19 Understanding JD Edwards EnterpriseOne Directory Structures
The charts in this section illustrate the directory structures for JD Edwards EnterpriseOne on the Deployment Server, the Enterprise Server, and Workstations. You must understand these directory structures to verify that you installed or upgraded Release 9.1 correctly.
Assuming you use the recommended shared path names, the process does not delete or overlay your previous release. You will have the Release 9.1 directories in addition to your existing directories.
The recommended configuration is for all business functions to be mapped to the server. The only exception to this rule is a client development environment in which case all business functions should be mapped locally.
This chapter discusses:
19.1 Deployment Server Directory Structure
After you install Release 9.1 on the Deployment Server, you should have the following directory structure:
JDEdwardsE910\CD Templates
JDEdwardsE910\CD Templates\Esu & Asu
JDEdwardsE910\CD Templates\Esu & Asu\planner
JDEdwardsE910\CD Templates\Esu & Asu\planner\Package
JDEdwardsE910\CD Templates\Esu & Asu\planner\Package\PKGNAME
JDEdwardsE910\cfgtoollogs
JDEdwardsE910\cfgtoollogs\cfgfw
JDEdwardsE910\cfgtoollogs\oui
JDEdwardsE910\Change Assistant
JDEdwardsE910\Change Assistant\Downloads
JDEdwardsE910\Change Assistant\Downloads\CopiedESUs
JDEdwardsE910\Change Assistant\Downloads\ESUs
JDEdwardsE910\Change Assistant\Downloads\logs
JDEdwardsE910\Change Assistant\SupportAssistant
JDEdwardsE910\client
JDEdwardsE910\database
JDEdwardsE910\database\Oracle
JDEdwardsE910\database\SQL
JDEdwardsE910\database\UDB
JDEdwardsE910\diagnostics
JDEdwardsE910\diagnostics\config
JDEdwardsE910\diagnostics\config\registration
JDEdwardsE910\path_code
JDEdwardsE910\path_code\bin32
JDEdwardsE910\path_code\include
JDEdwardsE910\path_code\ini
JDEdwardsE910\path_code\ini\sbf
JDEdwardsE910\path_code\java
JDEdwardsE910\path_code\java\sbfjars
JDEdwardsE910\path_code\lib32
JDEdwardsE910\path_code\make
JDEdwardsE910\path_code\obj
JDEdwardsE910\path_code\PACKAGE
JDEdwardsE910\path_code\PACKAGE\DATA
JDEdwardsE910\path_code\PACKAGE\DATACOMP
JDEdwardsE910\path_code\PACKAGE\path_codeFA
JDEdwardsE910\path_code\PACKAGE\path_codeFA\bin32
JDEdwardsE910\path_code\PACKAGE\path_codeFA\include
JDEdwardsE910\path_code\PACKAGE\path_codeFA\java
JDEdwardsE910\path_code\PACKAGE\path_codeFA\java\sbfjars
JDEdwardsE910\path_code\PACKAGE\path_codeFA\lib32
JDEdwardsE910\path_code\PACKAGE\path_codeFA\make
JDEdwardsE910\path_code\PACKAGE\path_codeFA\obj
JDEdwardsE910\path_code\PACKAGE\path_codeFA\res
JDEdwardsE910\path_code\PACKAGE\path_codeFA\res\actionbmps
JDEdwardsE910\path_code\PACKAGE\path_codeFA\res\AVI Files
JDEdwardsE910\path_code\PACKAGE\path_codeFA\res\FormLines
JDEdwardsE910\path_code\PACKAGE\path_codeFA\res\Icons
JDEdwardsE910\path_code\PACKAGE\path_codeFA\res\images
JDEdwardsE910\path_code\PACKAGE\path_codeFA\res\treebmps
JDEdwardsE910\path_code\PACKAGE\path_codeFA\source
JDEdwardsE910\path_code\PACKAGE\path_codeFA\spec
JDEdwardsE910\path_code\PACKAGE\path_codeFA\spec\runtimeCache
JDEdwardsE910\path_code\PACKAGE\path_codeFA\work
JDEdwardsE910\path_code\PACKAGE\path_codeFA\work\sbf
JDEdwardsE910\path_code\PACKAGE\path_codeFA\work\sbf\oas
JDEdwardsE910\path_code\PACKAGE\path_codeFA\work\sbf\oas\META-INF
JDEdwardsE910\path_code\res
JDEdwardsE910\path_code\res\actionbmps
JDEdwardsE910\path_code\res\AVI Files
JDEdwardsE910\path_code\res\FormLines
JDEdwardsE910\path_code\res\Icons
JDEdwardsE910\path_code\res\images
JDEdwardsE910\path_code\res\treebmps
JDEdwardsE910\path_code\source
JDEdwardsE910\path_code\spec
JDEdwardsE910\path_code\spec\runtimeCache
JDEdwardsE910\path_code\work
JDEdwardsE910\path_code\work\sbf
JDEdwardsE910\path_code\work\sbf\oas
JDEdwardsE910\path_code\work\sbf\oas\META-INF
In the preceding paths, the path_code portion is DV910, PD910, PS910, or PY910.
The PACKAGE\path_code directory contains the same sub-structure as this parent directory:
JDEdwards910\path_code
JDEdwardsE910\E1InstallerLibs
JDEdwardsE910\install
JDEdwardsE910\inventory
JDEdwardsE910\inventory\Actions21
JDEdwardsE910\inventory\Actions21\e1FileActions
JDEdwardsE910\inventory\Actions21\e1FileActions\10.2.0.3.0
JDEdwardsE910\inventory\Actions21\e1GeneralActions
JDEdwardsE910\inventory\Actions21\e1PackageActions
JDEdwardsE910\inventory\Actions21\e1PackageActions\10.2.0.3.0
JDEdwardsE910\inventory\Actions21\fileActions
JDEdwardsE910\inventory\Actions21\fileActions\11.2.0.2.0
JDEdwardsE910\inventory\Actions21\generalActions
JDEdwardsE910\inventory\Actions21\generalActions\10.2.0.9.0
JDEdwardsE910\inventory\Actions21\ntServicesActions
JDEdwardsE910\inventory\Actions21\ntServicesActions\10.2.0.6.0
JDEdwardsE910\inventory\Actions21\ntw32FoldersActions
JDEdwardsE910\inventory\Actions21\ntw32FoldersActions\10.2.0.3.0
JDEdwardsE910\inventory\Actions21\SpawnActions
JDEdwardsE910\inventory\Actions21\SpawnActions\10.1.0.3.4
JDEdwardsE910\inventory\Actions21\w32RegActions
JDEdwardsE910\inventory\Actions21\w32RegActions\10.2.0.1.0
JDEdwardsE910\inventory\backup
JDEdwardsE910\inventory\checkpoints
JDEdwardsE910\inventory\Clone
JDEdwardsE910\inventory\Components21
JDEdwardsE910\inventory\Components21\com.e1.bpm
JDEdwardsE910\inventory\Components21\com.e1.bpm\1.0.0.0.0
JDEdwardsE910\inventory\Components21\com.e1.bpm\1.0.0.0.0\resources
JDEdwardsE910\inventory\Components21\com.e1.deployment.data
JDEdwardsE910\inventory\Components21\com.e1.deployment.data\1.0.0.0.0
JDEdwardsE910\inventory\Components21\com.e1.deployment.data\1.0.0.0.0\resources
JDEdwardsE910\inventory\Components21\com.e1.deployment.development
JDEdwardsE910\inventory\Components21\com.e1.deployment.development\9.1.0.0.0
JDEdwardsE910\inventory\Components21\com.e1.deployment.development\9.1.0.0.0\resources
JDEdwardsE910\inventory\Components21\com.e1.deployment.e1files
JDEdwardsE910\inventory\Components21\com.e1.deployment.e1files\9.1.0.0.0
JDEdwardsE910\inventory\Components21\com.e1.deployment.e1files\9.1.0.0.0\resources
JDEdwardsE910\inventory\Components21\com.e1.deployment.oh4a
JDEdwardsE910\inventory\Components21\com.e1.deployment.oh4a\1.0.0.0.0
JDEdwardsE910\inventory\Components21\com.e1.deployment.oh4a\1.0.0.0.0\resources
JDEdwardsE910\inventory\Components21\com.e1.deployment.planner
JDEdwardsE910\inventory\Components21\com.e1.deployment.planner\9.1.0.0.0
JDEdwardsE910\inventory\Components21\com.e1.deployment.planner\9.1.0.0.0\resources
JDEdwardsE910\inventory\Components21\com.e1.deployment.top
JDEdwardsE910\inventory\Components21\com.e1.deployment.top\9.1.0.0.0
JDEdwardsE910\inventory\Components21\com.e1.deployment.top\9.1.0.0.0\resources
JDEdwardsE910\inventory\Components21\com.e1.features
JDEdwardsE910\inventory\Components21\com.e1.features\1.0.0.0.0
JDEdwardsE910\inventory\Components21\com.e1.features\1.0.0.0.0\resources
JDEdwardsE910\inventory\Components21\com.e1.foundation
JDEdwardsE910\inventory\Components21\com.e1.foundation\1.0.0.0.0
JDEdwardsE910\inventory\Components21\com.e1.foundation\1.0.0.0.0\resources
JDEdwardsE910\inventory\Components21\oracle.jdk
JDEdwardsE910\inventory\Components21\oracle.jdk\1.6.0.21.51
JDEdwardsE910\inventory\Components21\oracle.jdk\1.6.0.21.51\resources
JDEdwardsE910\inventory\Components21\oracle.swd.opatch
JDEdwardsE910\inventory\Components21\oracle.swd.opatch\11.2.0.0.2
JDEdwardsE910\inventory\Components21\oracle.swd.opatch\11.2.0.0.2\resources
JDEdwardsE910\inventory\Components21\oracle.swd.oui
JDEdwardsE910\inventory\Components21\oracle.swd.oui\11.2.0.2.0
JDEdwardsE910\inventory\Components21\oracle.swd.oui\11.2.0.2.0\resources
JDEdwardsE910\inventory\Components21\oracle.swd.oui.core
JDEdwardsE910\inventory\Components21\oracle.swd.oui.core\11.2.0.2.0
JDEdwardsE910\inventory\Components21\oracle.swd.oui.core\11.2.0.2.0\resources
JDEdwardsE910\inventory\ContentsXML
JDEdwardsE910\inventory\ContentsXML\ConfigXML
JDEdwardsE910\inventory\Dialogs21
JDEdwardsE910\inventory\Dialogs21\standardDialogs
JDEdwardsE910\inventory\Dialogs21\standardDialogs\10.2.0.1.0
JDEdwardsE910\inventory\Queries21
JDEdwardsE910\inventory\Queries21\areasQueries
JDEdwardsE910\inventory\Queries21\areasQueries\10.2.0.1.0
JDEdwardsE910\inventory\Queries21\e1DBQueries
JDEdwardsE910\inventory\Queries21\e1DBQueries\10.2.0.3.0
JDEdwardsE910\inventory\Queries21\e1FileQueries
JDEdwardsE910\inventory\Queries21\e1FileQueries\10.2.0.3.0
JDEdwardsE910\inventory\Queries21\e1GeneralQueries
JDEdwardsE910\inventory\Queries21\e1GeneralQueries\10.2.0.3.0
JDEdwardsE910\inventory\Queries21\e1PackageQueries
JDEdwardsE910\inventory\Queries21\e1PackageQueries\10.2.0.3.0
JDEdwardsE910\inventory\Queries21\fileQueries
JDEdwardsE910\inventory\Queries21\fileQueries\10.1.0.3.0
JDEdwardsE910\inventory\Queries21\generalQueries
JDEdwardsE910\inventory\Queries21\generalQueries\10.2.0.2.0
JDEdwardsE910\inventory\Queries21\w32RegQueries
JDEdwardsE910\inventory\Queries21\w32RegQueries\10.2.0.1.0
JDEdwardsE910\inventory\Queries21\WindowsGeneralQueries
JDEdwardsE910\inventory\Queries21\WindowsGeneralQueries\10.2.0.1.0
JDEdwardsE910\inventory\Scripts
JDEdwardsE910\inventory\Scripts\ext
JDEdwardsE910\inventory\Scripts\ext\jlib
JDEdwardsE910\inventory\Scripts\ext\lib
JDEdwardsE910\inventory\Templates
JDEdwardsE910\inventory\Templates\OPatch
JDEdwardsE910\inventory\Templates\oui
JDEdwardsE910\inventory\Templates\oui\bin
JDEdwardsE910\inventory\Templates\system
JDEdwardsE910\inventory\Templates\system\OC4J
JDEdwardsE910\inventory\Templates\system\OC4J\j2ee
JDEdwardsE910\inventory\Templates\system\OC4J\j2ee\home
JDEdwardsE910\inventory\Templates\system\OC4J\j2ee\home\applications
JDEdwardsE910\inventory\Templates\system\OC4J\j2ee\home\applications\webclient.ear
JDEdwardsE910\inventory\Templates\system\OC4J\j2ee\home\applications\webclient.ear\webclient
JDEdwardsE910\inventory\Templates\system\OC4J\j2ee\home\applications\webclient.ear\webclient\WEB-INF
JDEdwardsE910\inventory\Templates\system\OC4J\j2ee\home\applications\webclient.ear\webclient\WEB-INF\classes
JDEdwardsE910\jdk
JDEdwardsE910\jdk\bin
JDEdwardsE910\jdk\include
JDEdwardsE910\jdk\include\win32
JDEdwardsE910\jdk\jre
JDEdwardsE910\jdk\jre\bin
JDEdwardsE910\jdk\jre\bin\client
JDEdwardsE910\jdk\jre\bin\new_plugin
JDEdwardsE910\jdk\jre\bin\server
JDEdwardsE910\jdk\jre\lib
JDEdwardsE910\jdk\jre\lib\applet
JDEdwardsE910\jdk\jre\lib\audio
JDEdwardsE910\jdk\jre\lib\cmm
JDEdwardsE910\jdk\jre\lib\deploy
JDEdwardsE910\jdk\jre\lib\deploy\jqs
JDEdwardsE910\jdk\jre\lib\deploy\jqs\ff
JDEdwardsE910\jdk\jre\lib\deploy\jqs\ff\chrome
JDEdwardsE910\jdk\jre\lib\deploy\jqs\ff\chrome\content
JDEdwardsE910\jdk\jre\lib\deploy\jqs\ie
JDEdwardsE910\jdk\jre\lib\ext
JDEdwardsE910\jdk\jre\lib\fonts
JDEdwardsE910\jdk\jre\lib\i386
JDEdwardsE910\jdk\jre\lib\im
JDEdwardsE910\jdk\jre\lib\images
JDEdwardsE910\jdk\jre\lib\images\cursors
JDEdwardsE910\jdk\jre\lib\management
JDEdwardsE910\jdk\jre\lib\security
JDEdwardsE910\jdk\jre\lib\servicetag
JDEdwardsE910\jdk\jre\lib\zi
JDEdwardsE910\jdk\jre\lib\zi\Africa
JDEdwardsE910\jdk\jre\lib\zi\America
JDEdwardsE910\jdk\jre\lib\zi\America\Argentina
JDEdwardsE910\jdk\jre\lib\zi\America\Indiana
JDEdwardsE910\jdk\jre\lib\zi\America\Kentucky
JDEdwardsE910\jdk\jre\lib\zi\America\North_Dakota
JDEdwardsE910\jdk\jre\lib\zi\Antarctica
JDEdwardsE910\jdk\jre\lib\zi\Asia
JDEdwardsE910\jdk\jre\lib\zi\Atlantic
JDEdwardsE910\jdk\jre\lib\zi\Australia
JDEdwardsE910\jdk\jre\lib\zi\Etc
JDEdwardsE910\jdk\jre\lib\zi\Europe
JDEdwardsE910\jdk\jre\lib\zi\Indian
JDEdwardsE910\jdk\jre\lib\zi\Pacific
JDEdwardsE910\jdk\jre\lib\zi\SystemV
JDEdwardsE910\jdk\lib
JDEdwardsE910\jdk\lib\visualvm
JDEdwardsE910\jdk\lib\visualvm\etc
JDEdwardsE910\jdk\lib\visualvm\platform11
JDEdwardsE910\jdk\lib\visualvm\platform11\config
JDEdwardsE910\jdk\lib\visualvm\platform11\config\ModuleAutoDeps
JDEdwardsE910\jdk\lib\visualvm\platform11\config\Modules
JDEdwardsE910\jdk\lib\visualvm\platform11\core
JDEdwardsE910\jdk\lib\visualvm\platform11\core\locale
JDEdwardsE910\jdk\lib\visualvm\platform11\docs
JDEdwardsE910\jdk\lib\visualvm\platform11\lib
JDEdwardsE910\jdk\lib\visualvm\platform11\lib\locale
JDEdwardsE910\jdk\lib\visualvm\platform11\modules
JDEdwardsE910\jdk\lib\visualvm\platform11\modules\ext
JDEdwardsE910\jdk\lib\visualvm\platform11\modules\ext\locale
JDEdwardsE910\jdk\lib\visualvm\platform11\modules\locale
JDEdwardsE910\jdk\lib\visualvm\platform11\update_tracking
JDEdwardsE910\jdk\lib\visualvm\profiler3
JDEdwardsE910\jdk\lib\visualvm\profiler3\config
JDEdwardsE910\jdk\lib\visualvm\profiler3\config\Modules
JDEdwardsE910\jdk\lib\visualvm\profiler3\lib
JDEdwardsE910\jdk\lib\visualvm\profiler3\lib\deployed
JDEdwardsE910\jdk\lib\visualvm\profiler3\lib\deployed\jdk15
JDEdwardsE910\jdk\lib\visualvm\profiler3\lib\deployed\jdk15\windows
JDEdwardsE910\jdk\lib\visualvm\profiler3\lib\deployed\jdk16
JDEdwardsE910\jdk\lib\visualvm\profiler3\lib\deployed\jdk16\windows
JDEdwardsE910\jdk\lib\visualvm\profiler3\lib\locale
JDEdwardsE910\jdk\lib\visualvm\profiler3\modules
JDEdwardsE910\jdk\lib\visualvm\profiler3\modules\locale
JDEdwardsE910\jdk\lib\visualvm\profiler3\update_tracking
JDEdwardsE910\jdk\lib\visualvm\visualvm
JDEdwardsE910\jdk\lib\visualvm\visualvm\config
JDEdwardsE910\jdk\lib\visualvm\visualvm\config\Modules
JDEdwardsE910\jdk\lib\visualvm\visualvm\core
JDEdwardsE910\jdk\lib\visualvm\visualvm\core\locale
JDEdwardsE910\jdk\lib\visualvm\visualvm\modules
JDEdwardsE910\jdk\lib\visualvm\visualvm\modules\locale
JDEdwardsE910\jdk\lib\visualvm\visualvm\update_tracking
JDEdwardsE910\mediaobj
JDEdwardsE910\mediaobj\Composer
JDEdwardsE910\mediaobj\Composer\html
JDEdwardsE910\mediaobj\Composer\html\Images
JDEdwardsE910\mediaobj\Composer\Visio
JDEdwardsE910\mediaobj\ComposerCBT
JDEdwardsE910\mediaobj\ComposerCBT\Order_to_Cash
JDEdwardsE910\mediaobj\ComposerCBT\Procure_to_Pay
JDEdwardsE910\mediaobj\ComposerCBT\ShowMe_Eapxxxxx
JDEdwardsE910\mediaobj\ComposerCBT\ShowMe_Eapxxxxx\graphics
JDEdwardsE910\mediaobj\ComposerCBT\ShowMe_Earxxxxx
JDEdwardsE910\mediaobj\ComposerCBT\ShowMe_Earxxxxx\graphics
JDEdwardsE910\mediaobj\ComposerCBT\ShowMe_Ecoxxxxx
JDEdwardsE910\mediaobj\ComposerCBT\ShowMe_Ecoxxxxx\graphics
JDEdwardsE910\mediaobj\ComposerCBT\Standard_Graphics
JDEdwardsE910\mediaobj\Distribution
JDEdwardsE910\mediaobj\Financials
JDEdwardsE910\mediaobj\htmlupload
JDEdwardsE910\mediaobj\Human Resources
JDEdwardsE910\mediaobj\Manufacturing
JDEdwardsE910\mediaobj\MISC
JDEdwardsE910\mediaobj\Misc Animations
JDEdwardsE910\mediaobj\Misc Images
JDEdwardsE910\mediaobj\Oleque
JDEdwardsE910\mediaobj\OMW
JDEdwardsE910\mediaobj\SelfService
JDEdwardsE910\mediaobj\Text
JDEdwardsE910\MISC
JDEdwardsE910\OneWorld Client Install
JDEdwardsE910\OneWorld Client Install\install
JDEdwardsE910\OneWorld Client Install\install\access
JDEdwardsE910\OneWorld Client Install\install\access\jdk
JDEdwardsE910\OneWorld Client Install\install\access\jdk\jre
JDEdwardsE910\OneWorld Client Install\install\access\jdk\jre\bin
JDEdwardsE910\OneWorld Client Install\install\access\jdk\jre\lib
JDEdwardsE910\OneWorld Client Install\install\access\jdk\jre\lib\ext
JDEdwardsE910\OneWorld Client Install\install\resource
JDEdwardsE910\OneWorld Client Install\Misc
JDEdwardsE910\OneWorld Client Install\Misc\SBFServer
JDEdwardsE910\OneWorld Client Install\Stage
JDEdwardsE910\OneWorld Client Install\Stage\Actions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\dbActions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\dbActions\10.1.0.2.0
JDEdwardsE910\OneWorld Client Install\Stage\Actions\dbActions\10.1.0.2.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1FileActions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1FileActions\10.2.0.3.0
JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1FileActions\10.2.0.3.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1GeneralActions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1GeneralActions\10.2.0.3.0
JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1GeneralActions\10.2.0.3.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1ISeriesActions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1ISeriesActions\10.2.0.3.0
JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1ISeriesActions\10.2.0.3.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1PackageActions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\e1PackageActions\10.2.0.3.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Actions\fileActions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\fileActions\11.2.0.2.0
JDEdwardsE910\OneWorld Client Install\Stage\Actions\fileActions\11.2.0.2.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Actions\generalActions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\generalActions\10.2.0.9.0
JDEdwardsE910\OneWorld Client Install\Stage\Actions\generalActions\10.2.0.9.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Actions\jarActions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\jarActions\10.2.0.0.0
JDEdwardsE910\OneWorld Client Install\Stage\Actions\jarActions\10.2.0.0.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Actions\launchPadActions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\launchPadActions\10.1.0.2.0
JDEdwardsE910\OneWorld Client Install\Stage\Actions\launchPadActions\10.1.0.2.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Actions\ntServicesActions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\ntServicesActions\10.2.0.6.0
JDEdwardsE910\OneWorld Client Install\Stage\Actions\ntServicesActions\10.2.0.6.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Actions\ntw32FoldersActions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\ntw32FoldersActions\10.2.0.3.0
JDEdwardsE910\OneWorld Client Install\Stage\Actions\ntw32FoldersActions\10.2.0.3.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Actions\rgsActions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\rgsActions\10.1.0.3.0
JDEdwardsE910\OneWorld Client Install\Stage\Actions\rgsActions\10.1.0.3.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Actions\SpawnActions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\SpawnActions\10.1.0.3.4
JDEdwardsE910\OneWorld Client Install\Stage\Actions\SpawnActions\10.1.0.3.4\1
JDEdwardsE910\OneWorld Client Install\Stage\Actions\unixActions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\unixActions\10.2.0.3.0
JDEdwardsE910\OneWorld Client Install\Stage\Actions\unixActions\10.2.0.3.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Actions\w32OcxRegActions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\w32OcxRegActions\10.2.0.1.0
JDEdwardsE910\OneWorld Client Install\Stage\Actions\w32OcxRegActions\10.2.0.1.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Actions\w32RegActions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\w32RegActions\10.2.0.1.0
JDEdwardsE910\OneWorld Client Install\Stage\Actions\w32RegActions\10.2.0.1.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Actions\wingeneralActions
JDEdwardsE910\OneWorld Client Install\Stage\Actions\wingeneralActions\10.2.0.1.0
JDEdwardsE910\OneWorld Client Install\Stage\Actions\wingeneralActions\10.2.0.1.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Components
JDEdwardsE910\OneWorld Client Install\Stage\Components\com.e1.devclient.top
JDEdwardsE910\OneWorld Client Install\Stage\Components\com.e1.devclient.top\1.0.0.0.0
JDEdwardsE910\OneWorld Client Install\Stage\Components\com.e1.devclient.top\1.0.0.0.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Components\com.e1.devclient.top\1.0.0.0.0\1\DataFiles
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.jdk
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.jdk\1.6.0.21.51
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.jdk\1.6.0.21.51\1
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.jdk\1.6.0.21.51\1\DataFiles
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.jre
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.jre\1.5.0.11.0
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.jre\1.5.0.11.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.jre\1.5.0.11.0\1\DataFiles
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.opatch
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.opatch\11.2.0.0.2
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.opatch\11.2.0.0.2\1
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.opatch\11.2.0.0.2\1\DataFiles
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.oui
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.oui\11.2.0.2.0
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.oui\11.2.0.2.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.oui.core
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.oui.core\11.2.0.2.0
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.oui.core\11.2.0.2.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Components\oracle.swd.oui.core\11.2.0.2.0\1\DataFiles
JDEdwardsE910\OneWorld Client Install\Stage\Dialogs
JDEdwardsE910\OneWorld Client Install\Stage\Dialogs\e1Dialogs
JDEdwardsE910\OneWorld Client Install\Stage\Dialogs\e1Dialogs\10.2.0.1.0
JDEdwardsE910\OneWorld Client Install\Stage\Dialogs\e1Dialogs\10.2.0.1.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Dialogs\standardDialogs
JDEdwardsE910\OneWorld Client Install\Stage\Dialogs\standardDialogs\10.2.0.1.0
JDEdwardsE910\OneWorld Client Install\Stage\Dialogs\standardDialogs\10.2.0.1.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Disk1
JDEdwardsE910\OneWorld Client Install\Stage\Disk1\stage
JDEdwardsE910\OneWorld Client Install\Stage\ext
JDEdwardsE910\OneWorld Client Install\Stage\ext\jlib
JDEdwardsE910\OneWorld Client Install\Stage\ext\lib
JDEdwardsE910\OneWorld Client Install\Stage\globalvariables
JDEdwardsE910\OneWorld Client Install\Stage\Queries
JDEdwardsE910\OneWorld Client Install\Stage\Queries\areasQueries
JDEdwardsE910\OneWorld Client Install\Stage\Queries\areasQueries\10.2.0.1.0
JDEdwardsE910\OneWorld Client Install\Stage\Queries\areasQueries\10.2.0.1.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Queries\dbQueries
JDEdwardsE910\OneWorld Client Install\Stage\Queries\dbQueries\10.1.0.2.0
JDEdwardsE910\OneWorld Client Install\Stage\Queries\dbQueries\10.1.0.2.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1DBQueries
JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1FileQueries
JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1FileQueries\10.2.0.3.0
JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1FileQueries\10.2.0.3.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1GeneralQueries
JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1GeneralQueries\10.2.0.3.0
JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1GeneralQueries\10.2.0.3.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1ISeriesQueries
JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1ISeriesQueries\10.2.0.3.0
JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1ISeriesQueries\10.2.0.3.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1PackageQueries
JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1PackageQueries\10.2.0.3.0
JDEdwardsE910\OneWorld Client Install\Stage\Queries\e1PackageQueries\10.2.0.3.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Queries\fileQueries
JDEdwardsE910\OneWorld Client Install\Stage\Queries\fileQueries\10.1.0.3.0
JDEdwardsE910\OneWorld Client Install\Stage\Queries\fileQueries\10.1.0.3.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Queries\generalQueries
JDEdwardsE910\OneWorld Client Install\Stage\Queries\generalQueries\10.2.0.2.0
JDEdwardsE910\OneWorld Client Install\Stage\Queries\generalQueries\10.2.0.2.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Queries\netQueries
JDEdwardsE910\OneWorld Client Install\Stage\Queries\netQueries\10.2.0.2.0
JDEdwardsE910\OneWorld Client Install\Stage\Queries\netQueries\10.2.0.2.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Queries\NtServicesQueries
JDEdwardsE910\OneWorld Client Install\Stage\Queries\NtServicesQueries\10.2.0.3.0
JDEdwardsE910\OneWorld Client Install\Stage\Queries\NtServicesQueries\10.2.0.3.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Queries\rgsQueries
JDEdwardsE910\OneWorld Client Install\Stage\Queries\rgsQueries\10.1.0.3.0
JDEdwardsE910\OneWorld Client Install\Stage\Queries\rgsQueries\10.1.0.3.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Queries\unixQueries
JDEdwardsE910\OneWorld Client Install\Stage\Queries\unixQueries\10.1.0.2.0
JDEdwardsE910\OneWorld Client Install\Stage\Queries\unixQueries\10.1.0.2.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Queries\w32RegQueries
JDEdwardsE910\OneWorld Client Install\Stage\Queries\w32RegQueries\10.2.0.1.0
JDEdwardsE910\OneWorld Client Install\Stage\Queries\w32RegQueries\10.2.0.1.0\1
JDEdwardsE910\OneWorld Client Install\Stage\Queries\WindowsGeneralQueries
JDEdwardsE910\OneWorld Client Install\Stage\Queries\WindowsGeneralQueries\10.2.0.1.0
JDEdwardsE910\OneWorld Client Install\Stage\Queries\WindowsGeneralQueries\10.2.0.1.0\1
JDEdwardsE910\OneWorld Client Install\Stage\shiphomeinfo
JDEdwardsE910\OneWorld Client Install\Stage\shiphomeinfo\summary
JDEdwardsE910\OneWorld Client Install\ThirdParty
JDEdwardsE910\OneWorld Client Install\ThirdParty\BPMBroker
JDEdwardsE910\OneWorld Client Install\ThirdParty\ORACLE
JDEdwardsE910\OneWorld Client Install\ThirdParty\VSRunTime
JDEdwardsE910\OneWorld Client Install\ThirdParty\WebDevFeature
JDEdwardsE910\OneWorld Client Install\ThirdParty\WebDevFeature\H4A7
JDEdwardsE910\OneWorld Client Install\ThirdParty\WebDevFeature\OH4A
JDEdwardsE910\OPatch
JDEdwardsE910\OPatch\crs
JDEdwardsE910\OPatch\docs
JDEdwardsE910\OPatch\fmw
JDEdwardsE910\OPatch\jlib
JDEdwardsE910\OPatch\ocm
JDEdwardsE910\OPatch\ocm\generic.zip
JDEdwardsE910\OPatch\opatchprereqs
JDEdwardsE910\OPatch\opatchprereqs\opatch
JDEdwardsE910\OPatch\opatchprereqs\oui
JDEdwardsE910\oui
JDEdwardsE910\oui\bin
JDEdwardsE910\oui\bin\resource
JDEdwardsE910\oui\instImages
JDEdwardsE910\oui\jlib
JDEdwardsE910\oui\jlib\lib
JDEdwardsE910\oui\lib
JDEdwardsE910\oui\lib\win32
JDEdwardsE910\oui\schema
JDEdwardsE910\package_inf
JDEdwardsE910\package_inf\Feature_inf
JDEdwardsE910\Planner
JDEdwardsE910\Planner\bin32
JDEdwardsE910\Planner\data
JDEdwardsE910\Planner\include
JDEdwardsE910\Planner\ini
JDEdwardsE910\Planner\ini\sbf
JDEdwardsE910\Planner\java
JDEdwardsE910\Planner\java\sbfjars
JDEdwardsE910\Planner\lib32
JDEdwardsE910\Planner\make
JDEdwardsE910\Planner\obj
JDEdwardsE910\Planner\res
JDEdwardsE910\Planner\res\actionbmps
JDEdwardsE910\Planner\res\AVI Files
JDEdwardsE910\Planner\res\FormLines
JDEdwardsE910\Planner\res\Icons
JDEdwardsE910\Planner\res\images
JDEdwardsE910\Planner\res\treebmps
JDEdwardsE910\Planner\source
JDEdwardsE910\Planner\spec
JDEdwardsE910\Planner\spec\runtimeCache
JDEdwardsE910\Planner\work
JDEdwardsE910\Planner\work\sbf
JDEdwardsE910\SolutionExplorer
JDEdwardsE910\SolutionExplorer\+ Concept To Opportunity
JDEdwardsE910\SolutionExplorer\+ Concept To Opportunity\CustomWorks
JDEdwardsE910\SolutionExplorer\+ Concept To Opportunity\CustomWorks\Object Model Documentation
JDEdwardsE910\SolutionExplorer\+ Consumption To Reorder
JDEdwardsE910\SolutionExplorer\+ Demand To Available
JDEdwardsE910\SolutionExplorer\+ Demand To Available\MakeProduct
JDEdwardsE910\SolutionExplorer\+ Demand To Available\MakeProduct\Make Product Interview Questions_files
JDEdwardsE910\SolutionExplorer\+ Demand To Available\PlanSupplyChain
JDEdwardsE910\SolutionExplorer\+ Implementation Approach
JDEdwardsE910\SolutionExplorer\+ Manage The Business
JDEdwardsE910\SolutionExplorer\+ Manage The Business\Activity Scripts
JDEdwardsE910\SolutionExplorer\+ Manage The Business\Activity Scripts\Account and Report Script_files
JDEdwardsE910\SolutionExplorer\+ Manage The Business\Activity Scripts\Process Payments Script_files
JDEdwardsE910\SolutionExplorer\+ Manage The Business\Activity Scripts\Process Receivables Script_files
JDEdwardsE910\SolutionExplorer\+ Manage The Business\Interview Questions
JDEdwardsE910\SolutionExplorer\+ Manage The Business\Interview Questions\Account and Report Questions_files
JDEdwardsE910\SolutionExplorer\+ Manage The Business\Interview Questions\Process Payments Questions_files
JDEdwardsE910\SolutionExplorer\+ Manage The Business\Interview Questions\Process Receivables Questions_files
JDEdwardsE910\SolutionExplorer\+ Order To Cash
JDEdwardsE910\SolutionExplorer\+ Order To Cash\_vti_cnf
JDEdwardsE910\SolutionExplorer\+ Procure To Pay
JDEdwardsE910\SolutionExplorer\+ Procure To Pay\_vti_cnf
JDEdwardsE910\SolutionExplorer\+ Procure To Pay\CRP Scripts procure to pay_files
JDEdwardsE910\SolutionExplorer\+ Procure To Pay\CRP Scripts procure to pay_files\_vti_cnf
JDEdwardsE910\SolutionExplorer\BM944072060102
JDEdwardsE910\SolutionExplorer\BMPxxxxxxxxxxxx
JDEdwardsE910\SolutionExplorer\JDExxxxxx
JDEdwardsE910\system
JDEdwardsE910\system\bin32
JDEdwardsE910\system\bin32\debug
JDEdwardsE910\system\Classes
JDEdwardsE910\system\Classes\buildDeployBSSV
JDEdwardsE910\system\Classes\ConsumerWEBXML
JDEdwardsE910\system\Classes\endorsed
JDEdwardsE910\system\Classes\lib
JDEdwardsE910\system\Classes\Orchestration
JDEdwardsE910\system\Classes\samples
JDEdwardsE910\system\Generator
JDEdwardsE910\system\IDA
JDEdwardsE910\system\include
JDEdwardsE910\system\include\connector
JDEdwardsE910\system\include\database
JDEdwardsE910\system\include\jdesaw
JDEdwardsE910\system\include\Metadata
JDEdwardsE910\system\include\netmessaging
JDEdwardsE910\system\include\perfmon
JDEdwardsE910\system\include\workflow
JDEdwardsE910\system\include\xml
JDEdwardsE910\system\includev
JDEdwardsE910\system\includev\unicode
JDEdwardsE910\system\JDK
JDEdwardsE910\system\JRE
JDEdwardsE910\system\lib32
JDEdwardsE910\system\libv32
JDEdwardsE910\system\Locale
JDEdwardsE910\system\Locale\Iconv
JDEdwardsE910\system\Locale\Uconvtab
JDEdwardsE910\system\Locale\xml
JDEdwardsE910\system\Locale\xml\hpux
JDEdwardsE910\system\Locale\xml\NT
JDEdwardsE910\system\Locale\xml\Solaris
JDEdwardsE910\system\Mobile
JDEdwardsE910\system\Mobile\Authentication
JDEdwardsE910\system\Mobile\JrnlSQLCode
JDEdwardsE910\system\Mobile\WebLogic
JDEdwardsE910\system\OC4J
JDEdwardsE910\system\OC4J\ant
JDEdwardsE910\system\OC4J\ant\bin
JDEdwardsE910\system\OC4J\ant\etc
JDEdwardsE910\system\OC4J\ant\etc\checkstyle
JDEdwardsE910\system\OC4J\ant\lib
JDEdwardsE910\system\OC4J\bin
JDEdwardsE910\system\OC4J\diagnostics
JDEdwardsE910\system\OC4J\diagnostics\config
JDEdwardsE910\system\OC4J\diagnostics\lib
JDEdwardsE910\system\OC4J\j2ee
JDEdwardsE910\system\OC4J\j2ee\home
JDEdwardsE910\system\OC4J\j2ee\utilities
JDEdwardsE910\system\OC4J\javacache
JDEdwardsE910\system\OC4J\javacache\lib
JDEdwardsE910\system\OC4J\javavm
JDEdwardsE910\system\OC4J\javavm\lib
JDEdwardsE910\system\OC4J\jdbc
JDEdwardsE910\system\OC4J\jdbc\lib
JDEdwardsE910\system\OC4J\jlib
JDEdwardsE910\system\OC4J\lib
JDEdwardsE910\system\OC4J\opmn
JDEdwardsE910\system\OC4J\opmn\lib
JDEdwardsE910\system\OC4J\rdbms
JDEdwardsE910\system\OC4J\rdbms\jlib
JDEdwardsE910\system\OC4J\sqlj
JDEdwardsE910\system\OC4J\sqlj\jlib
JDEdwardsE910\system\OC4J\toplink
JDEdwardsE910\system\OC4J\toplink\jlib
JDEdwardsE910\system\OC4J\webservices
JDEdwardsE910\system\OC4J\webservices\lib
JDEdwardsE910\system\OC4J\xqs
JDEdwardsE910\system\OC4J\xqs\lib
JDEdwardsE910\system\OC4J\xqs\tools
JDEdwardsE910\system\resource
JDEdwardsE910\system\resource\cmap
JDEdwardsE910\system\resource\truetype
JDEdwardsE910\systemcomp
JDEdwardsE910\ThirdParty
JDEdwardsE910\ThirdParty\BPMBroker
19.2 Language Directory Structure
The following table outlines the Release 9.1 software directory structure for the Release 9.1 language installation image. You must understand this directory structure to help you verify that the language was installed correctly.
Directory Name Definition
\LANGUAGE Name of language for JD Edwards EnterpriseOne language installation.
\Helps Language help files.
\SolutionExplorer Solution Explorer language files.
\SolutionExplorer\PLANNER Planner path code.
\SolutionExplorer\PLANNER\DATA Language database.
19.3 Enterprise Server Directory Structure for UNIX-based Enterprise Servers
After you run Host Workbench, you should have the following Enterprise Server directory structure, where /u01 is an example of the installation mount point.
/u01/jdedwardsppack/e910/DV910
/u01/jdedwardsppack/e910/PrintQueue
/u01/jdedwardsppack/e910/system
/u01/jdedwardsppack/e910/DV910/bin32
/u01/jdedwardsppack/e910/DV910/data
/u01/jdedwardsppack/e910/DV910/include Production business function include (.h) files.
/u01/jdedwardsppack/e910/DV910/lib32 Import libraries for business functions.
/u01/jdedwardsppack/e910/DV910/make
/u01/jdedwardsppack/e910/DV910/obj Object code for business functions.
/u01/jdedwardsppack/e910/DV910/res
/u01/jdedwardsppack/e910/DV910/source Business function source.
/u01/jdedwardsppack/e910/DV910/spec Replicated local objects.
/u01/jdedwardsppack/e910/DV910/work
/u01/jdedwardsppack/e910/DV910/res/AVI Files
/u01/jdedwardsppack/e910/DV910/res/FormLines
/u01/jdedwardsppack/e910/DV910/res/Icons
/u01/jdedwardsppack/e910/DV910/res/images
/u01/jdedwardsppack/e910/DV910/res/treebmps
/u01/jdedwardsppack/e910/system/Bin32 System executables.
/u01/jdedwardsppack/e910/system/Classes
/u01/jdedwardsppack/e910/system/Explorer
/u01/jdedwardsppack/e910/system/Generator
/u01/jdedwardsppack/e910/system/Include System include files.
/u01/jdedwardsppack/e910/system/IncludeV
/u01/jdedwardsppack/e910/system/Lib32
/u01/jdedwardsppack/e910/system/Libv32
/u01/jdedwardsppack/e910/system/Locale
/u01/jdedwardsppack/e910/system/Models
/u01/jdedwardsppack/e910/system/Resource
/u01/jdedwardsppack/e910/packages/PD910FA
/u01/jdedwardsppack/e910/packages/PD910FA/bin32
/u01/jdedwardsppack/e910/packages/PD910FA/include
/u01/jdedwardsppack/e910/packages/PD910FA/obj
/u01/jdedwardsppack/e910/packages/PD910FA/source
/u01/jdedwardsppack/e910/packages/PD910FA/spec
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CAEC
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CALLBSFN
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CCONVERT
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CCORE
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CCRIN
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CDBASE
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CDDICT
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CDESIGN
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CDIST
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CDMDSCH
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CEPM
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CFIN
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CFND
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CHRM
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CINSTALL
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CINV
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CLOC
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CLOG
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CMFG
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CMFGBASE
/u01/jdedwardsppack/e910/packages/PD910FA/obj/COBJLIB
/u01/jdedwardsppack/e910/packages/PD910FA/obj/COPBASE
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CPAY
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CRES
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CRUNTIME
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CSALES
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CTC
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CTOOL
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CTRAN
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CTRANS
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CWARE
/u01/jdedwardsppack/e910/packages/PD910FA/obj/CWRKFLOW
/u01/jdedwardsppack/e910/packages/PD910FA/obj/JDBTRG1
/u01/jdedwardsppack/e910/packages/PD910FA/obj/JDBTRG2
/u01/jdedwardsppack/e910/packages/PD910FA/obj/JDBTRG3
/u01/jdedwardsppack/e910/packages/PD910FA/source/CAEC
/u01/jdedwardsppack/e910/packages/PD910FA/source/CALLBSFN
/u01/jdedwardsppack/e910/packages/PD910FA/source/CCONVERT
/u01/jdedwardsppack/e910/packages/PD910FA/source/CCORE
/u01/jdedwardsppack/e910/packages/PD910FA/source/CCRIN
/u01/jdedwardsppack/e910/packages/PD910FA/source/CDBASE
/u01/jdedwardsppack/e910/packages/PD910FA/source/CDDICT
/u01/jdedwardsppack/e910/packages/PD910FA/source/CDESIGN
/u01/jdedwardsppack/e910/packages/PD910FA/source/CDIST
/u01/jdedwardsppack/e910/packages/PD910FA/source/CDMDSCH
/u01/jdedwardsppack/e910/packages/PD910FA/source/CEPM
/u01/jdedwardsppack/e910/packages/PD910FA/source/CFIN
/u01/jdedwardsppack/e910/packages/PD910FA/source/CFND
/u01/jdedwardsppack/e910/packages/PD910FA/source/CHRM
/u01/jdedwardsppack/e910/packages/PD910FA/source/CINSTALL
/u01/jdedwardsppack/e910/packages/PD910FA/source/CINV
/u01/jdedwardsppack/e910/packages/PD910FA/source/CLOC
/u01/jdedwardsppack/e910/packages/PD910FA/source/CLOG
/u01/jdedwardsppack/e910/packages/PD910FA/source/CMFG
/u01/jdedwardsppack/e910/packages/PD910FA/source/CMFGBASE
/u01/jdedwardsppack/e910/packages/PD910FA/source/COBJLIB
/u01/jdedwardsppack/e910/packages/PD910FA/source/COPBASE
/u01/jdedwardsppack/e910/packages/PD910FA/source/CPAY
/u01/jdedwardsppack/e910/packages/PD910FA/source/CRES
/u01/jdedwardsppack/e910/packages/PD910FA/source/CRUNTIME
/u01/jdedwardsppack/e910/packages/PD910FA/source/CSALES
/u01/jdedwardsppack/e910/packages/PD910FA/source/CTC
/u01/jdedwardsppack/e910/packages/PD910FA/source/CTOOL
/u01/jdedwardsppack/e910/packages/PD910FA/source/CTRAN
/u01/jdedwardsppack/e910/packages/PD910FA/source/CTRANS
/u01/jdedwardsppack/e910/packages/PD910FA/source/CWARE
/u01/jdedwardsppack/e910/packages/PD910FA/source/CWRKFLOW
/u01/jdedwardsppack/e910/packages/PD910FA/source/JDBTRG1
/u01/jdedwardsppack/e910/packages/PD910FA/source/JDBTRG2
/u01/jdedwardsppack/e910/packages/PD910FA/source/JDBTRG3
/u01/jdedwardsppack/e910/system/Generator/WEB-INF
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/lib
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/bpm
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/bpmweb
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/jas
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/oneworld
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/printqueuecenter
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/redirector
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/saw/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/saw
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/services
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/system
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/taskexplorer
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/util
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/workflow
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/xts
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/beans
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/behaviorcom
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/cache
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/datatypes
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/exception
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/gui
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/imagegenerator
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/logging
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/owsecurity
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/resource
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/spec
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/timer
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/util
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/webgui
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/gui/explorer
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/gui/util
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/logging/log4j
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/logging/saw
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/logging/test
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/util/cache
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/util/ftp
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/util/smtp
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/base/util/threadpool
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/bpm/utils
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/bpmweb/broker
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/bpmweb/Handlers
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/bpmweb/Util
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/base
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/explorer
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/jdb
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/services
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/application
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/as400
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/businessview
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/condensed
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/config
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/datacache
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/formatter
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/logical
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/oracle
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/physical
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/resultset
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/retry
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/security
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/signon
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/sql
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/sqlserver
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/standalone
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/transaction
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/transform
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/trigger
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/udb
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/impl/usage
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/services/base
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/services/bootstrap
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/services/company
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/services/ocm
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/services/role
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/services/security
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/services/serviceobj
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/services/spec
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/database/services/udc
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/jas/bsfnplugin
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/jas/exception
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/jas/net
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/jas/res
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/jas/security
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/jas/services
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/jas/transaction
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/jas/services/anonuser
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/jas/services/env
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/jas/services/userpref
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/oneworld/ifc
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/oneworld/owportal
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/oneworld/owportal/beans
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/oneworld/owportal/components
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/oneworld/owportal/js
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/oneworld/owportal/util
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/oneworld/owportal/components/envcheck
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/oneworld/owportal/components/hr
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/oneworld/owportal/components/importer
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/oneworld/owportal/components/linkCenter
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/oneworld/owportal/components/reportcenter
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/oneworld/owportal/components/sarsystem
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/oneworld/owportal/components/webcheck
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/oneworld/owportal/components/workcenter
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/oneworld/owportal/components/reportcenter/client
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/beans
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/client
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/components
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/datahandler
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/defaults
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/gui
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/js
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/unittest
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/util
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/client/JdeTreeControl
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/components/envcheck
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/components/importer
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/components/linkcenter
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/components/login
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/components/rss
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/components/saw
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/components/search
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/components/webcheck
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/components/importer/upload
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/util/cache
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/portal/util/gui
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/base
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/engine
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/er
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/event
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/generator
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/interfac
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/model
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/swing
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/virtual
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/jdedward/runtime/vtcomponents
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/engine/form
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/engine/version
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/er/erobjects
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/generator/engine
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/generator/jniinclude
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/generator/model
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/generator/view
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/model/form
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/model/grid
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/virtual/input
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/virtual/output
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/virtual/xapi
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/vtcomponent/form
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/vtcomponent/grid
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/runtime/vtcomponent/version
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/saw/sawagent
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/saw/sawchart
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/saw/sawcomm
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/saw/sawdb
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/saw/sawjavalog
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/saw/sawjdbj
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/saw/sawlog
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/saw/sawsuperagent
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/saw/smc
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/saw/smcgui
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/services/login
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/services/objectlookup
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/services/login/display
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/system/kernel
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/system/lib
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/system/net
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/system/security
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/system/xml
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/system/kernel/jdesaw
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/system/lib/cache
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/system/security/as400
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/system/security/db
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/system/security/proxy
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/system/xml/test
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/taskexplorer/actions
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/taskexplorer/db
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/taskexplorer/filters
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/taskexplorer/gui
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/taskexplorer/launchers
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/taskexplorer/gui/tagext
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/util/imagegenerator
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/workflow/DesignEngine
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/workflow/monitoring
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/workflow/util
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/xts/serverproxy
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/xts/test
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/xts/xtse
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/xts/xtsm
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/xts/xtsr
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/xts/xtse/adapters
/u01/jdedwardsppack/e910/system/Generator/WEB-INF/classes/com/u01/JDEdwards/xts/xtsr/adapters
/u01/jdedwardsppack/e910/system/IncludeV/unicode
/u01/jdedwardsppack/e910/system/Locale/Iconv
/u01/jdedwardsppack/e910/system/Locale/Uconvtab
/u01/jdedwardsppack/e910/system/Locale/Xml
/u01/jdedwardsppack/e910/system/Resource/cidfont
/u01/jdedwardsppack/e910/system/Resource/cmap
/u01/jdedwardsppack/e910/system/Resource/encoding
/u01/jdedwardsppack/e910/system/Resource/font
/u01/jdedwardsppack/e910/system/Resource/iccprofile
/u01/jdedwardsppack/e910/system/Resource/truetype
/u01/jdedwardsppack/e910/system/Resource/font/pfm
19.4 Workstation General Directory Structure
After you install Release 9.1 installation on a Workstation, you should have the following local directory structure:
\E910
\E910\Log
\E910\output
\E910\packages
\E910\PD910
\E910\PrintQueue
\E910\queues
\E910\system
\E910\PD910\bin32
\E910\PD910\spec
\E910\PD910\spec\JDE
\E910\queues\control
\E910\queues\outqueue
\E910\system\bin32
\E910\system\Classes
\E910\system\include
\E910\system\includev
\E910\system\lib32
\E910\system\libv32
\E910\system\locale
\E910\system\resource
\E910\system\Classes\samples
\E910\system\includev\unicode
\E910\system\locale\iconv
\E910\system\locale\uconvtab
\E910\system\locale\xml
\E910\system\resource\cidfont
\E910\system\resource\cmap
\E910\system\resource\encoding
\E910\system\resource\font
\E910\system\resource\iccprofile
\E910\system\resource\truetype
\E910\system\resource\font\pfm
