This preface provides an overview of the PeopleSoft Integration Broker PeopleBook.
PeopleSoft Integration Broker facilitates integrations with PeopleSoft and third-party systems. It features a services-oriented architecture that enables you to expose PeopleSoft business logic as services to PeopleSoft and third-party systems. It also allows you to consume and invoke services from other PeopleSoft and third-party systems. The PeopleSoft Integration Broker services framework supports synchronous and asynchronous messaging, and enables you to use a variety of communication protocols, while managing message structure, message content, and transport disparities
This PeopleBook describes the procedures for using PeopleSoft Integration Broker to develop and administer services. These procedures include defining services, service operations, messages, queues, routings, and transformations.
This PeopleBook also discusses developing the necessary PeopleCode to send, receive, and route service operations. It also discusses how to develop PeopleCode and XSLT code to filter, transform, and translate message content.
Though not intended for use in production environments, code examples are included throughout this PeopleBook to help illustrate technology concepts and the use of product features.
Other PeopleBooks discuss configuring and administering the integration system, monitoring integrations, and testing integrations.
See Also
PeopleTools 8.52: PeopleSoft Integration Broker Administration PeopleBook
PeopleTools 8.52: Integration Broker Service Operations Monitor PeopleBook
PeopleTools 8.52: Integration Broker Testing Tools and Utilities PeopleBook
PeopleBooks and the PeopleSoft Online LibraryA companion PeopleBook called PeopleBooks and the PeopleSoft Online Library contains general information, including:
Understanding the PeopleSoft online library and related documentation.
How to send PeopleSoft documentation comments and suggestions to Oracle.
How to access hosted PeopleBooks, downloadable HTML PeopleBooks, and downloadable PDF PeopleBooks as well as documentation updates.
Understanding PeopleBook structure.
Typographical conventions and visual cues used in PeopleBooks.
ISO country codes and currency codes.
PeopleBooks that are common across multiple applications.
Common elements used in PeopleBooks.
Navigating the PeopleBooks interface and searching the PeopleSoft online library.
Displaying and printing screen shots and graphics in PeopleBooks.
How to manage the locally installed PeopleSoft online library, including web site folders.
Understanding documentation integration and how to integrate customized documentation into the library.
Application abbreviations found in application fields.
You can find PeopleBooks and the PeopleSoft Online Library in the online PeopleBooks Library for your PeopleTools release.
