| Skip Navigation Links | |
| Exit Print View | |
Sun Dual 10GbE PCIe 2.0 Fibre Channel Over Ethernet Product Notes |
Intel 10-GbE Driver Support for Linux and Windows
Adding or Removing an Adapter as a VNIC Does Not Load the Storage Miniport Driver
Installing the FCoE Image After Installing ANS and Creating AFT Teams Does Not Install Storports
Link Aggregation Teams Are Not Supported
Using the FCoE CTRL-D Utility Is Not Possible With the Windows Device Manager
Displaying 82599-Based Adapter Is Not Possible in Windows MPIO Configurations
Removing ALB Teaming Causes All FCoE Functions to Fail
Ethernet Virtual Storage Miniport Driver Disappears From the Device Manager
Boot-Option ROM and Windows Boot Issues
Discovering the Desired VLAN Might Fail
Having an Installed Local Disk Causes FCoE to Fail in Windows OS
Stopping the IntelDCB Service Might Cause the OS to Hang or Crash
Uninstalling FCoE From a Local Disk Might Be Blocked
Creating VLAN Interfaces Fails With the FCoE Boot Option Enabled
Configuring an Adapter Port as the FCoE Boot Option Displays the Port as an Externally Shared VNIC
Setting the FCoE Linkdown Timeout Value Fails Prematurely When the System Is Booted Remotely
These product notes contain information about new features, known limitations, and documentation updates for Intel's Fibre Channel Over Ethernet (FCoE) from Oracle.
New issues are added to these product notes as needed. Ensure that you have the most recent version of these product notes at:
