This chapter lists the major technical tables in the Release 9.1 data sources. This chapter does not list any Release 9.1 application tables. All technical media storage objects (GTxxx) are listed at the end of this chart. Many tables exist in multiple data sources. Some tables exist in data sources not noted here.
The Local - pathcode data source refers only to local databases that are path code specific. In the chart below, Local - pathcode could represent more than one data source, depending on the number of path codes you use. Pathcode is one or more of the following path codes:PY910
DV910
PS910
PD910
DEP910
The Local data source refers only to the local database on the Deployment Server, which is used by the planner environment.* Specific tables in the list below reflect language information, and contain a language preference code that is translated by JD Edwards EnterpriseOne.
Table | Data Source | Description | Purpose |
F0004D* | Control Tables | UDC - Alternate Language | Contains the User Defined Code (UDC) key, language key, and text for headers in the F0004 table. Provides UDC type descriptions for alternate languages. |
F0005D* | Control Tables | UDC - Alternate Language | Contains UDC key, language key, and text for detail in the F0005 table. Provides UDC value descriptions for alternate languages. |
F00165* | Business Data - Data Dictionary - 910Object Librarian - 910 Business Data Local Data Dictionary Local Object Librarian Local | Media Objects storage | Stores text OLE references and image references. Stores glossary text and media objects for all languages. |
F0092 | System - 910
Planner - 910 System Local |
Library List - User | Contains one record per user with initial menu, initial program, and whether to enable fast path. |
F00921* | System - 910
User Display Preferences | Contains one record per user with date format, date separator, DW prefix, and language preference. |
F00922 | System - 910
User Display Preferences Tagfile | Contains one record per user with workstation configuration name. This table is used with the F00050 table. |
F00924 | System - 910
User Install Packages | Contains one record per user for each authorized package. |
F0093 | System - 910
Library List Control | Contains a list, by user, of authorized environments. |
F0094 | System - 910
Library List Master file | Contains master file information for an environment. |
F00941 | System - 910
Environment Detail - EO | Contains one record per environment, with release and path code. |
F00942 | System - 910
Object Path Master file | Contains one record per path code with the data source for the specification files and the server path for the other development objects (.DLL, source, headers). |
F00945 | System - 910
Release Master | Contains one record per release, with the data source for system tables and the environments server path. |
F00946 | System - 910
Release Compatibility Map | Contains information used to map major release levels to determine forward and backward compatibility. |
F00948 | System - 910
Release Data Source Map | Contains information used to map a specific type of data source to a release level, such as Object Librarian, data dictionary, or versions list data sources. |
F00950 | System - 910
System Local |
Security Workbench table | Stores security attributes (one record for each user or group). |
F00960 | System - 910
System Local |
Machine/Group Identification | Stores a list of all workstations that installed Release 8.9 to scheduled packages. |
F83100* | System - 910
System Local |
Data Title | Series of definitions of data titles. Each row is the definition or specification of the date title. Provides soft coded RDA text. |
F83110* | System - 910
System Local |
Column Headings | Gives each period number an associated description. Provides soft coded RDA text. |
F9100 | Control Table | Task Master | Lists Release 8.9 tasks (Solution Explorer only). |
F9101 | Control Table | Task Relationships | Groups tasks listed in the F9100 table in logical (parent/child) tree order (ActivEra only). |
F9102 | Control Table | Task Descriptions | Provides descriptions of tasks listed in the F9100 table (ActivEra only). |
F9105 | Control Table | Variant Description | Describes the attributes of variants listed in this table. A variant performs a series of designated tasks (nodes) within a tree order defined in the F9101 table (ActivEra only). |
F9105D | Control Table | Alternate Variant Descriptions | Provides translated text for descriptions listed in the F9105 table (ActivEra only). |
F9106 | Control Table | Variant Detail | Defines which nodes (tasks) are run within a variant and the names of any tasks dynamically renamed within a variant (ActivEra only). |
F9106D | Control Table | Alternate Variant Detail Descriptions | Provides translated text for descriptions listed in the F9106 table (ActivEra only). |
F9010 | Control Table | Environment Setup Answers | |
F9020 | Control Table | ActivEra Qualifier Rules Header | Defines rule names used by ActivEra. Rules are applied to conditionally execute an individual task or task relationship (tree order). |
F9022 | Control Table | ActivEra Qualifier Rules Detail | Lists conditional statements within rules listed in the F9020 table (ActivEra only). |
F9030 | Control Table | Documentation Cross-reference | Stores indexes of HTML documents associated with specific tasks (ActivEra only). |
F9050 | Control Table | Rough-cut Answer Dependency | Defines the hierarchical means of eliminating system codes and subsequent applications which do not apply within a specified system configuration (ActivEra only). |
F91100 | System - 910 | Favorites - Relationship Properties | Categorizes business views on a parent/child format. |
F91100D* | System - 910 | Favorites - All Descriptions | Stores alternate descriptions for different languages. |
F91300 | System - 910 | Scheduled Job Master | |
F91310 | System - 910 | Scheduled Job Parameters | |
F91320 | System - 910 | Job Schedule | |
F91330 | System - 910 | Scheduled Job Override Printer Info | |
F91400 | System - 910 | Report Director Templates | Contains the design templates for reports that users can create. |
F91410 | System - 910 | Report Director Templates Sequence Items | Helps users manipulate data sequencing. |
F91420 | System - 910 | Report Director Template Smart Field Activation | Creates a list showing all data items belonging to a smart field template. |
F91430 | System - 910 | Smart Field Template Criteria | Stores a subset of selection criteria. |
F91500 | System - 910 | Application Header for Tip of the Day | Contains application names or tools names where tips reside. |
F91510 | System - 910 | Tip Details for Tip of the Day | Stores tip texts and a key to modify the sequence. |
F9200 | Data Dictionary
Data Dictionary Local |
Data Item Master | Contains the relational breakdown of data dictionary. |
F9202* | Data Dictionary
Data Field Display Text | Contains display text for each data field for language, data item, and product code reporting. Used when data items descriptions requested. Data dictionary row and column text for all languages* *
The language preference code for data dictionary applies to text only. Text includes row and column headings, a compressed description, and glossaries. |
F9203* | Data Dictionary
Data Item Alpha Descriptions | Contains alpha descriptions and compressed descriptions of data items. Used when data items descriptions requested. Similar to the F9202 table. Contains data dictionary alpha descriptions for all languages. |
F9207 | Data Dictionary
DD Error Message Information | Contains one record per error message. |
F9210 | Data Dictionary
Data Field Specifications | Contains detailed information (specifications) for each data item. This table is accessed whenever a data item needs to be identified. |
F9211 | Data Dictionary
Data Dictionary - Smart Fields | Contains information for Smart Fields. |
F9212 | Data Dictionary - 910 Data Dictionary Local | Smart Field Criteria - Setup Rules | |
F96021 | System - 910 | Software Package Build Header | Stores the detail information from the definition process of package build. |
F9603 | System - 910 | Software Package Build Header | Stores information from the assembly process of package build. |
F96210 | System - 910
System Local |
Package Build Validation Tables | |
F96211 | System - 910
System Local |
Package Build Validation Detail | |
F96215 | System - 910
Software Package Build Header History | Contains the history record of the F96021 record. It stores statuses of the package each time it is built. |
F9622 | System - 910
Software Package Build Detail | Stores the option information from the definition process of package build. Each record is either the name of the specification file, the name of a .DLL file, the name of the compression directory, or the name of an object. |
F96225 | System - 910
Software Package Build Detail History | Contains the history record of the software build program (P9622). Stores the status of the build on the operation of that record when the package is finished. |
F9631 | System - 910
Software Package Detail | Stores the detail information for the assembly process of package build. Stores the object names, foundation name, data name, or helps name. |
F9650 | System - 910
Machine Master | Holds the default information regarding all machines used by JD Edwards EnterpriseOne. |
F9651 | System - 910
Machine Detail | Holds specific information about each machine defined in the machine master table by record type. |
F9652 | System - 910
Deployment Group Header | Specifies groups that can be used by the Release 9.1 administrator for deploying packages. |
F9653 | System - 910
Deployment Group Detail Definitions | Stores the users that belong to one or more groups that were defined in the deployment header file. In addition, groups of groups can be defined here. |
F9654 | System - 910
Deployment Location Definitions | Enables definition of one or more locations for deployment. This table is used primarily in multitier deployment. |
F9660 | System - 910
Task Breaks | |
F96600 | System - 910
Deployment Features | |
F96601 | System - 910
Deployment Registry | |
F96602 | System - 910
Deployment Shortcut | |
F96603 | System - 910
Deployment Execute | |
F96604 | System - 910
Deployment Third Party | |
F96605 | System - 910
Deployment Initialization | |
F96605T | System - 910
F96606 | System - 910
Deployment File Set | |
F966071 | System - 910
Deployment ODBC Data Source | |
F966072 | System - 910
Deployment ODBC Data Source Attributes | |
F9670 | System - 910
Software Update Master Table | |
F9671 | System - 910
Software Update Detail Table | |
F96710 | System - 910
Impact Analysis Results | |
F9672 | System - 910
Software Update Pathcode Information | |
F96761 | System - 910
Software Update Object Detail | |
F967611 | System - 910
Software Update Language Table | |
F9691100 | System Local | Change Table - Favorites | Stores adds, changes, and deletes to favorites tables between releases. |
F9691400 | System Local | Change Table - Report Director Template Header | Stores adds/changes/deletes to the Report Director template header table between releases. |
F9691410 | System Local | Change Table - Report Director Template Sequence | Stores adds/changes/deletes to the Report Director Template Sequence table between releases. |
F9691420 | System Local | Change Table - Smart Field Activity | Stores adds/changes/deletes to the Smart Field Activity table between releases. |
F9691430 | System Local | Change Table - Smart Field Criteria | Stores adds/changes/deletes to the Smart Field Criteria table between releases. |
F9746 | System Local | UDC Merge table | Contains the UDC records changed or added from release to release. This table is used by the UDC merge program (R98741). |
F960004 | Control Tables - xxx Control Tables Local | UDC Type | |
F960005 | Control Tables - xxx Control Tables Local | UDC Codes | |
F9755 | Data Dictionary - 910 Data Dictionary Local | Data Item Master Changes by Release | Contains the data dictionary items changed or added from release to release. This table is used by the Data Dictionary merge program (R989200P). |
F9757 | Data Dictionary - 910 Data Dictionary Local | Data Item Alpha Description Changes by Release | Lists changes made to alpha descriptions of data items (F9203) between releases. This table is used in the data dictionary merge process. |
F9759 | Data Dictionary - 910 Data Dictionary Local | Error Message Pgm Call Changes By Release | Lists changes made to error messages (F9207) between releases. This table is used in the data dictionary merge process. |
F9760 | Data Dictionary - 910 Data Dictionary Local | Data Field Specification Changes By Release | Lists changes made to field specifications (F9210) between releases. This table is used in the data dictionary merges. |
F980011 | Central Objects - xxx Versions Local | Cross ' Reference Relationships | Lists cross-reference relationships for business views, event rules, and controls. |
F980021 | Central Objects - xxx Versions Local | Cross ' Reference Field Relationships | Lists cross-reference relationships for fields in an application. |
F98101 | System - 910
System Local |
Imaging Constants | Determines whether you are doing third-party imaging. |
F983051 | Versions - xxx Versions Local | Versions List | Contains one record per version (batch or interactive). For interactive, it stores processing option values. For batch, this table holds data selection, sequencing, and other template overrides. |
F982xx | System - 910
System Local Planner - 910 |
Series (OMW) | |
F98306* | Central Objects - xxx Versions Local | Processing Option Text | Provides processing option text for all languages. |
F9840 | Version - 910
Planner - 910 |
Installation Plan Master table | Contains general information for the installation plan with one record per plan name (description and status). |
F98401 | Version - 910
Planner - 910 |
Data Source Plan Detail table | Lists data sources for each plan, and one record per plan record per data source associated with that plan. |
F98402 | Version - 910
Planner - 910 |
Host Plan Detail table | Lists the Enterprise Server and hosts for each plan (one record per plan, per server). |
F984021 | Version - 910
Planner - 910 |
Location Plan Detail table | Contains the last location for a plan. |
F984022 | Version - 910
Planner - 910 |
Replication Plan Detail table | Stores replicated plan for remote locations, publisher, and subscriber tables. |
F98403 | Version - 910
Planner - 910 |
Environment Plan Detail table | Lists environments for each plan. Holds flags for production data, demo data, and table conversions for an upgrade. |
F984031* | Version - 910
Planner - 910 |
Language and Environment Plan Detail table | Lists language and the selected environments for each plan. |
F98404 | Version - 910
Planner - 910 |
Package Plan Detail table | Lists packages and package definitions for each environment. |
F98405 | Version - 910
Planner - 910 |
Table Conversion Scheduler | Lists table conversion information merged in Table Conversion Scheduler from Environment Planner and Table Conversion Planner. This table is similar to the F9843 table. |
F984052 | Version - 910
Planner - 910 |
Table Conversion - History Log | Stores the logs for table conversions, control table merges, and specification merges. |
F9843 | System - 910 | Table Conversion - JDE Scheduler | Contains table conversions, control table merges, and specification merges for upgrades, updates, and coexistent installations. |
F9843T | System - 910 | ||
F98511 | System - 910
Planner - 910 |
REP Data Sources by Environment | Lists default data sources by environment. This table is used during installation. |
F9860 | Object Librarian
Object Librarian Master table | Contains one record per object with description and object type. |
F9861 | Object Librarian
Object Librarian - Status Detail | Contains one record per object, per location, per path code. Each object has a server location plus locations for each person who checks it out to his machine. |
F986101 | System - 910
Server Map Planner - 910 System Local |
Object Configuration Master | Contains all data sources for tables, batch applications, and business functions that run on the server. The only data sources not controlled through this file are the system data source in Release Master and the Development data source in object path master. |
F98611 | System - 910
Data Source Master | Holds data source definitions. One record per data source with type, database, machine name, and foundation .DLL. |
F986110 | System - 910
Contains one record for each job on the server with status information. | |
F986111 | System - 910
Job Number Master | Contains the next numbers table for server jobs. |
F986113 | System - 910
Subsystem Job Master | Contains server job records, including status, location, and version. |
F986115 | System - 910
Table and Data Source Sizing table | Holds storage, sizing, and location parameters for Oracle, with some general information for all data sources. |
F986116 | System - 910
MVS table and Data Source Sizing | Holds storage, sizing, and location parameters for MVS. Similar to the F986115 table. |
F98613 | System - 910
Business View Environmental Server | Lists cached tables. |
F986150 | System - 910
System Local |
Server Transfer Package Contents | Lists objects belonging to each server package. This table is used by the server package installation process (P986150). |
F986151 | System - 910
System Local |
Server Package Transfer | Lists the servers and path codes to which a given server package will be transferred. This table is used by the server package install process (P986150). |
F986152 | System - 910
System Local |
Server Package Master | Contains the master list of all service packages. This table is used by the server package install process (P986150). |
F98616 | System - 910
System Local |
Printer | Lists the printer definitions, including logical name, physical name, and conversion program, one record per printer. |
F986161 | System - 910
System Local |
Default Printer table | Lists default printer settings by user and environment. |
F986162 | System - 910
System Local |
Paper Definition | Lists paper sizes defined for each printer, one record per printer. |
F986163 | System - 910
System Local |
Printer Capability | Lists printer capabilities (paper orientation and size, type and location of printer) for each printer, one record per printer. |
F986164 | System - 910
System Local |
Output Conversions | Lists printer output conversions defined for each printer, one record per printer. |
F986165 | System Shared | New Default Printer Table | Stores the default printer information including the user, environment, host name, printer name, and the status. |
F986167 | System - 910
System Local |
Printer Security | Reserved for future use. |
F9862 | Object Librarian
Object Librarian - Function Detail | Lists one record for each function contained in the source file. |
F9863 | Object Librarian
Object Librarian - Object Relationships | Contains one record per business function per related object. This table is used when building business functions. |
F9865 | Object Librarian
Form Information | Contains one record per interactive form, including online help information. |
F98710 | Central Objects Specifications | Table Header | Holds table-specific information for tables created in TDA (BOBSPEC). |
F98711 | Central Objects Specifications | Table Columns | Holds all column information for the table in TDA (DDCLMN). |
F98712 | Central Objects Specifications | Primary Index Header | TDA - Information pertaining to the primary index. |
F98713 | Central Objects Specifications | Primary Index Detail | TDA - All fields that make up the primary index. |
F98720 | Central Objects Specifications | Business View Specifications | Holds all business-view specific information from BDA. |
F98740 | Central Objects Specifications | Event Rules - Link | Stores header file for event rules. |
F98741 | Central Objects Specifications | Event Rules - Specification | Contains actual event rules detail for a form. |
F98743 | Central Objects Specifications | Data Structure Templates | Contains one record for each template, for example, Data Structure for Business Function. |
F98744 | Central Objects Specifications | Media Object | Contains media object text for tools. |
F98745 | Central Objects Specifications | Smart Field Named Mappings | Contains smart field named mappings. |
F98750* | Central Objects Specifications | FDA Text Information | Contains form design text for all languages for any generated application. |
F98751 | Central Objects Specifications | FDA Specification Information | Contains specifications for an application. |
F98752 | Central Objects Specifications | FDA/SVR Header Information | Contains summary information about each application. |
F98753 | Central Objects Specifications | FDA/SVR Detail Information | Contains summary information about each form for each application. |
F98760* | Central Objects Specifications | RDA Text Information | Holds records that contain the report design aid text for all languages. |
F98761 | Central Objects Specifications | RDA Specification Info | Holds records that contain report design aid setup information. |
F98762 | Central Objects Specifications | JDEBLC - Behavior Information | Contains business function specifications. |
F9882 | System - 910
Checkout Log table | Logs all transactions that take place to objects. |
F98825 | System - 910 | Package Deployment Scheduling | Contains information for deploying client packages, such as group user ID and package assignment. |
F9883 | System - 910 | Release 9.1 Network Locations table | Contains information for deploying server packages, such as package assignments. |
F9885 | System - 910
System Local |
Install Package Header | Contains one record per package. |
F9886 | System - 910
System Local |
Install Package Detail | Contains one record per package per product code or object to be included in the package. |
F9887 | System - 910
System Local |
Install Package Build History | Lists each time the package is built. |
F9888 | System - 910
Merge Log | Contains temporary message logging for merges. |
F98800D* | Control Tables | Process Master - Alternative Description | Contains multiple language information for the F98800 table. |
F98800T | Control Tables | Process Master Supplemental Information | Categorizes Composer processes. |
F98810D* | Control Tables | Activity Master - Alternative Description | Contains multiple language information for the F98810 table. |
F98810 | Control Tables | Activity Master | Contains workflow activity information. |
F98811 | Control Tables | Activity Specifications | Contains workflow activity specifications stored as event rules. |
F98830 | Control Tables | Process Activity Associations | Contains workflow activity relationships. |
F98840 | Control Tables | Organizational Structure Master | Contains the defining data for organizational models. |
F98845 | Control Tables | Organizational Structure Rule | Contains the data that ties workflows to organizational models. |
F98860 | Control Tables | Process Instance | Contains the instances of workflow processes. |
F98865 | Control Tables | Activity Instance | Contains the instances of workflow activities within processes. |
F98881 | System - 910
System - Local |
Specification Merge Logging | Contains logging information generated from the Specification Merge for upgrade, update, and the Specification Merge and Object Librarian Merge reports. |
F9889 | System - 910
System - Local |
Deployment Location Master | Lists records for each tier with system and help information. This table is used only for multitier deployment. |
F98891 | System - 910
System - Local |
Deployment Location Path Code | Lists records with packages and help information. This table is used only for multitier deployment. |
F98892 | System - 910
System - Local |
Package Deployment Scheduling | Lists scheduling information for a multitier environment. |
F98950 | Central Objects Specifications
System - Local |
User Overrides table | Contains application version information: application, version, and user who entered it. |
F98980 | System - 910
System - Local |
Font Override by Language | Lists languages with information on corresponding display fonts. |
F98BLOB | System - 910 | DB2 BLOB Support | |
F98CONST | System - 910
System - Local |
Table of Constants | Lists constants for report design aid and form design aid. |
F98DRENV | System - 910
System - Planner |
Data Replication Environment Mapping table | Determines which path codes to update for data dictionary replication. |
F98DRLOG | System - 910
Server Map System - Planner |
Data Replication Change Log | Contains one record for each replicated change. The table information is stored as a BLOB. |
F98DRPCN | System - 910
Data Replication Pending Change Notifications | Contains one record for each replicated change for each subscriber. Records are deleted as subscribers are notified. |
F98DRPUB | System - 910
System - Planner |
Data Replication Publisher | Lists definitions of published objects. |
F98DRSUB | System - 910
System - Planner |
Data Replication Subscribers | Defines each subscriber. |
F98EVDTL | System - 910
System - Local |
Event Detail file | Filters events displayed in Form Design Aid (FDA) or Universal Batch Engine (UBE) design. |
F98EVHDR | System - 910
System - Local |
Event Header file | Stores event description and event ID. This table is used for all event rules. |
F98MOQUE | System - 910
System - Local |
Media Object Queues | Contains path codes to locations of multimedia objects. |
F98OWSEC | System - 910
System - Local |
Release 9.1 Security | Contains the security tables that store the Release 9.1 user name and password for obtaining database user and password for certain data sources. |
F98TMPL | System - 910
System - Local |
Templates | |
F98VAR | System - 910
System - Local |
Table of Variables | Contains commonly used event rule variables. |
GT92002 | Data Dictionary | Data Dictionary - Glossary Information | Contains column in data dictionary with descriptions of data dictionary items. |
GT9860A | Object Librarian | Object Librarian Generic Text Structure | Contains notes for objects in the Object Librarian. |
GT9862A | Object Librarian | Business Function Notes | Contains notes for business functions. |
GT98DSA | Object Librarian | Data Structure Notes - Structure and Item | Contains notes for data structures. |
GT98DSB | Object Librarian | Data Structure Notes - Structure and Item | Contains notes for data structures. |
GT98TMPL | Object Librarian | Media Object Templates | Contains templates that can be used for any attachment. |
