Understanding the Installation Process
Installation Overview (Oracle Solaris 10)
Installation Overview (Oracle Solaris 11)
Installation Overview (Windows)
Front Panel Connectors and LEDs
Power and Environmental Requirements
Verify the Driver Version (Oracle Solaris 10)
Verify the Driver Version (Oracle Solaris 11)
Remove the Driver (Oracle Solaris OS)
Download and Install the Driver (Linux)
Download and Install the Driver (Windows)
Verify the Installation (Oracle SPARC)
Verify the Installation (Oracle Solaris x86)
Verify the Installation (Linux)
Verify the Installation (Windows)
Create Driver Instance Files (Oracle Solaris 10)
Configure the Network Host Files (Oracle Solaris 10)
Boot Over a 10 GbE Network (Oracle Solaris x86 and Linux)
Install Oracle Solaris 10 Over a Network (Oracle SPARC)
Administering Driver Parameters and Jumbo Frames
Driver Parameters (Oracle Solaris OS)
Set Driver Parameters (Oracle Solaris OS)
Configuring Jumbo Frames (Oracle Solaris OS)
Change the MTU Temporarily (Oracle Solaris 10)
Change the MTU Temporarily (Oracle Solaris 11)
Configure Jumbo Frames (Linux)
Configure Link Aggregations (Oracle Solaris 10)
Display Information About Link Aggregations (Oracle Solaris 10)
Delete Link Aggregations (Oracle Solaris 10)
Configure Static VLANs (Oracle Solaris 10)
Analyze Why the Device Link Is Missing
This guide provides hardware and software installation instructions for the Sun Dual Port 10GBase-T Adapter from Oracle. The instructions are meant for enterprise system administrators who have experience installing network hardware and software.
Important: The Sun Dual Port 10GBase-T Adapter was formerly named the Sun Dual Port 10 GbE PCIe 2.0 Low Profile Adapter, Base-T. The former product name might still appear in the product and document. The product name change does not indicate any change in product features or functionality.
Note - In this document, the term “x86” refers to 64-bit and 32-bit systems manufactured using processors compatible with the AMD64, Intel Xeon, or Intel Pentium product families.
For late-breaking information and known issues about this product, refer to the product notes at:
http://www.oracle.com/pls/topic/lookup?ctx=SDP_10GbE-PCIe2.0-LPA_BASE-T
Provide feedback on this documentation at:
http://www.oracle.com/goto/docfeedback
