This book discusses PeopleSoft Query, a tool that you use to retrieve selected data from the database.
PeopleSoft QueryPeopleSoft Query is an end user reporting tool. This book explains the basic concepts of selecting data, designing simple and complex queries, and sending query results to other reporting tools.
To take full advantage of the information covered in this book, you should be comfortable using Microsoft Windows and should have a basic familiarity with relational database concepts and SQL. In addition, this book assumes that you have a basic understanding of how to use PeopleSoft applications and are familiar with PeopleTools.
PeopleBooks and the PeopleSoft Online LibraryA companion PeopleBook called PeopleBooks and the PeopleSoft Online Library contains general information, including:
Understanding the PeopleSoft online library and related documentation.
How to send PeopleSoft documentation comments and suggestions to Oracle.
How to access hosted PeopleBooks, downloadable HTML PeopleBooks, and downloadable PDF PeopleBooks as well as documentation updates.
Understanding PeopleBook structure.
Typographical conventions and visual cues used in PeopleBooks.
ISO country codes and currency codes.
PeopleBooks that are common across multiple applications.
Common elements used in PeopleBooks.
Navigating the PeopleBooks interface and searching the PeopleSoft online library.
Displaying and printing screen shots and graphics in PeopleBooks.
How to manage the locally installed PeopleSoft online library, including web site folders.
Understanding documentation integration and how to integrate customized documentation into the library.
Application abbreviations found in application fields.
You can find PeopleBooks and the PeopleSoft Online Library in the online PeopleBooks Library for your PeopleTools release.
