This chapter discusses these tasks:
The HTML Server is started using these scripts:
startNodeManager.sh
startWebLogic.sh
startManagedWebLogic.sh
While logged on to the HTML Server as the oracle user, you can submit these commands to run with nohup and in the background by executing the following commands:
cd /u01/Oracle/Middleware/wlserver_10.3/server/bin nohup ./startNodeManager.sh & tail -f nohup.out
Watch this log until you see this message:
INFO: Plain socket Listener started on port
Press ”Control + C” to break out of the tail command and then execute the following commands:
cd /u01/Oracle/Middleware/user_projects/domains/base_domain/bin nohup ./startWebLogic.sh & tail -f nohup.out
... <Server started in RUNNING mode>
Press ”control + C” to break out of the tail command.
Logon to your WebLogic Server Admin Console at this URL:
http:/<your WebLogic server>:7001/console
From the WebLogic Server Admin Console, go to the Environment and select the Servers option. The Summary of Servers screen is displayed. Select the Control tab and click the html_server row click the start button.
The log will display on the screen and prompt you to enter the user name and password, whose values should be documented in the Pre-Install Worksheet. Once WebLogic has been configured with a new password you can update the boot.properties file for nohup and background processing. For instructions on changing and setting up boot.properties files, refer to the JD Edwards EnterpriseOne HTML Server on WebLogic Reference Guide Release 9.1 for UNIX, Section 4.4 at the following link:
http://docs.oracle.com/cd/E24902_01/doc.91/e23434/toc.htm
Monitor the log until you see this message:
INFO: Successfully stated the management agent listerner on port 14502
Alternately, you can start the html_server through the WebLogic Administration Console or from Server Manager.
You should always shut down services before shutting down a VM Guest. When a VM Guest is shutdown and restarted, the Server Manager Agent may need to be manually restarted by logging in as the oracle user and running the startup steps.To shutdown services, log in as oracle and cd to the bin directory as above, and run the following scripts:
/stopManagedWebLogic.sh html_server
./stopWebLogic.sh
For more information on using WebLogic with EnterpriseOne see JD Edwards EnterpriseOne HTML Server on WebLogic Reference Guide Release 9.1 for UNIX, at the following link:
The BI Publisher Server is started using these scripts:
startNodeManager.sh
startWebLogic.sh
While logged on to the BI Publisher Server as the oracle user, you can submit these commands to run with nohup and in the background by executing the following commands:
Watch this log until you see this messages as shown below indicating the server started in RUNNING mode:
Logon to the WebLogic Server Administrative Console and start the BI Publisher Application, as shown in the following example
Caution:
Do not use this script to start the BI Publisher:startManagedWebLogic.sh
You must use the WebLogic Server Administrative Console to start the BI Publisher because there are configuration settings that are only available using this method.
The Mobile Server is started using these scripts:
startNodeManager.sh
startWebLogic.sh for the BSSV Server
startWebLogic.sh for the ADF Server
While logged on to the Mobile Server as the oracle user, you can submit these commands to run with nohup and in the background by executing the following commands:
INFO: Plain socket Listener started on port 5556
cd /u01/Oracle/Middleware/user_projects/domains/bssv_domain/bin nohup ./startWebLogic.sh & tail -f nohup.out
In the messages indicating the AdminServer_bssv is started, note on which port the server is listening. In the above example, the port is 10.245.161.12:8001.
cd /u01/Oracle/Middleware/user_proj ects/domains/adf_domain/bin
Watch this log until you see this messages as shown below indicating the ADF server started in RUNNING mode:
In the messages indicating the AdminServer_adf is started, note on which port the server is listening. In the above example, the port is 10.245.161.12:7001.
Press ”Control + C” to break out of the tail command.
Logon to the BSSV WebLogic Administrative Console and start the BSSV application, as shown in the following example:
Logon to the ADF Administrative Console and start the ADF application, as shown in the following example:
Caution:
Do not use this script to start the BSSV or ADF application:startManagedWebLogic.sh
You must use the WebLogic Server Administrative Console to start the BSSV and ADF applications because there are configuration settings that are only available using this method.
