDEdwardsE910\OneWorld Client Install\Stage\Actions\generalActions\10.2.0.9.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Actions\jarActions JDEdwardsE910\OneWorld Client Install\Stage\Actions\jarActions\10.2.0.0.0 JDEdwardsE910\OneWorld Client Install\Stage\Actions\jarActions\10.2.0.0.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Actions\launchPadActions JDEdwardsE910\OneWorld Client Install\Stage\Actions\launchPadActions\10.1.0.2.0 JDEdwardsE910\OneWorld Client Install\Stage\Actions\launchPadActions\10.1.0.2.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Actions\ntServicesActions JDEdwardsE910\OneWorld Client Install\Stage\Actions\ntServicesActions\10.2.0.6.0 JDEdwardsE910\OneWorld Client Install\Stage\Actions\ntServicesActions\10.2.0.6.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Actions\ntw32FoldersActions JDEdwardsE910\OneWorld Client Install\Stage\Actions\ntw32FoldersActions\10.2.0.3.0 JDEdwardsE910\OneWorld Client Install\Stage\Actions\ntw32FoldersActions\10.2.0.3.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Actions\rgsActions JDEdwardsE910\OneWorld Client Install\Stage\Actions\rgsActions\10.1.0.3.0 JDEdwardsE910\OneWorld Client Install\Stage\Actions\rgsActions\10.1.0.3.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Actions\SpawnActions JDEdwardsE910\OneWorld Client Install\Stage\Actions\SpawnActions\10.1.0.3.4 JDEdwardsE910\OneWorld Client Install\Stage\Actions\SpawnActions\10.1.0.3.4\1 JDEdwardsE910\OneWorld Client Install\Stage\Actions\unixActions JDEdwardsE910\OneWorld Client Install\Stage\Actions\unixActions\10.2.0.3.0 JDEdwardsE910\OneWorld Client Install\Stage\Actions\unixActions\10.2.0.3.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Actions\w32OcxRegActions JDEdwardsE910\OneWorld Client Install\Stage\Actions\w32OcxRegActions\10.2.0.1.0 JDEdwardsE910\OneWorld Client Install\Stage\Actions\w32OcxRegActions\10.2.0.1.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Actions\w32RegActions JDEdwardsE910\OneWorld Client Install\Stage\Actions\w32RegActions\10.2.0.1.0 JDEdwardsE910\OneWorld Client Install\Stage\Actions\w32RegActions\10.2.0.1.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Actions\wingeneralActions JDEdwardsE910\OneWorld Client Install\Stage\Actions\wingeneralActions\10.2.0.1.0 JDEdwardsE910\OneWorld Client Install\Stage\Actions\wingeneralActions\10.2.0.1.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Components JDEdwardsE910\OneWorld Client Install\Stage\Components\com.e1.devclient.top JDEdwardsE910\OneWorld Client Install\Stage\Components\com.e1.devclient.top\1.0.0.0.0 JDEdwardsE910\OneWorld Client Install\Stage\Components\com.e1.devclient.top\1.0.0.0.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Components\com.e1.devclient.top\1.0.0.0.0\1\DataFiles JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.jdk JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.jdk\1.6.0.21.51 JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.jdk\1.6.0.21.51\1 JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.jdk\1.6.0.21.51\1\DataFiles JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.jre JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.jre\1.5.0.11.0 JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.jre\1.5.0.11.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.jre\1.5.0.11.0\1\DataFiles JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.opatch JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.opatch\11.2.0.0.2 JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.opatch\11.2.0.0.2\1 JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.opatch\11.2.0.0.2\1\DataFiles JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.oui JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.oui\11.2.0.2.0 JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.oui\11.2.0.2.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.oui.core JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.oui.core\11.2.0.2.0 JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.oui.core\11.2.0.2.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.oui.core\11.2.0.2.0\1\DataFiles JDEdwardsE910\OneWorld Client Install\Stage\Dialogs JDEdwardsE910\OneWorld Client Install\Stage\Dialogs\e1Dialogs JDEdwardsE910\OneWorld Client Install\Stage\Dialogs\e1Dialogs\10.2.0.1.0 JDEdwardsE910\OneWorld Client Install\Stage\Dialogs\e1Dialogs\10.2.0.1.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Dialogs\standardDialogs JDEdwardsE910\OneWorld Client Install\Stage\Dialogs\standardDialogs\10.2.0.1.0 JDEdwardsE910\OneWorld Client Install\Stage\Dialogs\standardDialogs\10.2.0.1.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Disk1 JDEdwardsE910\OneWorld Client Install\Stage\Disk1\stage JDEdwardsE910\OneWorld Client Install\Stage\ext JDEdwardsE910\OneWorld Client Install\Stage\ext\jlib JDEdwardsE910\OneWorld Client Install\Stage\ext\lib JDEdwardsE910\OneWorld Client Install\Stage\globalvariables JDEdwardsE910\OneWorld Client Install\Stage\Queries JDEdwardsE910\OneWorld Client Install\Stage\Queries\areasQueries JDEdwardsE910\OneWorld Client Install\Stage\Queries\areasQueries\10.2.0.1.0 JDEdwardsE910\OneWorld Client Install\Stage\Queries\areasQueries\10.2.0.1.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Queries\dbQueries JDEdwardsE910\OneWorld Client Install\Stage\Queries\dbQueries\10.1.0.2.0 JDEdwardsE910\OneWorld Client Install\Stage\Queries\dbQueries\10.1.0.2.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1DBQueries JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1FileQueries JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1FileQueries\10.2.0.3.0 JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1FileQueries\10.2.0.3.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1GeneralQueries JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1GeneralQueries\10.2.0.3.0 JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1GeneralQueries\10.2.0.3.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1ISeriesQueries JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1ISeriesQueries\10.2.0.3.0 JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1ISeriesQueries\10.2.0.3.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1PackageQueries JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1PackageQueries\10.2.0.3.0 JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1PackageQueries\10.2.0.3.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Queries\fileQueries JDEdwardsE910\OneWorld Client Install\Stage\Queries\fileQueries\10.1.0.3.0 JDEdwardsE910\OneWorld Client Install\Stage\Queries\fileQueries\10.1.0.3.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Queries\generalQueries JDEdwardsE910\OneWorld Client Install\Stage\Queries\generalQueries\10.2.0.2.0 JDEdwardsE910\OneWorld Client Install\Stage\Queries\generalQueries\10.2.0.2.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Queries\netQueries JDEdwardsE910\OneWorld Client Install\Stage\Queries\netQueries\10.2.0.2.0 JDEdwardsE910\OneWorld Client Install\Stage\Queries\netQueries\10.2.0.2.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Queries\NtServicesQueries JDEdwardsE910\OneWorld Client Install\Stage\Queries\NtServicesQueries\10.2.0.3.0 JDEdwardsE910\OneWorld Client Install\Stage\Queries\NtServicesQueries\10.2.0.3.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Queries\rgsQueries JDEdwardsE910\OneWorld Client Install\Stage\Queries\rgsQueries\10.1.0.3.0 JDEdwardsE910\OneWorld Client Install\Stage\Queries\rgsQueries\10.1.0.3.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Queries\unixQueries JDEdwardsE910\OneWorld Client Install\Stage\Queries\unixQueries\10.1.0.2.0 JDEdwardsE910\OneWorld Client Install\Stage\Queries\unixQueries\10.1.0.2.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Queries\w32RegQueries JDEdwardsE910\OneWorld Client Install\Stage\Queries\w32RegQueries\10.2.0.1.0 JDEdwardsE910\OneWorld Client Install\Stage\Queries\w32RegQueries\10.2.0.1.0\1 JDEdwardsE910\OneWorld Client Install\Stage\Queries\WindowsGeneralQueries JDEdwardsE910\OneWorld Client Install\Stage\Queries\WindowsGeneralQueries\10.2.0.1.0 JDEdwardsE910\OneWorld Client Install\Stage\Queries\WindowsGeneralQueries\10.2.0.1.0\1 JDEdwardsE910\OneWorld Client Install\Stage\shiphomeinfo JDEdwardsE910\OneWorld Client Install\Stage\shiphomeinfo\summary JDEdwardsE910\OneWorld Client Install\ThirdParty JDEdwardsE910\OneWorld Client Install\ThirdParty\BPMBroker JDEdwardsE910\OneWorld Client Install\ThirdParty\ORACLE JDEdwardsE910\OneWorld Client Install\ThirdParty\VSRunTime JDEdwardsE910\OneWorld Client Install\ThirdParty\WebDevFeature JDEdwardsE910\OneWorld Client Install\ThirdParty\WebDevFeature\H4A7 JDEdwardsE910\OneWorld Client Install\ThirdParty\WebDevFeature\OH4A JDEdwardsE910\OPatch JDEdwardsE910\OPatch\crs JDEdwardsE910\OPatch\docs JDEdwardsE910\OPatch\fmw JDEdwardsE910\OPatch\jlib JDEdwardsE910\OPatch\ocm JDEdwardsE910\OPatch\ocm\generic.zip JDEdwardsE910\OPatch\opatchprereqs JDEdwardsE910\OPatch\opatchprereqs\opatch JDEdwardsE910\OPatch\opatchprereqs\oui JDEdwardsE910\oui JDEdwardsE910\oui\bin JDEdwardsE910\oui\bin\resource JDEdwardsE910\oui\instImages JDEdwardsE910\oui\jlib JDEdwardsE910\oui\jlib\lib JDEdwardsE910\oui\lib JDEdwardsE910\oui\lib\win32 JDEdwardsE910\oui\schema JDEdwardsE910\package_inf JDEdwardsE910\package_inf\Feature_inf JDEdwardsE910\Planner JDEdwardsE910\Planner\bin32 JDEdwardsE910\Planner\bin32 JDEdwardsE910\Planner\data JDEdwardsE910\Planner\include JDEdwardsE910\Planner\ini JDEdwardsE910\Planner\ini\sbf JDEdwardsE910\Planner\java JDEdwardsE910\Planner\java\sbfjars JDEdwardsE910\Planner\lib32 JDEdwardsE910\Planner\make JDEdwardsE910\Planner\obj JDEdwardsE910\Planner\res JDEdwardsE910\Planner\res\actionbmps JDEdwardsE910\Planner\res\AVI Files JDEdwardsE910\Planner\res\FormLines JDEdwardsE910\Planner\res\Icons JDEdwardsE910\Planner\res\images JDEdwardsE910\Planner\res\treebmps JDEdwardsE910\Planner\source JDEdwardsE910\Planner\spec JDEdwardsE910\Planner\spec\runtimeCache JDEdwardsE910\Planner\work JDEdwardsE910\Planner\work\sbf JDEdwardsE910\SolutionExplorer JDEdwardsE910\SolutionExplorer\+ Concept To Opportunity JDEdwardsE910\SolutionExplorer\+ Concept To Opportunity\CustomWorks JDEdwardsE910\SolutionExplorer\+ Concept To Opportunity\CustomWorks\Object Model Documentation JDEdwardsE910\SolutionExplorer\+ Consumption To Reorder JDEdwardsE910\SolutionExplorer\+ Demand To Available JDEdwardsE910\SolutionExplorer\+ Demand To Available\MakeProduct JDEdwardsE910\SolutionExplorer\+ Demand To Available\MakeProduct\Make Product Interview Questions_files JDEdwardsE910\SolutionExplorer\+ Demand To Available\PlanSupplyChain JDEdwardsE910\SolutionExplorer\+ Implementation Approach JDEdwardsE910\SolutionExplorer\+ Manage The Business JDEdwardsE910\SolutionExplorer\+ Manage The Business\Activity Scripts JDEdwardsE910\SolutionExplorer\+ Manage The Business\Activity Scripts\Account and Report Script_files JDEdwardsE910\SolutionExplorer\+ Manage The Business\Activity Scripts\Process Payments Script_files JDEdwardsE910\SolutionExplorer\+ Manage The Business\Activity Scripts\Process Receivables Script_files JDEdwardsE910\SolutionExplorer\+ Manage The Business\Interview Questions JDEdwardsE910\SolutionExplorer\+ Manage The Business\Interview Questions\Account and Report Questions_files JDEdwardsE910\SolutionExplorer\+ Manage The Business\Interview Questions\Process Payments Questions_files JDEdwardsE910\SolutionExplorer\+ Manage The Business\Interview Questions\Process Receivables Questions_files JDEdwardsE910\SolutionExplorer\+ Order To Cash JDEdwardsE910\SolutionExplorer\+ Order To Cash\_vti_cnf JDEdwardsE910\SolutionExplorer\+ Procure To Pay JDEdwardsE910\SolutionExplorer\+ Procure To Pay\_vti_cnf JDEdwardsE910\SolutionExplorer\+ Procure To Pay\CRP Scripts procure to pay_files JDEdwardsE910\SolutionExplorer\+ Procure To Pay\CRP Scripts procure to pay_files\_vti_cnf JDEdwardsE910\SolutionExplorer\BM944072060102 JDEdwardsE910\SolutionExplorer\BMPxxxxxxxxxxxx JDEdwardsE910\SolutionExplorer\JDExxxxxx JDEdwardsE910\system JDEdwardsE910\system\bin32 JDEdwardsE910\system\bin32\debug JDEdwardsE910\system\Classes JDEdwardsE910\system\Classes\buildDeployBSSV JDEdwardsE910\system\Classes\ConsumerWEBXML JDEdwardsE910\system\Classes\endorsed JDEdwardsE910\system\Classes\lib JDEdwardsE910\system\Classes\Orchestration JDEdwardsE910\system\Classes\samples JDEdwardsE910\system\Generator JDEdwardsE910\system\IDA JDEdwardsE910\system\include JDEdwardsE910\system\include\connector JDEdwardsE910\system\include\database JDEdwardsE910\system\include\jdesaw JDEdwardsE910\system\include\Metadata JDEdwardsE910\system\include\netmessaging JDEdwardsE910\system\include\perfmon JDEdwardsE910\system\include\workflow JDEdwardsE910\system\include\xml JDEdwardsE910\system\includev JDEdwardsE910\system\includev\unicode JDEdwardsE910\system\JDK JDEdwardsE910\system\JRE JDEdwardsE910\system\lib32 JDEdwardsE910\system\libv32 JDEdwardsE910\system\Locale JDEdwardsE910\system\Locale\Iconv JDEdwardsE910\system\Locale\Uconvtab JDEdwardsE910\system\Locale\xml JDEdwardsE910\system\Locale\xml\hpux JDEdwardsE910\system\Locale\xml\NT JDEdwardsE910\system\Locale\xml\Solaris JDEdwardsE910\system\Mobile JDEdwardsE910\system\Mobile\Authentication JDEdwardsE910\system\Mobile\JrnlSQLCode JDEdwardsE910\system\Mobile\WebLogic JDEdwardsE910\system\OC4J JDEdwardsE910\system\OC4J\ant JDEdwardsE910\system\OC4J\ant\bin JDEdwardsE910\system\OC4J\ant\etc JDEdwardsE910\system\OC4J\ant\etc\checkstyle JDEdwardsE910\system\OC4J\ant\lib JDEdwardsE910\system\OC4J\bin JDEdwardsE910\system\OC4J\diagnostics JDEdwardsE910\system\OC4J\diagnostics\config JDEdwardsE910\system\OC4J\diagnostics\lib JDEdwardsE910\system\OC4J\j2ee JDEdwardsE910\system\OC4J\j2ee\home JDEdwardsE910\system\OC4J\j2ee\utilities JDEdwardsE910\system\OC4J\javacache JDEdwardsE910\system\OC4J\javacache\lib JDEdwardsE910\system\OC4J\javavm JDEdwardsE910\system\OC4J\javavm\lib JDEdwardsE910\system\OC4J\jdbc JDEdwardsE910\system\OC4J\jdbc\lib JDEdwardsE910\system\OC4J\jlib JDEdwardsE910\system\OC4J\lib JDEdwardsE910\system\OC4J\opmn JDEdwardsE910\system\OC4J\opmn\lib JDEdwardsE910\system\OC4J\rdbms JDEdwardsE910\system\OC4J\rdbms\jlib JDEdwardsE910\system\OC4J\sqlj JDEdwardsE910\system\OC4J\sqlj\jlib JDEdwardsE910\system\OC4J\toplink JDEdwardsE910\system\OC4J\toplink\jlib JDEdwardsE910\system\OC4J\webservices JDEdwardsE910\system\OC4J\webservices\lib JDEdwardsE910\system\OC4J\xqs JDEdwardsE910\system\OC4J\xqs\lib JDEdwardsE910\system\OC4J\xqs\tools JDEdwardsE910\system\resource JDEdwardsE910\system\resource\cmap JDEdwardsE910\system\resource\truetype JDEdwardsE910\systemcomp JDEdwardsE910\ThirdParty JDEdwardsE910\ThirdParty\BPMBroker
The following table outlines the Release 9.1 software directory structure for the Release 9.1 language installation image. You must understand this directory structure to help you verify that the language was installed correctly.
| Directory Name | Definition |
\LANGUAGE |
Name of language for JD Edwards EnterpriseOne language installation. |
\Helps |
Language help files. |
\SolutionExplorer |
Solution Explorer language files. |
\SolutionExplorer\PLANNER |
Planner path code. |
\SolutionExplorer\PLANNER\DATA |
Language database. |
After you run Host Workbench, you should have the following Enterprise Server directory structure, where c:\ is an example of the installation drive.
c:\JDEdwards\E910\DV910 |
c:\JDEdwards\E910\PrintQueue |
c:\JDEdwards\E910\system |
c:\JDEdwards\E910\DV910\bin32 |
c:\JDEdwards\E910\DV910\data |
c:\JDEdwards\E910\DV910\include |
Production business function include (.h) files. |
c:\JDEdwards\E910\DV910\lib32 |
Import libraries for business functions. |
c:\JDEdwards\E910\DV910\make |
c:\JDEdwards\E910\DV910\obj |
Object code for business functions. |
c:\JDEdwards\E910\DV910\res |
c:\JDEdwards\E910\DV910\source |
Business function source. |
c:\JDEdwards\E910\DV910\spec |
Replicated local objects. |
c:\JDEdwards\E910\DV910\work |
c:\JDEdwards\E910\DV910\res\AVI Files |
c:\JDEdwards\E910\DV910\res\FormLines |
c:\JDEdwards\E910\DV910\res\Icons |
c:\JDEdwards\E910\DV910\res\images |
c:\JDEdwards\E910\DV910\res\treebmps |
c:\JDEdwards\E910\system\Bin32 |
System executables. |
c:\JDEdwards\E910\system\Classes |
c:\JDEdwards\E910\system\Explorer |
c:\JDEdwards\E910\system\Generator |
c:\JDEdwards\E910\system\Include |
System include files. |
c:\JDEdwards\E910\system\IncludeV |
c:\JDEdwards\E910\system\Lib32 |
c:\JDEdwards\E910\system\Libv32 |
c:\JDEdwards\E910\system\Locale |
c:\JDEdwards\E910\system\Models |
c:\JDEdwards\E910\system\Resource |
c:\JDEdwards\E910\packages\PD910FA |
c:\JDEdwards\E910\packages\PD910FA\bin32 |
c:\JDEdwards\E910\packages\PD910FA\include |
c:\JDEdwards\E910\packages\PD910FA\obj |
c:\JDEdwards\E910\packages\PD910FA\source |
c:\JDEdwards\E910\packages\PD910FA\spec |
c:\JDEdwards\E910\packages\PD910FA\obj\CAEC |
c:\JDEdwards\E910\packages\PD910FA\obj\CALLBSFN |
c:\JDEdwards\E910\packages\PD910FA\obj\CCONVERT |
c:\JDEdwards\E910\packages\PD910FA\obj\CCORE |
c:\JDEdwards\E910\packages\PD910FA\obj\CCRIN |
c:\JDEdwards\E910\packages\PD910FA\obj\CDBASE |
c:\JDEdwards\E910\packages\PD910FA\obj\CDDICT |
c:\JDEdwards\E910\packages\PD910FA\obj\CDESIGN |
c:\JDEdwards\E910\packages\PD910FA\obj\CDIST |
c:\JDEdwards\E910\packages\PD910FA\obj\CDMDSCH |
c:\JDEdwards\E910\packages\PD910FA\obj\CEPM |
c:\JDEdwards\E910\packages\PD910FA\obj\CFIN |
c:\JDEdwards\E910\packages\PD910FA\obj\CFND |
c:\JDEdwards\E910\packages\PD910FA\obj\CHRM |
c:\JDEdwards\E910\packages\PD910FA\obj\CINSTALL |
c:\JDEdwards\E910\packages\PD910FA\obj\CINV |
c:\JDEdwards\E910\packages\PD910FA\obj\CLOC |
c:\JDEdwards\E910\packages\PD910FA\obj\CLOG |
c:\JDEdwards\E910\packages\PD910FA\obj\CMFG |
c:\JDEdwards\E910\packages\PD910FA\obj\CMFGBASE |
c:\JDEdwards\E910\packages\PD910FA\obj\COBJLIB |
c:\JDEdwards\E910\packages\PD910FA\obj\COPBASE |
c:\JDEdwards\E910\packages\PD910FA\obj\CPAY |
c:\JDEdwards\E910\packages\PD910FA\obj\CRES |
c:\JDEdwards\E910\packages\PD910FA\obj\CRUNTIME |
c:\JDEdwards\E910\packages\PD910FA\obj\CSALES |
c:\JDEdwards\E910\packages\PD910FA\obj\CTC |
c:\JDEdwards\E910\packages\PD910FA\obj\CTOOL |
c:\JDEdwards\E910\packages\PD910FA\obj\CTRAN |
c:\JDEdwards\E910\packages\PD910FA\obj\CTRANS |
c:\JDEdwards\E910\packages\PD910FA\obj\CWARE |
c:\JDEdwards\E910\packages\PD910FA\obj\CWRKFLOW |
c:\JDEdwards\E910\packages\PD910FA\obj\JDBTRG1 |
c:\JDEdwards\E910\packages\PD910FA\obj\JDBTRG2 |
c:\JDEdwards\E910\packages\PD910FA\obj\JDBTRG3 |
c:\JDEdwards\E910\packages\PD910FA\source\CAEC |
c:\JDEdwards\E910\packages\PD910FA\source\CALLBSFN |
c:\JDEdwards\E910\packages\PD910FA\source\CCONVERT |
c:\JDEdwards\E910\packages\PD910FA\source\CCORE |
c:\JDEdwards\E910\packages\PD910FA\source\CCRIN |
c:\JDEdwards\E910\packages\PD910FA\source\CDBASE |
c:\JDEdwards\E910\packages\PD910FA\source\CDDICT |
c:\JDEdwards\E910\packages\PD910FA\source\CDESIGN |
c:\JDEdwards\E910\packages\PD910FA\source\CDIST |
c:\JDEdwards\E910\packages\PD910FA\source\CDMDSCH |
c:\JDEdwards\E910\packages\PD910FA\source\CEPM |
c:\JDEdwards\E910\packages\PD910FA\source\CFIN |
c:\JDEdwards\E910\packages\PD910FA\source\CFND |
c:\JDEdwards\E910\packages\PD910FA\source\CHRM |
c:\JDEdwards\E910\packages\PD910FA\source\CINSTALL |
c:\JDEdwards\E910\packages\PD910FA\source\CINV |
c:\JDEdwards\E910\packages\PD910FA\source\CLOC |
c:\JDEdwards\E910\packages\PD910FA\source\CLOG |
c:\JDEdwards\E910\packages\PD910FA\source\CMFG |
c:\JDEdwards\E910\packages\PD910FA\source\CMFGBASE |
c:\JDEdwards\E910\packages\PD910FA\source\COBJLIB |
c:\JDEdwards\E910\packages\PD910FA\source\COPBASE |
c:\JDEdwards\E910\packages\PD910FA\source\CPAY |
c:\JDEdwards\E910\packages\PD910FA\source\CRES |
c:\JDEdwards\E910\packages\PD910FA\source\CRUNTIME |
c:\JDEdwards\E910\packages\PD910FA\source\CSALES |
c:\JDEdwards\E910\packages\PD910FA\source\CTC |
c:\JDEdwards\E910\packages\PD910FA\source\CTOOL |
c:\JDEdwards\E910\packages\PD910FA\source\CTRAN |
c:\JDEdwards\E910\packages\PD910FA\source\CTRANS |
c:\JDEdwards\E910\packages\PD910FA\source\CWARE |
c:\JDEdwards\E910\packages\PD910FA\source\CWRKFLOW |
c:\JDEdwards\E910\packages\PD910FA\source\JDBTRG1 |
c:\JDEdwards\E910\packages\PD910FA\source\JDBTRG2 |
c:\JDEdwards\E910\packages\PD910FA\source\JDBTRG3 |
c:\JDEdwards\E910\system\Generator\WEB-INF |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes |
c:\JDEdwards\E910\system\Generator\WEB-INF\lib |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\com |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\bpm |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\bpmweb |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\jas |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\oneworld |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\printqueuecenter |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\redirector |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\services |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\system |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\taskexplorer |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\util |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\workflow |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\xts |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\beans |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\behaviorcom |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\cache |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\datatypes |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\exception |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\gui |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\imagegenerator |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\logging |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\owsecurity |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\resource |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\spec |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\timer |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\util |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\webgui |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\gui\explorer |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\gui\util |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\logging\log4j |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\logging\test |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\util\cache |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\util\ftp |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\util\smtp |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\base\util\threadpool |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\bpm\utils |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\bpmweb\broker |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\bpmweb\Handlers |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\bpmweb\Util |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\base |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\explorer |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\jdb |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\services |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\application |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\as400 |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\businessview |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\condensed |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\config |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\datacache |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\formatter |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\logical |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\oracle |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\physical |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\resultset |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\retry |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\security |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\signon |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\sql |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\sqlserver |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\standalone |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\transaction |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\transform |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\trigger |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\udb |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\impl\usage |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\services\base |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\services\bootstrap |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\services\company |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\services\ocm |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\services\role |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\services\security |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\services\serviceobj |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\services\spec |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\database\services\udc |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\jas\bsfnplugin |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\jas\exception |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\jas\net |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\jas\res |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\jas\security |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\jas\services |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\jas\transaction |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\jas\services\anonuser |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\jas\services\env |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\jas\services\userpref |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\oneworld\ifc |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\oneworld\owportal |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\oneworld\owportal\beans |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\oneworld\owportal\components |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\oneworld\owportal\js |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\oneworld\owportal\util |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\oneworld\owportal\components\envcheck |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\oneworld\owportal\components\hr |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\oneworld\owportal\components\importer |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\oneworld\owportal\components\linkCenter |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\oneworld\owportal\components\reportcenter |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\oneworld\owportal\components\sarsystem |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\oneworld\owportal\components\webcheck |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\oneworld\owportal\components\workcenter |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\oneworld\owportal\components\reportcenter\client |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\beans |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\client |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\components |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\datahandler |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\defaults |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\gui |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\js |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\unittest |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\util |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\client\JdeTreeControl |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\components\envcheck |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\components\importer |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\components\linkcenter |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\components\login |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\components\rss |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\components\search |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\components\webcheck |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\components\importer\upload |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\util\cache |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\portal\util\gui |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\base |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\engine |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\er |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\event |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\generator |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\interfac |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\model |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\swing |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\virtual |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\com\jdedward\runtime\vtcomponents |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\engine\form |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\engine\version |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\er\erobjects |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\generator\engine |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\generator\jniinclude |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\generator\model |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\generator\view |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\model\form |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\model\grid |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\virtual\input |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\virtual\output |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\virtual\xapi |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\vtcomponent\form |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\vtcomponent\grid |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\runtime\vtcomponent\version |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\services\login |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\services\objectlookup |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\services\login\display |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\system\kernel |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\system\lib |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\system\net |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\system\security |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\system\xml |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\system\lib\cache |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\system\security\as400 |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\system\security\db |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\system\security\proxy |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\system\xml\test |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\taskexplorer\actions |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\taskexplorer\db |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\taskexplorer\filters |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\taskexplorer\gui |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\taskexplorer\launchers |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\taskexplorer\gui\tagext |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\util\imagegenerator |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\workflow\DesignEngine |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\workflow\monitoring |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\workflow\util |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\xts\serverproxy |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\xts\test |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\xts\xtse |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\xts\xtsm |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\xts\xtsr |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\xts\xtse\adapters |
c:\JDEdwards\E910\system\Generator\WEB-INF\classes\comc:\JDEdwards\xts\xtsr\adapters |
c:\JDEdwards\E910\system\IncludeV\unicode |
c:\JDEdwards\E910\system\Locale\Iconv |
c:\JDEdwards\E910\system\Locale\Uconvtab |
c:\JDEdwards\E910\system\Locale\Xml |
c:\JDEdwards\E910\system\Resource\cidfont |
c:\JDEdwards\E910\system\Resource\cmap |
c:\JDEdwards\E910\system\Resource\encoding |
c:\JDEdwards\E910\system\Resource\font |
c:\JDEdwards\E910\system\Resource\iccprofile |
c:\JDEdwards\E910\system\Resource\truetype |
c:\JDEdwards\E910\system\Resource\font\pfm |
After you install Release 9.1 installation on a Workstation, you should have the following local directory structure:
\E910\E910\Log\E910\output\E910\packages\E910\PD910\E910\PrintQueue\E910\queues\E910\system\E910\PD910\bin32\E910\PD910\spec\E910\PD910\spec\JDE\E910\queues\control\E910\queues\outqueue\E910\system\bin32\E910\system\Classes\E910\system\include\E910\system\includev\E910\system\lib32\E910\system\libv32\E910\system\locale\E910\system\resource\E910\system\Classes\samples\E910\system\includev\unicode\E910\system\locale\iconv\E910\system\locale\uconvtab\E910\system\locale\xml\E910\system\resource\cidfont\E910\system\resource\cmap\E910\system\resource\encoding\E910\system\resource\font\E910\system\resource\iccprofile\E910\system\resource\truetype\E910\system\resource\font\pfm
