This preface provides an overview of the contents discussed in the System and Server Administration PeopleBook and discusses PeopleBooks and the Online PeopleSoft Library.
System and Server AdministrationThis book includes several chapters relating to administration tools for the PeopleSoft application server, and web servers. It also contains information about building and maintaining search indexes, database level auditing, and PeopleTools utilities.
Note. PeopleSoft supports a number of versions of UNIX and Linux in addition to Microsoft Windows. Throughout this book, there are references to operating system configuration requirements. Where necessary, this book refers to specific operating systems by name (for example, Solaris, HP/UX, Linux, and so on). However, for simplicity the word UNIX is used to refer to all UNIX-like operating systems, including Linux.
PeopleBooks and the PeopleSoft Online LibraryA companion PeopleBook called PeopleBooks and the PeopleSoft Online Library contains general information, including:
Understanding the PeopleSoft online library and related documentation.
How to send PeopleSoft documentation comments and suggestions to Oracle.
How to access hosted PeopleBooks, downloadable HTML PeopleBooks, and downloadable PDF PeopleBooks as well as documentation updates.
Understanding PeopleBook structure.
Typographical conventions and visual cues used in PeopleBooks.
ISO country codes and currency codes.
PeopleBooks that are common across multiple applications.
Common elements used in PeopleBooks.
Navigating the PeopleBooks interface and searching the PeopleSoft online library.
Displaying and printing screen shots and graphics in PeopleBooks.
How to manage the locally installed PeopleSoft online library, including web site folders.
Understanding documentation integration and how to integrate customized documentation into the library.
Application abbreviations found in application fields.
You can find PeopleBooks and the PeopleSoft Online Library in the online PeopleBooks Library for your PeopleTools release.
