This appendix provides examples for using the listening and target connectors delivered with PeopleSoft Integration Broker, and discusses how to:
Set up metadata for the examples.
Use the PeopleSoft connectors.
Use the HTTP connectors.
Use the PeopleSoft 8.1 connectors.
Use the JMS connectors.
Use the AS2 connectors.
Use the simple file target connector.
Use the FTP target connector.
Use the SMTP target connector.
Understanding Using This AppendixThis appendix presents examples of how to use the connectors delivered with PeopleSoft Integration Broker.
The intention of the examples provided in this appendix is to provide a starting point for exploring how the connectors work. The examples are designed to be simple and require the minimum set up and configuration necessary to invoke them.
If you try these examples and choose to cut the code samples provided in this document and paste them into PeopleSoft Application Designer, the PeopleSoft Pure Internet Architecture, or text or XML editors, verify that single or double quotation marks are pasted into these mediums as straight quotes. Slanted or curly quotes will cause the code samples to fail.
PrerequisitesTo use this appendix, you should have basic experience in using PeopleSoft Integration Broker. There is little background information presented in this appendix and many of the basic steps involved in creating integrations are presented in general terms (for example, “create a new Service/Service Operation.”) Please refer to the appropriate chapters in this PeopleBook for information on how to complete basic tasks.
Setting Up MetadataThis section discusses how to set up metadata for the examples presented in this appendix and discusses how to:
Create queues, request messages, response messages, services, service operations and pages.
Create nodes and routing definitions.
Create a test record and page.
Set up integration gateway logging.
Understanding Setting Up MetadataBefore you use the examples in this appendix you must set up metadata as described in this section.
Note. The examples presented in this appendix demonstrate the use of one type of connector at a time. The examples share the same basic definitions for the service operation, request message, response message, routings, and the test page. As a result, you should attempt to run only one example at a time, since the underlying metadata and objects are shared.
The exact requirements for setting up the listening and target connectors do differ somewhat, but since the differences are fairly minor the steps are combined in this section.
PrerequisitesBefore you begin the set up data for the examples configure and start the integration gateway.
Creating Services, Service Operations, Queues, and MessagesThis section describes creating services, service operations, queues, and request and response messages for use in running the connector examples presented in this appendix.
Unless otherwise noted, use the appropriate PeopleSoft Pure Internet Architecture pages to complete these tasks.
To create services, service operations, queues, and messages:
Create a new Service
Name the service EXAMPLE_SERVICE.
Create new synchronous Service operation.
Add a service operation of type synchronous to the EXAMPLE_SERVICE service and name it EXAMPLE_SERVICE_OPR.
Complete the field definitions for service operation as follows:
Field |
Value |
Operation Description |
Test service operation |
Request Message.Version |
EXAMPLE_REQUEST_MSG.VERSION_1 |
Response Message Name.Version |
EXAMPLE_RESPONSE_MSG.VERSION_1 |
Configure the Service Operation Security for this service operation.
Create a new asynchronous Service Operation
Add a service operation of type Asynchronous — one way to the EXAMPLE_SERVICE and name it EXAMPLE_SERVICE_ASYNC_OPR
Complete the field definitions for the service operation as follows:
Field |
Value |
Queue Name |
EXAMPLE_QUEUE |
Create a new queue.
Name the queue EXAMPLE_QUEUE
Verify that the Queue Status is set to Run.
Use the Integration Broker Service Operations Monitor Administration to verify that the EXAMPLE_QUEUE is running.
Create a new request message.
Create a Nonrowset-based message with message name as EXAMPLE_REQUEST_MSG and message version as VERSION_1.
Create a new response message.
Create a Nonrowset-based message with message name as EXAMPLE_RESPONSE_MSG and message version as VERSION_1.
Creating the Test Record and Page.This section discusses how to use PeopleSoft Application Designer to:
Create a test record.
Create a test page.
You must create a work record that will be used on the Test Page.
Create a new record:
Insert the character field TEST into the record.
Select Derived/Work as the Record Type.
Save the record as EXAMPLE_WORKREC.
Creating the Test Page
You must create a test page. This page will be used in some of the target connector examples.
Create a new page with a single push button on it:
Create the page.
Add a push button with the following properties:
Property |
Value |
Destination |
PeopleCode Command |
RecordName |
EXAMPLE_WORKREC |
Field Name |
TEST |
Re-size the button and label it Test target connector.
Save the page as EXAMPLE_PAGE.
Add the page to a component. This may be an existing component or a new one. Ensure that the security settings for the component allow the new page to be accessed.
Creating Nodes and Routing DefinitionsUse the PeopleSoft Pure Internet Architecture to complete the following tasks.
Creating Source Nodes and Inbound Routing for service operations
You must create a node that will be the source of all requests to the listening connectors.
To create a source node and a inbound routing:
Add a new node called SOURCENODE. Enter in appropriate values for the description and the default user ID. Verify that the Active Node check box has been selected. Save this node.
Add a new inbound routing to the EXAMPLE_SERVICE_OPR service operation and name it EXAMPLE_SERVICE_IN_RTN.
Set the Sender Node field value to SOURCENODE and the Receiver Node field value to the local node's value.
Check the Active check-box for routing .
Set the Logging Details field value to Header and Detail .
Save the routing.
Adding Target Nodes and outbound routing
You must create a target node and an outbound routing for all outgoing requests for the target connectors.
To add a target node and an outbound routing:
Add a new node called TARGETNODE. Enter in the appropriate values for the description and default user ID. Verify that the Active Node check box has been selected. Save this node.
Add a new outbound routing to the EXAMPLE_SERVICE_OPR service operation and name it EXAMPLE_SERVICE_OUT_RTN.
Set the Sender Node field value to the local node's value and the Receiver Node field value to TARGETNODE.
Verify that the Status is set to Active.
Verify that Logging Details field value is set to Header and Detail.
Save the routing.
Add a new outbound routing to the service operation EXAMPLE_SERVICE_OPR_ASYNC and name it EXAMPLE_SERVICE_ASYNC_RTN.
Save the routing.
Setting Up Integration Gateway LoggingThe integration gateway has message and error logging capabilities. If problems arise while trying the examples, these logs can be invaluable in determining where problems are occurring.
See Managing Integration Gateway Message and Error Logging.
Example 1: Using the PeopleSoft ConnectorsThis section discusses using the PeopleSoft listening and PeopleSoft target connectors.
Understanding the PeopleSoft Connector ExamplesThe example provided for using the PeopleSoft target connector demonstrates using the connector to invoke a synchronous service operation between two PeopleSoft nodes.
The example provided for using the PeopleSoft listening connector demonstrates using Send Master to invoke a service operation into the local system for processing.
PrerequisitesTo use the PeopleSoft target connector example you must have a second PeopleSoft 8.52 system. You must have the application server, the PeopleSoft Pure Internet Architecture and the Integration Gateway configured and running.
Note. In this section, the current PeopleSoft system is referred to as the originating system, and the second PeopleSoft system is called the destination system.
Using the PeopleSoft Target ConnectorThis section provides an example of using the PeopleSoft target connector and describes how to:
Set up data on the originating system.
Set up data on the destination system.
Test the PeopleSoft target connector.
Setting Up Data on the Originating System
To set up data on the originating system:
In PeopleSoft Application Designer, open the EXAMPLE_WORKREC record. Add the following PeopleCode to the FieldChange event for the TEST field:
&msg = CreateMessage(Operation.EXAMPLE_SERVICE_OPR); &xmldata = "<?xml version='1.0'?><ConnectorTest/>"; /* create an XmlDoc */ &xmlDoc = CreateXmlDoc(&xmldata); &rootNode = &xmlDoc.documentelement; &descNode = &rootNode.addelement("PSFTtest"); &descNode.nodevalue = "This is a test message."; /* put the XML in the message */ &msg.setxmldoc(&xmlDoc); /* send the request */ &response = %IntBroker.SyncRequest(&msg); /* and echo it back to the user */ &xmlDoc = &response.getxmldoc(); MessageBox(0, "", 0, 0, &xmlDoc.genxmlstring());
In the PeopleSoft Pure Internet Architecture, open the node definition for TARGETNODE. Set the ConnectorID to PSFTTARGET.
In the Integration Properties for the gateway, add a new entry for TARGETNODE along with the appropriate values.
ig.isc.TARGETNODE.serverURL=//<machinename>:<port> ig.isc.TARGETNODE.userid=<userid> ig.isc.TARGETNODE.password=<password> ig.isc.TARGETNODE.toolsRel=<toolsRelease>
Setting Up Data on the Destination System
To set up data on the destination system:
Follow the steps outlined in the section “Setting Up Metadata” to add the following to the destination system:
the EXAMPLE_QUEUE queue
the EXAMPLE_REQUEST_MSG message
the EXAMPLE_RESPONSE_MSG message
the EXAMPLE_SERVICE_OPR synchronous service operation
Add a node entry for the originating system. Ensure that the Single Signon security is configured so that the destination system accepts authentication tokens from the originating system.
Add a new inbound synchronous routing between the originating system and the destination for the EXAMPLE_SERVICE_OPR service operation.
In PIA, for service operation EXAMPLE_SERVICE_OPR add a handler of type OnRequest with implementation type App Class. Create a handler application class based on the IRequestHandler interface, and for the method OnRequest add following PeopleCode
Local XmlDoc &xmldoc; Local File &theFile; Local XmlNode &rootNode, &descNode; Local Message &response; Local string &xmldata; /* get the body of the incoming message */ &xmldoc = &_MSG.GetXmlDoc(); /* and write it out to a file */ &theFile = GetFile("ARequest.txt", "W"); &theFile.WriteString(&xmldoc.GenXmlString()); &theFile.Close(); /* create the response message */ &response = CreateMessage(Operation.EXAMPLE_SERVICE_OPR, %IntBroker_Response); /* create the body for the response message */ &xmldata = "<?xml version='1.0'?><ConnectorTest/>"; &xmldoc = CreateXmlDoc(&xmldata); &rootNode = &xmldoc.DocumentElement; &descNode = &rootNode.AddElement("ResponseMessage"); &descNode.NodeValue = "This was generated in the OnRequest event."; /* add the body to the message */ &response.SetXmlDoc(&xmldoc); /* and return the response message */ Return &response;
Testing the PeopleSoft Target Connector
To test the PeopleSoft target connector:
In the PeopleSoft Pure Internet Architecture, open the EXAMPLE_PAGE page and click the Test button. The response message will be displayed in a message box.
On the destination system, open Service Operation Monitor to view the details of the received message. Open the text file created by the OnRequest PeopleCode to view the details of service operation request received.
Using the PeopleSoft Listening ConnectorThis section provides an example for testing the PeopleSoft listening connector.
Testing the PeopleSoft Listening Connector
To test the PeopleSoft listening connector:
In PIA , open the EXAMPLE_SERVICE_OPR service operation and add a Handler of type OnRequest with implementation type App class. The OnRequest method of App class should have following PeopleCode .
Local XmlDoc &xmldoc; Local File &theFile; Local XmlNode &rootNode, &descNode; Local Message &response; Local string &xmldata; /* get the body of the incoming message */ &xmldoc = &_MSG.GetXmlDoc(); /* and write it out to a file */ &theFile = GetFile("HttpRequest.txt", "W"); &theFile.WriteString(&xmldoc.GenXmlString()); &theFile.Close(); /* create the response message */ &response = CreateMessage(Operation.EXAMPLE_SERVICE_OPR, %IntBroker_Response); /* create the body for the response message */ &xmldata = "<?xml version='1.0'?><ConnectorTest/>"; &xmldoc = CreateXmlDoc(&xmldata); &rootNode = &xmldoc.DocumentElement; &descNode = &rootNode.AddElement("ResponseMessage"); &descNode.NodeValue = "This was generated in the OnRequest event."; /* add the body to the message */ &response.SetXmlDoc(&xmldoc); /* and return the response message */ Return &response;
Start Send Master and create an 8.48 Integration Broker (MIME) project.
In the URL field enter the address of the PeopleSoft listening connector:
http://your_server_name/PSIGW/PeopleSoftListeningConnector
Replacing <your_server_name> with the details of the server where the gateway is running. For example:
http://machine1234/PSIGW/PeopleSoftListeningConnector
In the Requesting Node field, enter SOURCENODE.
In the Ext. Operation name field, enter EXAMPLE_SERVICE_OPR.v1.
From the Operation type list, select Sync.
Click the Input File tab and enter the following XML:
<?xml version="1.0"?><Test>Data</Test>
Click the Post button.
The response from the server displays in the Output Information section. Note that this is a MIME response; look near the end to find the response XML generated by the OnRequest PeopleCode. Open the text file created by the OnRequest method of application class to view the body of the request message.
Example 2: Using the HTTP ConnectorsThis section discusses how to:
Use the HTTP listening connector.
Use the HTTP target connector.
PrerequisitesWhen using the examples for using the HTTP target connector, an HTTP server is needed to receive the HTTP request and to return a response. If using the SOAP example, the HTTP server must be able to process SOAP messages.
Using the HTTP Listening ConnectorThis section provides examples of how to set credentials for HTTP requests coming into the integration gateway, and discusses how to:
Set credentials in message bodies.
Set credentials in HTTP headers.
Set credentials in query strings.
Set credentials in SOAP-specific HTTP headers.
Setting Up for Using the HTTP Listening Connector Examples
In PIA, for service operation EXAMPLE_SERVICE_OPR add a handler of type OnRequest with implementation type application Class. Create a handler application class based on the IRequestHandler interface, and for the method OnRequest add following PeopleCode
Setting Credentials in the Message Body
To set HTTP request credentials in the message body:
Start Send Master, and create a new Input File project.
In the URL field enter:
http://<your_server_name>/PSIGW/HttpListeningConnector
Replace <your_server_name> with the details of the server where the integration gateway is running. For example:
http://machine1234/PSIGW/HttpListeningConnector
In the Input section, paste the following XML. Notice that the service operation name and requesting node are present in the XML
<?xml version="1.0"?> <IBRequest> <ExternalOperationName>EXAMPLE_SERVICE_OPR.v1</ExternalOperation Name> <From> <RequestingNode>SOURCENODE</RequestingNode> </From> <ContentSections> <ContentSection> <Data> <![CDATA[<?xml version="1.0"?><ConnectorTest> Testing the HTTPListeningConnector. Message body. </ConnectorTest>]]> </Data> </ContentSection> </ContentSections> </IBRequest>
Click the Post button to invoke service operation on the integration gateway.
Check the Output section for the response. Compare the response with the XML created in the handler application class. Also check the HttpRequest.txt file created by the OnRequest PeopleCode to see the body of the request message received by the application server.
Setting Credentials in HTTP Headers
To set HTTP request credentials in the HTTP header:
In the Headers field enter the following:
OperationName:EXAMPLE_SERVICE_OPR.v1 From:SOURCENODE
In the Input section, paste the following:
<?xml version="1.0"?> <ConnectorTest> Testing the HTTPListeningConnector. HTTP Header. </ConnectorTest>
Click the Post button to sent the message to the integration gateway.
Setting Credentials in Query Strings
To set HTTP request credentials in a query string:
http://your_server_name/PSIGW/HttpListeningConnector?&Operation= EXAMPLE_SERVICE_OPR.v1&From=SOURCENODE
http://machine1234/PSIGW/HttpListeningConnector?&Operation= EXAMPLE_SERVICE_OPR.VERSION_1&From=SOURCENODE
<?xml version="1.0"?> <ConnectorTest> Testing the HTTPListeningConnector. Query String. </ConnectorTest>
Setting Credentials in SOAP-Specific HTTP Headers
To set HTTP request credentials in a SOAP-specific HTTP header:
In the Header field, add the following:
SOAPAction: http://peoplesoft.com/EXAMPLE_SERVICE_OPR.v1/SOURCENODE//
<?xml version="1.0"?> <SOAP-ENV:Envelope xmlns:SOAP-ENC="http://schemas.xmlsoap.encoding/ "xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"> <SOAP-ENV:Body> <ConnectorTest> <Text> Testing the HTTPListeningConnector. SOAP Message. </Text> </ConnectorTest> </SOAP-ENV:Body> </SOAP-ENV:Envelope>
Check the Output section for the response. Compare the response with the XML created in the handler application class; that XML will be returned wrapped in a SOAP envelope. Also check the HttpRequest.txt file created by the OnRequest PeopleCode to see the body of the request message received by the application server.
Using the HTTP Target ConnectorThis section provides examples of using the HTTP target connector and discusses how use the connector to:
Send standard HTTP requests.
Send SOAP messages in HTTP requests.
Sending Standard HTTP Requests
To send a standard HTTP request:
In PeopleSoft Application Designer, open the EXAMPLE_WORKREC record and add the following PeopleCode to the FieldChange event for the TEST field.
&msg = CreateMessage(Operation.EXAMPLE_SERVICE_OPR); &xmldata = "<?xml version='1.0'?><ConnectorTest/>"; /* create an XmlDoc */ &xmlDoc = CreateXmlDoc(&xmldata); &rootNode = &xmlDoc.documentelement; &descNode = &rootNode.addelement("HTTPtest"); &descNode.nodevalue = "This will be sent to an HTTP server."; /* put the XML in the message */ &msg.setxmldoc(&xmlDoc); /* send the request */ &response = %IntBroker.SyncRequest(&msg); /* and echo it back to the user */ &xmlDoc = &response.getxmldoc(); MessageBox(0, "", 0, 0, &xmlDoc.genxmlstring());
Note that this code assumes that the response from the server is properly formatted XML.
In the PeopleSoft Pure Internet Architecture, open the node definition for TARGETNODE. Set the Connector ID to HTTPTARGET. Set the URL property value to the address of the HTTP server that will process the request.
Open the EXAMPLE_PAGE page, and click on the Test button. The HTTP response will be displayed in the resulting message box.
Sending SOAP Messages in HTTP Requests
To send a SOAP message in an HTTP request:
&msg = CreateMessage(Operation.EXAMPLE_SERVICE_OPR); /* create a SOAP document */ &soapReq = CreateSOAPDoc(); &soapReq.AddMethod("TestNode", 1); &soapReq.AddParm("Text", "This is a SOAP request."); /* put the XML in the message */ &msg.setxmldoc(&soapReq.xmlDoc); /* send the request */ &response = %IntBroker.SyncRequest(&msg); /* and echo it back to the user */ &xmlDoc = &response.getxmldoc(); MessageBox(0, "", 0, 0, &xmlDoc.genxmlstring());
On the Node Definitions-Connectors tab, set the Connector ID to HTTPTARGET.
Example 3: Using the PeopleSoft 8.1 ConnectorsThe examples provided in this section demonstrate sending a rowset-based asynchronous message between a PeopleSoft 8.52 node and a PeopleSoft 8.1 node.
Understanding the PeopleSoft 8.1 Connectors ExamplesWhen sending a message from a PeopleSoft 8.52 system to a PeopleSoft 8.1 system, you will use the PeopleSoft 8.1 target connector. You will also use PeopleCode, as well as the example page and work record that you created using the information in the setup section at the beginning of this appendix.
When sending a message from a PeopleSoft 8.1 system to a PeopleSoft 8.4 system, you will use the PeopleSoft 8.1 listening connector. You will also use the test message functionality in PeopleSoft Application Designer.
Setting Up Data for the PeopleSoft 8.1 Connectors ExamplesThis section describes setting up data for using the PeopleSoft 8.1 connector examples.
Setting Up Data on the PeopleSoft 8.52 System
To set up data on the PeopleSoft 8.52 system:
In PeopleSoft Application Designer, create a new field called EXAMPLE_CHAR. This should be a mixed-case character field of size 20.
Create a new record.
Name the record EXAMPLE_REC.
Add the EXAMPLE_CHAR field to this record, set it as the key, and save the definition.
Build the physical table for this record.
In the PeopleSoft Pure Internet Architecture, create a new message called EXAMPLE_PSFT_MSG with the version set to VERSION_1.
Select the message type to be Rowset— Based.
Add the EXAMPLE_REC record as the root record of this message.
Add a new node, using the node name of the PeopleSoft 8.1 system. Verify that the Active Node box is checked, and save the record.
Open the EXAMPLE_PAGE page and add an EditBox to the page, setting the following properties:
Property |
Value |
Record name |
EXAMPLE_REC |
Field name |
EXAMPLE_CHAR |
Create a new service called PSFT81_SERVICE.
Create a new service operation
Add a service operation of type asynchronous-one way to the PSFT81_SERVICE and name it PSFT81_SERVICE_OPR.
Add EXAMPLE_PSFT_MSG as the message.
Add EXAMPLE_QUEUE as the queue.
Add an inbound routing for the PSFT81_SERVICE_OPR service operation with the sourcenode being the 8.1 system and the destination being the 8.52 system.
Add an outbound routing for the PSFT81_SERVICE_OPR service operation with the sourcenode being the 8.52 system and the destination being 8.1 system.
Open the EXAMPLE_WORKREC record. Add the following PeopleCode to the FieldChange event for the TEST field:
&message = CreateMessage(Operation.PSFT81_SERVICE_OPR); /* get the buffer data */ &rowset = GetLevel0(); /* copy buffer data to the message */ &message.CopyRowset(&rowset); /* send the message */ &message.Publish();
Go to the connector information for the new node. Set the Connector ID to PSFT81TARGET. Set the URL property to the address of the gateway servlet on the PeopleSoft 8.1 system. For example:
http://<theServerNameAndPort>/servlets/gateway
Setting Up Data on the PeopleSoft 8.1 System
To set up data on the PeopleSoft 8.1 system:
Create a new message channel called EXAMPLE_CHANNEL. On the properties dialog box, set the Status to Run. Configure the security for the message monitor so that the channel can be displayed.
Create a new message.
Open the properties and select the Active box for the Status.
Set the Message Channel to EXAMPLE_CHANNEL.
Add the EXAMPLE_REC record to VERSION_1 of this message.
Save the message as EXAMPLE_PSFT_MSG.
Add the subscription ExampleSubscription to the EXAMPLE_PSFT_MSG. Use the following PeopleCode in the subscription body:
/* get the incoming message */ &msg = GetMessage(); &msgXML = &msg.GenXMLString(); /* and write it to a file */ &file = GetFile("PSFT81msg.txt", "w"); &file.writeString(&msgXML); &file.close();
Create a new message node, using the name of the PeopleSoft 8.52 node. Add a Location to this node with the following format:
http://<serverName:port>/PSIGW/PS81ListeningConnector
The serverName and port you specify must correspond to the integration gateway address of the PeopleSoft 8.52 system.
Open the EXAMPLE_CHANNEL. Add a new routing rule to the channel, where the direction is Both and the message node name is that of the PeopleSoft 8.52 node.
In the PeopleSoft Pure Internet Architecture, invoke the Gateway Administration servlet and add the PeopleSoft 8.1 node to the PeopleSoft handler.
Open the Message Monitor and verify that the EXAMPLE_CHANNEL is running.
Using the PeopleSoft 8.1 Target ConnectorIn the example presented in this section, you will use the PeopleSoft 8.1 target connector to send a message from a PeopleSoft 8.52 system to a PeopleSoft 8.1 system.
To send a message from a PeopleSoft 8.52 system to a PeopleSoft 8.1 system:
In the PeopleSoft Pure Internet Architecture on the PeopleSoft 8.52 system, open the EXAMPLE_PAGE. Enter text into the edit box, and press the Test button. Wait for a minute or two to allow the systems to process the message.
On the PeopleSoft 8.52 system, open Integration Broker Monitor to view the details of the outbound message.
On the PeopleSoft 8.1 system, open up the Message Monitor to view the details of the received message. Open the PSFT81msg.txt file created by the subscription PeopleCode to see the body of the message.
Using the PeopleSoft 8.1 Listening ConnectorIn the example presented in this section, you will use the PeopleSoft 8.1 listening connector to send a message from a PeopleSoft 8.1 system to a PeopleSoft 8.52 system.
To send a message from a PeopleSoft 8.1 system to a PeopleSoft 8.52 system:
On the PeopleSoft 8.1 system, open PeopleSoft Application Designer and open the EXAMPLE_PSFT_MSG message. Right-click VERSION_1 and select Create test message. The Create Test Message window appears.
Expand Transaction in the tester window. Set the value for EXAMPLE_CHAR. Open the PSCAMA section and set the AUDIT_ACTN to A and click OK. A message is published. Wait a minute or two before proceeding to allow the message to be processed by both nodes.
On the PeopleSoft 8.1 system, open the Message Monitor to view the details of the outbound message.
On the PeopleSoft 8.52 system, open the Service Operation Monitor to view the details of the received message.
Example 4: Using the JMS ConnectorsThis section discusses using the JMS listening and JMS target connectors.
Understanding the JMS Connector ExamplesThe examples in this section are intended to be generic and independent of the JMS provider being used. Because of this, in certain steps general instructions are provided. The actual details of the task will depend on the provider being used – and may be rather involved. Please refer to the appropriate documentation.
The error queue is not configured in the examples. However, configuring the error queue may be desirable should issues arise while trying the examples.
The examples in this section focus on queues, but the process for using the JMS connectors when working with topics is essentially the same.
See Also
Working With the JMS Connectors
PrerequisitesTo use the examples in this section, a JMS provider must be configured and running. Please refer to the provider’s documentation for instructions on how to accomplish these tasks. Ensure that messages can be sent to topics and queues before proceeding with the examples.
For the JMS target connector example, you will need a utility to consume and view the messages created. For the JMS listening connector example, you will need a utility to create the messages. The exact details of these utilities depend on the provider. Some may provide an administrative console that you can use to view the contents of topics and queues, and possibly send new messages to them. Other providers may include sample Java programs that you can use to interact with the provider. Refer to the provider’s documentation for further details.
A special case exists for testing the JMS listening connector and queues when the provider is IBM MQSeries. In this instance, use Send Master to test the JMS listening connector.
See Also
Using the JMS Target ConnectorIn this example, PeopleSoft Integration Broker will generate a JMS message, which will be consumed outside of the PeopleSoft system.
To use the JMS target connector:
On the JMS provider, create a JMS Connection Factory with the JNDI name ExampleConnectionFactory.
On the JMS provider, create a JMS Queue with the JNDI name ExampleQueue.
In PeopleSoft Application Designer, open the EXAMPLE_WORKREC record and add the following PeopleCode to the FieldChange event for the TEST field:
/* create an XML document */ &xmldata = "<?xml version='1.0'?><ConnectorTest/>"; &xmlDoc = CreateXmlDoc(&xmldata); &rootNode = &xmlDoc.documentelement; /* add text to the document */ &descNode = &rootNode.AddElement("TestNode"); &descNode.NodeValue = "Sending a message to a JMS queue."; /* and send it out in an async request */ &MSG = CreateMessage(Operation.EXAMPLE_SERVICE_ASYNC_OPR); &MSG.SetXmlDoc(&xmlDoc); %IntBroker.Publish(&MSG); MessageBox(0, "", 0, 0, "Message sent.");
In the PeopleSoft Pure Internet Architecture, open the node definition for TARGETNODE. Set the Connector ID to JMSTARGET. Set the values for the following properties:
Property |
Value |
JMSFactory |
ExampleConnectionFactory. |
JMSProvider |
Name of the provider being used. |
JMSUrl |
Connection URL for the provider. |
JMSQueue |
ExampleQueue. |
JMSUserName |
The username on the JMS provider. |
JMSPassword |
The encrypted password for the user ID. |
Test the connector:
Open the test page, and click on the Test button.
Verify that the message was sent to the queue. The exact mechanism for doing depends on the provider or utility that you are using.
Using the JMS Listening ConnectorIn this example, you will use the JMS listening connector to send a message to the JMS provider. PeopleSoft Integration Broker will consume the message.
To use the JMS listening connector:
In PeopleSoft Application Designer, create a application package and application class. In the application class, put the following PeopleCode in the OnRequest function
Local XmlDoc &xmldoc; &xmldoc = &_MSG.GetXmlDoc(); /*&_msg is the parameter*/ /* and write it to a file */ Local File &theFile = GetFile("JMSRequest.txt", "W"); &theFile.WriteString(&xmldoc.GenXmlString()); &theFile.Close(); /* create the reponse message */ Local Message &outmsg; &outmsg = CreateMessage(Operation.EXAMPLE_SERVICE_OPR, %IntBroker_Response); /* build the body of the response */ Local string &xmldata = "<?xml version='1.0'?><ConnectorTest/>"; &xmldoc = CreateXmlDoc(&xmldata); Local XmlNode &rootNode = &xmldoc.DocumentElement; Local XmlNode &descNode = &rootNode.AddElement("ResponseMessage"); &descNode.NodeValue = "This wasgenerated in the OnRequest handler."; /* add the body to the message */ &outmsg.SetXmlDoc(&xmldoc); /* send the response message */ Return &outmsg;
In PIA, open the handler tab on the service operation EXAMPLE_SERVICE_OPR, and set the application class package, class and method name as you defined above.
In the integrationGateway.properties file, uncomment the following line:
ig.jms.Queues=1
Set the following properties to the values indicated:
Property |
Value |
ig.jms.Queue1 |
ExampleQueue |
ig.jms.Queue1.Provider |
<the name of the provider> |
ig.jms.Queue1.JMSFactory |
ExampleConnectionFactory |
ig.jms.Queue1.Url |
<connection URL for the provider> |
ig.jms.Queue1.Use |
< the userid > |
ig.jms.Queue1.Password |
<the encrypted password for the userid. > |
ig.jms.Queue1.MessageName |
EXAMPLE_SERVICE_OPR.VERSION_1 |
ig.jms.Queue1.RequestingNode |
SOURCENODE |
ig.jms.Queue1.DestinationNode |
<the name of the local node > |
Deploy and start the JMSListeningConnectorAdministrator servlet.
Test the connector:
Send a text message to the example JMS queue. Set the text of the message to:
<?xml version="1.0"?> <ConnectorTest> <TestNode>Sending a message to the JMS Listening Connector.</TestNode> </ConnectorTest>
Check the message logs and the file named in the OnRequest method of application class . The message should be present in both.
Example 5: Using the AS2 ConnectorsThis section discusses using the AS2 listening and AS2 target connectors.
Understanding the AS2 Connector ExamplesThe purpose of the AS2 protocol is to allow the secure exchange of EDI data over the internet with trading partners. In the simplest case of an AS2 Message exchange, a sender packages data into an AS2 message structure and sends the message to trading partner over HTTP. Any kind of data can be transferred using AS2, including XML, EDI, text and binary.
This examples in this section demonstrate using the AS2 target connector to send an XML message to an external trading partner and using the AS2 listening connector to receive an XML message from a trading partner.
See Also
Working With the AS2 Connectors
PrerequisitesTo use the examples in this section, security certificates must be setup and registered in the keystore on the source and target machines. Take note of the certificate alias name for both the source or signer and the target or recipient servers, as you will need this information to set connector properties.
Verify that messages can be sent to and received from the AS2 external trading partner over HTTP before proceeding with the examples.
For the AS2 target connector example, you will need a third-party application to consume and view the messages created. For the AS2 listening connector example, you will need a third-party application to create and deliver the messages.
See Also
Setting Up Secure Integration Environments
Using the AS2 Target ConnectorIn this example PeopleSoft Integration Broker will generate an AS2 message and send it to a trading partner using HTTP. The external trading partner consumes the message. This example shows the tasks to perform to receive an MDN response message back synchronously or asynchronous.
To use the AS2 target connector:
In PeopleSoft Application Designer open the EXAMPLE_WORKREC record and add the following PeopleCode to the FieldChange event for the TEST field:
/*create an XML document */ Local string &xmldata; Local XmlDoc &xmlDoc; Local XmlNode &rootNode, &descNode; Local boolean &result; &xmldata = "<AS2ConnectorTest/>"; &xmlDoc = CreateXmlDoc(""); &rootNode = &xmlDoc.CreateDocumentElement("AS2ConnectorTest"); &rootNode = &xmlDoc.DocumentElement; /* add text to the document */ &descNode = &rootNode.AddElement("TestNode"); &descNode.NodeValue = "Sending a AS2 message."; &MSG = CreateMessage(Operation.EXAMPLE_SERVICE_ASYNC_OPR); &MSG.SetXmlDoc(&xmlDoc); /* and send it out in an async request */ %IntBroker.Publish(&MSG); MessageBox(0, "", 0, 0, "AS2 Message sent.");
In the PeopleSoft Pure Internet Architecture, open the node definition for TARGETNODE. Set the Connector ID to AS2TARGET. Set the values for the following required properties:
Property Name |
Value |
URL |
Specify the URL to which messages are sent using this connector. |
AS2To |
Specify the name of the sending node. |
AS2From |
Specify the name of the receiving node. |
RecipientCertAlias |
Specify the alias of the receiving certificate. |
SignersCertificateAlias |
Specify the alias of the signing certificate. |
Add an outbound asynchronous transaction on the AS2TARGETNODE, to identify that the message EXAMPLE_MESSAGE, VERSION_1 will be sent to the URL location.
Set the following properties in the integrationGateway.properties file. Use PSCipher.bat utility located at <PIA_HOME>\webserv\peoplesoft to encrypt the keystore password.
#AS2 Log Directory, logs all incoming and outgoing AS2 request and responses. #Uncomment and specify the correct directory name to enable logging. ig.AS2.LogDirectory = c://temp//as2 #AS2 Properties #Uncomment the following two lines to specify your keystore and AS2 properties ig.AS2.KeyStorePath=KeyStore Location (use // for windows path) ig.AS2.KeyStorePassword=EncryptedKeyStorePassword ig.AS2.AS2Directory=Location of AS2 Certificates (required for Async MDN Type) ig.AS2.LogDirectory=Path to store AS2 Log Files (optional) Examples ig.AS2.KeyStorePath=C://pt846-112-R2//webserv//peoplesoft//keystore//pskey ig.AS2.KeyStorePassword=GD9klUFw8760HVaqeT4pkg== ig.AS2.AS2Directory=c://temp//as2 ig.AS2.LogDirectory = c://temp//as2//logs
If the MDN response is synchronous, go to step 8.
If the MDN response is asynchronous, verify the delivered node named ASYNC_MDN exists.
Verify that the node ASYNC_MDN has an active incoming asynchronous routing for the service operation ASYNC_MDN_RESPONSE. VERSION_1.
Verify that the delivered queue AS2_CHANNEL is not in Pause mode.
Test the connector.
Verify that the message was sent to the recipient. The exact mechanism for doing so depends on the AS2 trading partner you are using.
Verify that the MDN response was sent back to the source. The exact mechanism for doing so depends on the AS2 trading partner you are using.
If the MDN type is set to Async, verify that the ASYNC_MDN_RESPONSE was received.
Using the AS2 Listening ConnectorIn this example, you will use the AS2 listening connector to receive a message sent by the AS2 trading partner, and return an MDN synchronous or asynchronous response. Perform all tasks on the target machine. PeopleSoft Integration Broker will consume the message.
To use the AS2 listening connector:
In the PeopleSoft Pure Internet Architecture, choose the node that corresponds to the AS2 trading partner sending the message.
Insert an inbound asynchronous routing corresponding to the service operation EXAMPLE_REQUEST_ASYNC_OPR.VERSION_1 expected.
Insert an outbound asynchronous routing corresponding to the service operation EXAMPLE_RESPONSE_ASYNC_OPR.VERSION_1 as a reply.
In PeopleSoft Application Designer, create an application package and application class, and provide a method OnNotify with the following PeopleCode:
Local XmlDoc &xmlDoc; Local File &theFile; Local Message &msg; Local XmlDoc &MsgXmlDoc, &xmlDoc; Local XmlNode &rootNode, &descNode; /* get the body of the incoming message */ &MsgXmlDoc = &MSG.GetXmlDoc(); /* and write it to a file */ &theFile = GetFile("AS2Request.txt", "W"); &theFile.WriteString(&MsgXmlDoc.GenXmlString()); &theFile.Close(); &xmlDoc = CreateXmlDoc(""); &rootNode = &xmlDoc.CreateDocumentElement("ConnectorTest"); &rootNode = &xmlDoc.DocumentElement; /* add text to the document */ &descNode = &rootNode.AddElement("ResponseMessage"); &descNode.NodeValue = "This was generated in the OnRequest event."; /* send the response message */ &msg = CreateMessage(Operation.EXAMPLE_RESPONSE_ASYNC_OPR); &msg.SetXmlDoc(&xmlDoc); /* and send it out in an async request */ %IntBroker.Publish(&msg);
In PIA, open the handler tab on the service operation EXAMPLE_RESPONSE_ASYNC_OPR, and set the application package, class name and method.
In the integrationGateway.properties file, set the following properties to the values indicated:
#AS2 Properties #Uncomment the following two lines to specify your keystore and AS2 properties ig.AS2.KeyStorePath=KeyStore Location (use // for windows path) ig.AS2.KeyStorePassword=EncryptedKeyStorePassword ig.AS2.LogDirectory=Path to store AS2 Log Files (optional) #example: ig.AS2.KeyStorePath=C://pt846-112-R2//webserv//peoplesoft//keystore//pskey ig.AS2.KeyStorePassword=GD9klUFw8760HVaqeT4pkg== ig.AS2.LogDirectory = c://temp//as2//logs
In the following required properties, replace the <SOURCENODE> with the name of the AS2 trading partner source node, and <TARGETNODE> with the name of the local target node. Continue to set the value of the property.
# CertificateAlias is the certificate of AS2 Listening Node. # SignerCertificateAlias is the certificate of AS2 trading partner of Listening⇒ Node. ig.AS2.QE_<SOURCE>.<TARGET>.CertificateAlias= Target Machine Alias ig.AS2. <SOURCE>.<TARGET>.SignerCertificateAlias=Source Machine Alias #example: ig.AS2.PSFT_SRC_NODE.PSFT_TGT_NODE.CertificateAlias=<GeneratedAS2certificatealias> ig.AS2.PSFT_SRC_NODE.PSFT_TGT_NODE.SignerCertificateAlias=<Generated⇒ AS2certificatealias>
The following values only need to be set if the incoming data does not contain the appropriate AS2To and AS2From values in the header of the message. It is best to leave these values in the request message header and leave these properties commented out.
#This map translate AS2From and AS2To to a different node name. #This property is not required if you would use AS2FROM and AS2TO http header. ig.AS2.AS2ListenerMap.From.<SOURCEALIAS> = Specify the Source Node Name ig.AS2.AS2ListenerMap.To.<TARGETALIAS> = Specify the Target Node Name #example: ig.AS2.AS2ListenerMap.From.QE_SOURCE= PT_LOCAL ig.AS2.AS2ListenerMap.To. QE_IBTGT= AS2TARGETNODE
Test the connector:
Send a text message to the example AS2 queue. Name the message EXAMPLE_REQUEST_MSG.
<?xml version="1.0"?> <ConnectorTest> <TestNode>Sending a message to the AS2 Listening Connector.</TestNode> </ConnectorTest>
Check the file named in the subscription PeopleCode. The default location for this file is <PS_CFG_HOME>\appserv\<DOMAIN_NAME>\Files. The message contents should be present.
If the MDN type is asynchronous, verify that the AS2 trading partner received the ASYNC_MDN_RESPONSE.
Example 6: Using the Simple File Target ConnectorThis section describes how to use the simple file target connect to:
Write PeopleSoft data to a file.
Read data into PeopleSoft from a file.
Writing PeopleSoft Data to FilesThis section describes how to use the simple file target connector to write PeopleSoft data to a file.
To write data to a file:
&msg = CreateMessage(Operation.EXAMPLE_SERVICE_OPR); &xmldata = "<?xml version='1.0'?><ConnectorTest/>"; /* create an XmlDoc */ &xmlDoc = CreateXmlDoc(&xmldata); &rootNode = &xmlDoc.documentelement; &descNode = &rootNode.AddElement("TestNode"); &descNode.NodeValue = "This message was written to a file."; /* put the XML in the request... */ &msg.setxmldoc(&xmlDoc); /* ...and send */ &response = %IntBroker.SyncRequest(&msg);
In the PeopleSoft Pure Internet Architecture, open the node definition TARGETNODE.
On the Node Definitions-Connectors tab, set the Connector ID to FILEOUTPUT.
Add the following connector properties and values:
Property |
Value |
Method |
PUT |
FilePath |
Enter the location where you want the connector to write the file. For example, c:\temp. |
Access the integrationGateway.properties file and comment out the following line.
ig.fileconnector.password=EncryptedPassword
The password option is not used in this example.
In the PeopleSoft Pure Internet Architecture, open the EXAMPLE_PAGE page and click Test.
Go to the directory specified in the connector properties, and open the new file. The contents should reflect what was created in the PeopleCode.
Reading Data Into PeopleSoft From FilesThis section describes how to use the simple file target connector to read data into PeopleSoft from files.
To read data from files into PeopleSoft:
Create an XML file and include the following text:
<?xml version='1.0'?> <ConnectorTest> <TestNode> The file has been read from the file system. </TestNode> </ConnectorTest>
&msg = CreateMessage(Operation.EXAMPLE_SERVICE_OPR); &xmldata = "<?xml version='1.0'?><ConnectorTest/>"; /* create an XmlDoc */ &xmlDoc = CreateXmlDoc(&xmldata); /* put the XML in the message */ &msg.setxmldoc(&xmlDoc); /* send the request */ &response = %IntBroker.SyncRequest(&msg); /* display the results */ &xmlDoc = &response.getxmldoc(); MessageBox(0, "", 0, 0, &xmlDoc.genxmlstring());
In the PeopleSoft Pure Internet Architecture, open the TARGETNODE node definition.
Set the Connector ID to FILEOUTPUT.
Set the FilePath property to the location from where the connector will read the output file.
Property |
Value |
FileName |
Specify the name of the output file. The file's default name has the following format: sourcenodename.serviceoperationname.publication_id.xml |
METHOD |
GET |
A message box appears that displays the data from the file read.
Example 7: Using the FTP Target ConnectorThis sections discusses how to use the FTP target connector to:
Upload files to an FTP server.
Download files from an FTP server.
PrerequisitesFor the examples presented in this section, you must have an active FTP server, as well as an account on that server.
Uploading Files to FTP ServersTo upload a file to an FTP server:
&msg = CreateMessage(Operation.EXAMPLE_SERVICE_OPR); &xmldata = "<?xml version='1.0'?><ConnectorTest/>"; /* create an XmlDoc */ &xmlDoc = CreateXmlDoc(&xmldata); &rootNode = &xmlDoc.documentelement; &descNode = &rootNode.addelement("FTPtest"); &descNode.nodevalue = "This text will be uploaded"; /* put the XML in the message */ &msg.setxmldoc(&xmlDoc); /* send the request */ &response = %IntBroker.SyncRequest(&msg);
On the Node Definitions-Connectors tab, set the Connector ID to FTPTARGET.
Property |
Value |
HOSTNAME |
Specify the IP address or name of the FTP server for the connection. |
METHOD |
PUT |
USERNAME |
Enter the FTP server login ID. |
PASSWORD |
Enter the password for the login to the FTP server. This password must be encrypted. Use the Password Encryption Utility at the bottom of the page to encrypt the password, if necessary |
Login to the FTP server and check for the file. Open the file and verify the contents.
Downloading Files From FTP ServersTo download a file from an FTP server:
Create an XML file with the following contents and place the file on an FTP server.
<?xml version="1.0"?> <ConnectorTest> <TestNode>This message will be downloaded from an FTP server.</TestNode> </ConnectorTest>
&msg = CreateMessage(Operation.EXAMPLE_SERVICE_OPR); &xmldata = "<?xml version='1.0'?><ConnectorTest/>"; /* create an XmlDoc */ &xmlDoc = CreateXmlDoc(&xmldata); /* put the XML in the message */ &msg.setxmldoc(&xmlDoc); /* send the request */ &response = %IntBroker.SyncRequest(&msg); /* display the contents */ &xmlDoc = &response.getxmldoc(); MessageBox(0, "", 0, 0, &xmlDoc.genxmlstring());
Property |
Value |
HOSTNAME |
METHOD |
GET |
FILENAME |
Specify the name of the file. |
USERNAME |
PASSWORD |
The contents of the XML file will display in the message box.
Example 8: Using the SMTP Target ConnectorThis section provides an example of how to use the Simple Mail Transfer Protocol (SMTP) target connector to send an email message using an SMTP server.
PrerequisitesFor this example, you must have an active SMTP server as well as an active email account to receive the message.
Sending Email Messages to SMTP ServersTo send an email message to an SMTP server using the SMTP target connector:
&msg = CreateMessage(Operation.EXAMPLE_SERVICE_OPR); &xmldata = "<?xml version='1.0'?><ConnectorTest/>"; /* create an XmlDoc */ &xmlDoc = CreateXmlDoc(&xmldata); &rootNode = &xmlDoc.documentelement; &descNode = &rootNode.addelement("SMTPtest"); &descNode.nodevalue = "This xml will appear in the email"; /* put the XML in the message */ &msg.setxmldoc(&xmlDoc); /* send the request */ &response = %IntBroker.SyncRequest(&msg);
On the Node Definitions-Connectors tab, set the Connector ID to SMTPTARGET.
Property |
Value |
DestEmailAddress |
Set this property to the email address to which the email will be sent. |
SourceEmailAddress |
Set this property to the email address from which you are sending the message. |
Access the integrationGateway.properties file. Locate the following line and replace <mailServerName> with the name of the SMTP server.
ig.connector.smtptargetconnector.host=<mailServerName>
In the PeopleSoft Pure Internet Architecture, open the EXAMPLE_PAGE page and click the Test button to send the message.
Check the destination email account for the message. Since the message is being passed through one or more SMTP servers, there may be some propagation delay and the message might not be received immediately.
