This chapter contains the following topics:
This guide describes the configuration of the Application Interface Services (AIS) Server which provides the communication interface between JD Edwards EnterpriseOne mobile enterprise applications and JD Edwards EnterpriseOne. It also contains information about additional setup tasks that must be performed in EnterpriseOne to determine the data that mobile users can access and work with in mobile enterprise applications.
This guide also contains references to additional mobile enterprise applications implementation instructions located in the JD Edwards EnterpriseOne Applications Mobile Enterprise Applications Implementation Guide.
As you read through the contents of this guide and the JD Edwards EnterpriseOne Applications Mobile Enterprise Applications Implementation Guide, use the following list of tasks as a checklist for setting up mobile enterprise applications:
Deploy the AIS Server through Server Manager.
Configure the Allowed Hosts setting for the EnterpriseOne HTML Server.
Verify JAVA argument for AIS Server (Oracle WebLogic Server Only).
Define mobile enterprise application versions for mobile users.
Specify processing options and display options for mobile enterprise applications.
Set up security for mobile enterprise application versions.
Set up security for base EnterpriseOne applications used by mobile enterprise applications.
The following list contains references to the minimum technical requirements for the AIS Server for mobile:
Customers must conform to the supported platforms for the AIS Server, which can be found in the Certifications tab on My Oracle Support: https://support.oracle.com.
For more information about JD Edwards EnterpriseOne Minimum Technical Requirements, see the following document on My Oracle Support:
JD Edwards EnterpriseOne Minimum Technical Requirements Reference (Doc ID 745831.1)
https://support.oracle.com/epmos/faces/DocumentDisplay?id=745831.1
For a list of the EnterpriseOne mobile enterprise applications and the minimum EnterpriseOne Tools release required to run them, see the following document on My Oracle Support (login required):
Information Center for JD Edwards EnterpriseOne Mobile Applications (Doc ID 1637232.2)
https://support.oracle.com/epmos/faces/DocumentDisplay?id=1637232.2
