23 Understanding Data Source Charts
This chapter discusses these data sources:
23.1 Business Data
This chart lists the characteristics of the Business Data data source.
Field Valid Value for Oracle
Data Source Name (list includes possible sources) Business Data - PROD
Business Data - CRP
Business Data - TEST
Business Data - PS910
Data Source Use DB
Data Source Type O
Database Server Name Name of the machine where your database resides
Platform Platform type
Advanced Exit Selected
Clustered Blank
Unicode Selected
Use Decimal Shift Selected
Use Julian Dates Selected
Support for Locking Updates Selected
OCM Data Source Blank
Use Table Owner Selected
LOB Data Type Support Selected
Object Owner ID (list includes possible owner Ids) PRODDTA
CRPDTA
TESTDTA
PS910DTA
Database Name (list includes possible databases) Connect string for the database
Support for Updates Selected
LOB Selected
23.2 Central Objects
This chart lists the characteristics of the Central Objects data source.
Field Oracle
Data Source Name (list includes possible sources) Central Objects - PROD
Central Objects - CRP
Central Objects - TEST
Central Objects - PS910
Data Source Use DB
Data Source Type O
Object Owner ID (list includes possible owner IDs) PD910
PY910
DV910
PS910
Library Name Blank
Library List Name Blank
LOB Data Source Selected
23.3 Control Tables
This chart lists the characteristics of the Control Tables data source.
Field Oracle
Data Source Name (list includes possible sources) Control Tables - Prod
Control Tables - CRP
Control Tables - Test
Control Tables - PS910
Data Source Use DB
Data Source Type O
Object Owner ID (list includes possible owner IDs) Control Tables - Prod
Library Name Blank
23.4 Data Dictionary
This chart lists the characteristics of the Data Dictionary data source.
Field Oracle
Data Source Name Data Dictionary - 910
Data Source Use DB
Data Source Type O
Object Owner ID DD910
Library Name Blank
Database Name Connect string for the database
23.5 Logic
This chart lists the characteristics of the Logic data source.
Field Oracle
Data Source Name Name of the machine where your database resides
Data Source Use SVR
Data Source Type Blank
Object Owner ID SVM910
Library Name Blank
IBM i BLOB Data Source Blank
23.6 Object Librarian
This chart lists the characteristics of the Object Librarian data source.
Data Source Name Object Librarian - 910
Data Source Use DB
Data Source Type O
Object Owner ID OL910
Library Name Blank
23.7 Language
This chart lists the characteristics of the Language data source, which applies to the Oracle tablespace on the Deployment Server.
Data Source Name (list includes possible sources) Language
Language – 910
For example, French – 910.
Data Source Use DB
Data Source Type N
Object Owner ID (list includes possible owner IDs) Blank
Library Name Blank
Database Name (list includes possible databases) Language
JDELanguage_F910
Server Name Local
Platform LOCAL
Use Table Owner Blank
Use Julian Dates Blank
Use Decimal Shift Blank
Support for Updates Blank
IBM i BLOB Support Blank
23.8 Local
This chart lists the characteristics of the Local data source, which applies to the Oracle tablespace on the Deployment Server.
Data Source Name (list includes possible sources) Local
JDELocal - DV910
JDELocal - PS910
JDELocal - PD910
JDELocal - PY910
Data Source Use DB
Data Source Type N
Object Owner ID (list includes possible owner IDs) dbo
Library Name Blank
Database Name (list includes possible databases) JDELocal
JDEPlan910
JDECTL910
JDEDD910
JDESY910
JDEVL910
JDEOL910
JDEData910
Server Name Local
Platform LOCAL
23.9 Server Map
This chart lists the characteristics of the Server Map data source.
Data Source Name machinename - 910 Server Map
Data Source Use DB
Data Source Type O
Library Name Blank
DDL Name Blank
OCM Data Source Selected
23.10 System
This chart lists the characteristics of the System data source.
Data Source Name System - 910
Data Source Use DB
Data Source Type O
Object Owner ID SY910
Library Name Blank
23.11 Versions
This chart lists the characteristics of the Versions data source.
Data Source Name (list includes possible sources) Versions - PD910
Versions - PY910
Versions - DV910
Versions - PS910
Data Source Use DB
Data Source Type O
PY910
DV910
PS910
Library Name Blank
