This chapter discusses these data sources:
This chart lists the characteristics of the Business Data data source.
| Field | Valid Value for SQL Server |
| Data Source Name (list includes possible sources) | Business Data - PROD
Business Data - CRP Business Data - TEST Business Data - PS910 |
| Data Source Use | DB |
| Data Source Type | S |
| Database Server Name | Name of the machine where your database resides |
| Platform | NTSVR |
| Advanced Exit | Selected |
| Clustered | Blank |
| Unicode | Selected |
| Use Decimal Shift | Selected |
| Use Julian Dates | Selected |
| Support for Locking Updates | Selected |
| OCM Data Source | Blank |
| Use Table Owner | Selected |
| LOB Data Type Support | Blank |
| Object Owner ID (list includes possible owner Ids) | PRODDTA
CRPDTA TESTDTA PS910DTA |
| Database Name (list includes possible databases) | JDE_PRODUCTION
JDE_CRP JDE_DEVELOPMENT JDE_PRIST910 |
| Support for Updates | Selected |
| LOB | Blank |
This chart lists the characteristics of the Central Objects data source.
| Field | SQL Server |
| Data Source Name (list includes possible sources) | Central Objects - PD910
Central Objects - PY910 Central Objects - DV910 Central Objects - PS910 |
| Object Owner ID (list includes possible owner IDs) | PD910
PY910 DV910 PS910 |
| Library Name | Blank |
| Library List Name | Blank |
| Database Name (list includes possible databases) | JDE_PD910
JDE_PY910 JDE_PS910 JDE_DV910 |
| Platform | Platform type |
| LOB Data Source | Selected |
This chart lists the characteristics of the Control Tables data source.
| Data Source Name (list includes possible sources) | Control Tables - Prod
Control Tables - CRP Control Tables - Test Control Tables - PS910 |
| Object Owner ID (list includes possible owner IDs) | PRODCTL
CRPCTL PS910CTL TESTCTL |
This chart lists the characteristics of the Data Dictionary data source.
| Data Source Name | Data Dictionary - 910 |
| Object Owner ID | DD910 |
| Database Name | JDE910 |
| LOB Data Source | Blank |
This chart lists the characteristics of the Logic data source.
| Data Source Name | Name of the machine where your database resides |
| Data Source Use | SRN |
| Data Source Type | Blank |
| Object Owner ID | SVM910 |
| Database Name | PS910 |
| IBM i BLOB Data Source | Blank |
This chart lists the characteristics of the Object Librarian data source.
| Data Source Name | Object Librarian - 910 |
| Object Owner ID | OL910 |
This chart lists the characteristics of the Language data source, which applies to the Oracle tablespace on the Deployment Server.
| Field | Valid Value for Oracle |
| Data Source Name (list includes possible sources) | Language
Language – 910 For example, French – 910. |
| Data Source Type | N |
| Object Owner ID (list includes possible owner IDs) | Blank |
| Database Name (list includes possible databases) | Language
JDELanguage_F910 |
| Server Name | Local |
| Platform | LOCAL |
| Use Table Owner | Blank |
| Use Julian Dates | Blank |
| Use Decimal Shift | Blank |
| Support for Updates | Blank |
| IBM i BLOB Support | Blank |
This chart lists the characteristics of the Local data source, which applies to the Oracle tablespace on the Deployment Server.
| Data Source Name (list includes possible sources) | Local
JDELocal - DV910 JDELocal - PS910 JDELocal - PD910 JDELocal - PY910 |
| Object Owner ID (list includes possible owner IDs) | dbo |
| Database Name (list includes possible databases) | JDELocal
JDEPlan910 JDECTL910 JDEDD910 JDESY910 JDEVL910 JDEOL910 JDEData910 |
| Platform | LOCAL |
This chart lists the characteristics of the Server Map data source.
| Data Source Name | machinename - 910 Server Map |
| DDL Name | Blank |
| Database Name | machinename
- 910 Server Map |
| OCM Data Source | Selected |
This chart lists the characteristics of the System data source.
| Data Source Name | System - 910 |
| Object Owner ID | SY910 |
This chart lists the characteristics of the Versions data source.
| Data Source Name (list includes possible sources) | Versions - PD910
Versions - PY910 Versions - DV910 Versions - PS910 |
PY910 DV910 PS910 |
JDE_PY910 JDE_DV910 JDE_PS910 |
