This chapter contains an overview, and discusses how to:
Use the Application Server Administration menu.
Use the PeopleSoft Process Scheduler menu.
Use the PeopleSoft Search Server menu (Verity).
Use the PeopleSoft Web Server (PIA) menu.
Switch PS_CFG_HOME.
Set up the PeopleSoft Windows service.
Replicate PS_CFG_HOME.
Understanding PSADMIN MenusYou use PSADMIN to manage all of the main PeopleSoft server types. After launching PS_HOME\appserv\psadmin.exe from the command line, the PeopleSoft Server Administration (PSADMIN) main menu appears.
-------------------------------- PeopleSoft Server Administration -------------------------------- Config Home: D:\PT_SERVER\8.52 1) Application Server 2) Process Scheduler 3) Search Server 4) Web (PIA) Server 5) Switch Config Home 6) Service Setup 7) Replicate Config Home q) Quit Command to execute (1-7, q):
Config Home |
Displays the PS_CFG_HOME the current PSADMIN session. If it is not the PS_CFG_HOME desired, use the Switch Config Home option to select the appropriate location. |
Application Server |
Select to manager your application server domains. |
Process Scheduler |
Select to manager your Process Scheduler domains. |
Search Server |
Select to manager your Verity—based search server domains. Note. This menu applies only to the Verity-based search servers. It does not apply to any PeopleSoft Search Framework components. |
Switch Config Home |
Select to switch to an alternative PS_CFG_HOME location. Determine the current PS_CFG_HOME from the Config Home value displayed. |
Service Setup |
(Applies to Microsoft Windows only). Select to configure domains to start using Windows Services. |
Replicate Config Home |
Select to replicate configured PS_CFG_HOME locations so that you can share these pre-created, tuned, and configured server configurations on the local server or on remote servers. |
Using the Application Server Administration Menu
Access the application server options.
Administer a domain.
Boot a domain.
Shut down a domain.
Perform a normal shutdown.
Perform a forced shutdown.
Check the domain status.
Purge the domain cache.
Configure a domain.
Edit configuration and log files.
Create a domain.
Delete a domain.
Configure an application server domain to preload cache.
Clean domain IPC resources.
Accessing the Application Server Options
To access the menu options for configuring and administering an application server, select Application Server from the PeopleSoft Server Administration (PSADMIN) menu.
-------------------------------------------- PeopleSoft Application Server Administration -------------------------------------------- 1) Administer a domain 2) Create a domain 3) Delete a domain 4) Import domain configuration q) Quit Command to execute (1-4, q) : 4
The Administer a domain menu offers numerous configuration, administration, and logging parameters that you may access frequently.
The menu options and parameters within the Create a domain and Delete a domain menus are one-time tasks (per domain).
The Import domain configuration menu enables you to import existing configurations.
Administering a Domain
To administer a domain, you must have already created a domain. After you have created a domain, specify environment-specific settings for the application server to function correctly with your system. The following sections describe all of the menus and menu options that you use to administer and configure an application server domain.
To administer a domain:
Select Administer a domain from the PeopleSoft Application Server Administration menu.
In the Select domain number to administer command line, enter the number that corresponds to the previously created domain that you want to administer that appears in the Tuxedo domain list.
Select the option that you want to perform from the PeopleSoft Domain Administration menu.
PSADMIN transparently sets several environment variables before invoking any Tuxedo administrative commands. You don't need to set these variables manually. These environment variables are:
TUXCONFIG = PS_CFG_HOME/appserv/domain_name/PSTUXCFG
APPDIR = PS_CFG_HOME/appserv/domain_name
PATH = TUXDIR/bin; PS_HOME/bin/server/winx86; PATH
APP_PW = Application Password (initialize)
Importing Domain Configurations
You import existing domain configurations by selecting the Import domain configuration option from the PeopleSoft Application Server Administration menu. From the PeopleSoft Import Application Server Configuration menu, you have the option to import a regular domain or an Integration Broker Master Configuration.
-------------------------------------------- PeopleSoft Import Application Server Configuration -------------------------------------------- 1) Import regular domain 2) Import IB Master Configuration q) Quit Command to execute (1-2, q) : 1
Importing a Regular Application Server Domain
When importing a regular application server domain, you can import from a file or from a domain.
-------------------------------------------- PeopleSoft Import Application Server Configuration -------------------------------------------- 1) Import from file 2) Import from application domain q) Quit Command to execute (1-2, q) :
To import configuration settings from a file:
From the PeopleSoft Import Application Server Configuration menu, select Import from file.
Enter the complete file path to the PSAPPSRV.CFG file containing the desired configuration settings.
For example,
c:\documents and settings\TSAWYER.DOMAINX\PSFT\PT\8.52\appserv\appserv\PT850TST
Enter a name for the new domain.
To import configuration settings from an existing domain:
From the PeopleSoft Import Application Server Configuration menu, select Import from application domain.
Enter the path to the appropriate PS_CFG_HOME.
For example,
From the Tuxedo domain list, select the domain containing the desired configuration settings.
Importing an Integration Broker Master Configuration
Use this option to import a master configuration, if you are implementing a "master-slave" integration server configuration. This implementation option is documented in detail within the Integration Broker Administration PeopleBook.
See Implementing Master-Slave Dispatchers.
Booting a Domain
This boots the Tuxedo domain (the application server) by using the tmboot command. This command will start all of the server processes that have been configured for your domain.
------------------------------- PeopleSoft Domain Boot Menu ------------------------------- Domain Name: DOC 1) Boot (Serial Boot) 2) Parallel Boot q) Quit Command to execute (1-2, q) [q]:
You have two booting options: a serial boot and a parallel boot.
Running a Serial Boot
A serial boot starts server processes in a sequential order, with one process beginning to start after the previous process has completely started.
Running a Parallel Boot
A parallel boot starts server processes at the same time, rather than having each process start sequentially. This option typically provides shorter boot durations.
Shutting Down a Domain
The PeopleSoft Domain Shutdown menu offers two options: a normal shutdown and a forced shutdown.
------------------------------- PeopleSoft Domain Shutdown Menu ------------------------------- Domain Name: psdmo 1) Normal shutdown 2) Forced shutdown q) Quit Command to execute (1-2, q) [q]:
A normal shutdown is a quiescent shutdown that waits for users to complete their tasks and turns away new requests before terminating all of the processes in the domain.
A forced shutdown is a nonquiescent shutdown that immediately terminates all of the processes in the domain. Normally, you use the forced shutdown only when a Bulletin Board Liaison (BBL) process encounters errors and cannot be shut down by using a normal shutdown.
Note. The BBL is a primary Tuxedo process that controls the domain.
Checking the Domain Status
Use the PeopleSoft Domain Status menu to view the status of the server, queues, or clients connected to the domain.
----------------------------- PeopleSoft Domain Status Menu ----------------------------- Domain Name: psdmo 1) Server status 2) Client status 3) Queue status q) Quit Command to execute (1-3, q) [q]:
Server Status
Select Server status to invoke the Tuxedo tmadmin psr subcommand (print server processes), which displays the Tuxedo processes and PeopleSoft server processes that are currently running. For example:
> Prog Name Queue Name Grp Name ID RqDone Load Done Current Service --------- ---------- -------- -- ------ --------- --------------- BBL.exe 62645 RTDC796+ 0 42801 2140050 ( IDLE ) PSAPPSRV.exe APPQ APPSRV 1 422 21100 ( IDLE ) PSMONITORSRV.e MONITOR MONITOR 1 0 0 ( IDLE ) PSWATCHSRV.exe WATCH WATCH 1 0 0 ( IDLE ) PSAPPSRV.exe APPQ APPSRV 2 4 200 ( IDLE ) JSL.exe 00095.00200 JSLGRP 200 0 0 ( IDLE ) PSMSGDSP.exe 00098.00100 PUBSUB 100 4 200 ( IDLE ) PSSAMSRV.exe SAMQ APPSRV 100 0 0 ( IDLE ) PSMSGHND.exe MBHQ PUBSUB 101 0 0 ( IDLE ) JREPSVR.exe 00094.00250 JREPGRP 250 29 1450 ( IDLE )
The number of items appearing depends on the number of server processes that you have configured.
Client Status
Select Client status to invoke the Tuxedo tmadmin pclt subcommand (printclient), which displays connected users. For example:
> LMID User Name Client Name Time Status Bgn/Cmmt/Abrt --------------- --------------- --------------- -------- ------- ------------- RTDC79623VMC NT JSH **:**:** IDLE 0/0/0 RTDC79623VMC NT JSH **:**:** IDLE 0/0/0 RTDC79623VMC JPOOL_15 dhcp-adc-twvpn+ 0:02:03 IDLE/W 0/0/0 RTDC79623VMC NT tmadmin 0:00:00 IDLE 0/0/0
Queue Status
Examining the status of the individual queues for each server process provides valuable tuning information. Check the queues by using the Queue status option. In the following example, the results of the Queue status option show the individual server processes, the associated queue, the number of server processes currently running, and the number of requests waiting to be processed:
> Prog Name Queue Name # Serve Wk Queued # Queued Ave. Len Machine --------- ------------------- --------- -------- -------- ------- PSAPPSRV.exe APPQ 2 - 0 - RTDC79623+ JSL.exe 00095.00200 1 - 0 - RTDC79623+ JREPSVR.exe 00094.00250 1 - 0 - RTDC79623+ BBL.exe 62645 1 - 0 - RTDC79623+ PSMONITORSRV.e MONITOR 1 - 0 - RTDC79623+ PSWATCHSRV.exe WATCH 1 - 0 - RTDC79623+ PSSAMSRV.exe SAMQ 1 - 0 - RTDC79623+ PSMSGHND.exe MBHQ 1 - 0 - RTDC79623+ PSMSGDSP.exe 00098.00100 1 - 0 - RTDC79623+
The results alert you to any bottlenecks that may be occurring on your application server. With this information, you can make more informed performance decisions. For instance, if the bottlenecks appear to be persistent, it may indicate that you need to add more instances of a particular server process, such as PSAPPSRV for example. Or the results may indicate that you need to start either a PSQCKSRV or a PSQRYSRV.
Purging the Domain Cache
A proven technique for resolving problem application server environments is to purge the application server domain cache located in PS_CFG_HOME\appserv\domain_name\CACHE.
Important! You should purge the cache only after due consideration, and in after consultation with PeopleSoft support or consultants.
Please keep the following in mind:
You cannot purge shared file cache.
You can purge the cache regardless of whether the application server domain is running; there's no need to shut it down and reboot. However, the procedure is less disruptive and runs more quickly if the domain is shut down or its activity level is low.
Purging the cache can take five minutes or more on a large or busy domain, depending on the domain configuration.
If database cache is enabled, the database cache will be purged. If the database cache is purged, it affects all domains using that cache. The database cache is shared across all domains that use the same byte-order (little-endian or big-endian).
To purge the domain cache:
On the PeopleSoft Domain Administration menu, select Purge Cache.
If the cache is currently empty, the purge operation is cancelled, and the PeopleSoft Domain Administration menu reappears.
If the cache is not empty, the following prompt appears:
Enter log comments about this purge, if any (maximum 256 characters):
Enter any information (up to 256 characters) that you want recorded explaining the circumstances of this cache purge operation, and press Enter. Your comments will be saved to a purge log file.
The following prompt appears:
Do you wish to archive the contents of the current cache? (y/n) [n] :
Enter y to archive the cache contents, or n to delete them permanently. The default response is n.
If you enter y, the following prompt appears:
Cache contents will be archived to PS_CFG_HOME\appserv\domain_name\Archive\CACHE_mmddyy_hhmm_ss. Hit Enter to continue or provide a new location:
Note. At runtime, PS_CFG_HOME and domain_name are replaced with values appropriate to your system, and mmddyy_hhmm_ss represents the date and time of the cache purge operation.
(If you chose to archive the cache contents) Enter a different archive location if desired, and press Enter.
If the location you enter is rejected, the following message appears, and you're prompted to continue:
Failed to archive cache to location.
Note. Continuing this procedure with an invalid location will purge the cache without archiving.
The default location is a unique directory name. Keep in mind that the location you enter might have been rejected for the following reasons:
The directory can't be created due to an invalid drive or network mount.
The directory can't be created due to insufficient user privileges.
The directory has insufficient space for the cache files.
When prompted to continue, enter y to continue the purge operation, or n to cancel the operation and return to the PeopleSoft Domain Administration menu.
Note. Archiving the cache increases the time required to complete the purge, because the cache files must be copied to the archive location.
If the application server domain is running, you might see INFO: messages related to version, patch level, serial number and so on. These are normal and don't require any action. When the cache is successfully purged, the following message appears:
Purge Cache operation completed successfully. You may notice that the cache directory is non-empty. Cache files have been⇒ invalidated and will be refreshed from the database.
If the cache was archived, you'll also see the following:
You may also have noticed a number of Sharing Violation messages during the Cache⇒ Purge. These messages are no cause for alarm and are expected as part of the cache⇒ archival.
If the application server domain is running, an entry is written to the application server log file to indicate that the cache has been purged.
The purge log file is saved (including any comments you entered in step 2) as PS_CFG_HOME\appserv\domain_name\LOGS\PurgeCache_mmddyy_hhmm_ss.log.
Following is an example of the purge log file contents:
Date:02/17/10 11:47 User Explanation: Processes appeared to take a long time to recycle. Cache Contents archived to C:\ptservers\appserv\QEDMO\Archive\CACHE_021710_1147_01
Configuring a Domain
This option prompts you with a model configuration file to gather such parameters as port numbers, the number of various server processes that are needed, encryption enabling, and so forth. PSADMIN then invokes a subprogram, UBBGEN, which takes the configuration parameters, builds the file PS_CFG_HOME/appserv/domain-name/psappsrv.ubb, and carries out the tmloadcf - y psappsrv.ubb command to generate the following file: PS_CFG_HOME/appserv/domain-name/PSTUXCFG.
The following topics describe all of the parameters that you encounter while configuring an application server. Either read this section before you fine tune the configuration of your application server or have it available while you are doing it.
To configure a domain:
Select Configure this domain from the PeopleSoft Domain Administration menu.
Enter n (No), if you do not want to continue. This returns you to the previous menu. Otherwise, enter y (Yes).
When prompted to change configuration values, enter y.
If you don't need to change any of the values, enter n. By doing so, you create a new configuration file with the same values that were previously specified. Enter n, or elect not to modify the PSADMIN parameters, if:
You have changed only the location of TUXDIR.
You would rather edit the PSAPPSRV.CFG file manually.
You installed a new Tuxedo patch.
Note. If you edit the psappsrv.cfg file directly, it is recommended to reload your domain configuration. This is necessary because some settings in psappsrv.cfg are transferred to the PSTUXCFG file for the domain. This transfer of settings can only be achieved by running UBBGEN and tmloadcf, which the "Configure this domain" option performs.
Editing Configuration and Log Files
Use the Edit Configuration/Log Files menu to view the application server and Tuxedo log files. You can also manually edit the PSAPPSRV.CFG file if you do not want to use the PSADMIN interface.
To have PSADMIN start your text editor (such as Notepad or KEDIT) so that you can manually edit or view application server configuration and log files, you must specify the text editor in the environment settings. For example, to use KEDIT, the editor environment setting should look like this:
set EDITOR=c:\apps\kedit\keditw32.exe
To use Notepad, it should look like this:
set EDITOR=c:\Windows\Notepad.exe
Note. You can view and edit a domain's PSAPPSRV.CFG file while the domain is running, but the changes that you specify do not take effect until the next time you reconfigure the domain.
For the following options, you must enter your operator ID to view and edit the files:
Edit PSAPPSRV.tracesql (PSAPPSRV SQL trace file) Edit PSSAMSRV.tracesql (PSSAMSRV SQL trace file)
For example:
Command to execute (1-7, q) [q]: 5 Enter the operator ID : PTXYZ
Note. PeopleSoft secures the Structured Query Language (SQL) traces because, in some instances, the SQL that is traced may involve sensitive information.
Note. Server configuration files (.CFG) support the use of environment variables, such as %PS_HOME%, %TEMP%, and so on.
Edit PSAPPSRV.CFG
The PSAPPSRV.CFG file contains all of the configuration settings for an application server domain. The PSADMIN interface provides prompts so that you can edit and modify this file within a structured format. In many cases, and perhaps due to personal preference, you may opt to edit the PSAPPSRV.CFG file manually in a text editor. When editing this configuration file manually, note that it is similar to editing an INI file, because all of the parameters are grouped in sections.
Edit APPSRV.LOG
This log file contains PeopleTools specific logging information.
Edit TUXLOG
The TUXLOG file enables you to trace the Tuxedo component for troubleshooting information.
You can specifically trace the activity of the PSAPPSRV server process by setting the PSAPPSRV.tracesql option.
You can specifically trace the activity of the PSSAMSRV server process by setting the PSSAMSRV.tracesql option.
Creating a Domain
The Create a domain option creates a subdirectory under PS_CFG_HOME/appserv using the domain name you specify as the directory name and copies the required domain files to that directory.
To create an application server domain:
Select Create a domain from the PeopleSoft Application Server Administration menu.
Enter the name of the domain that you want to create; the name must not exceed eight characters.
Select a configuration template from the Configuration template list.
The configuration templates are preconfigured sets of application server processes.
Deleting a Domain
Use the Delete a domain option to shut down the domain, if running, and delete the domain's subdirectory.
Note. Before you delete a domain, make sure that it is not running.
To delete a domain:
Select Delete a domain from the PeopleSoft Application Server Administration menu.
From the Tuxedo domain list, select the number that corresponds to the domain that you want to delete.
When prompted to continue, enter y and press Enter.
If the application server domain is currently running, PSADMIN informs you of that, and you will need to determine if you want to continue.
Domain processes are currently running. This option will shutdown and delete the domain. Do you want to continue? (y/n) [n] :
If you enter y, PSADMIN performs a forced shutdown on the domain prior to deleting the domain.
If you enter n, PSADMIN returns you to the PeopleSoft Application Server Administration menu, allowing you to shutdown the domain manually, if needed.
Configuring an Application Server Domain to Preload Cache
This section provides an overview and discusses how to:
Create cache projects.
Delete cache projects.
Preloading File Cache.
See ServerCacheMode.
See Load Application Server Cache.
Understanding Preload Cache Projects
To improve performance, the application server uses a caching mechanism that keeps commonly used objects in memory and either file form on the application server or in a database cache. Caching reduces the need for a complete database query each time a definition is accessed. As more definitions are accessed, more data becomes stored in the cache. However, if a page, for example, has not already been accessed, it does not exist in the current cache, and the user may experience a slower response time as the system requests the page from the database for the first time. To prevent this initial performance degradation, you can preload file, database, and memory cache with commonly used definitions inserted into a cache project.
Preloading cache involves creating a project containing commonly used definitions and then referring to these projects in the PSADMIN settings PreloadMemoryCache and PreloadCache. By default, PreloadMemoryCache and PreloadCache are commented out because the two parameters need to be set to a specific name of a project that you create. You can set the parameters to reference separate projects. You use the Select Preload Objects page to select frequently used definitions and build the preload project containing the objects selected.
The cache project is intended to be used for a new domain, where the cache is not yet built. Prior to providing the domain for production use, use the Preload Cache PSADMIN option to build the cache containing the objects specified in the project. The domain starts the PSAPPSRV process, builds the cache, and shuts down.
The memory cache project is intended to be used during a server process recycle. When a the system starts a new process to replace an old one, the new process loads memory cache based on the project specified by PreloadMemoryCache so that the new process will not have delays when processing the first few service requests. Because it is desirable to have new processes start as quickly as possible, there is a timeout (or limit) of 60 seconds for PreloadMemoryCache. That is, PreloadMemoryCache preloads as many definitions as possible before the timeout of 60 seconds.
Note. In general, it is not recommended to create large projects for the PreloadMemoryCache project. For all cache projects (used for file, database, and memory cache) the optimum selections for the projects will require tuning and testing at your site.
Creating Cache Projects
To create cache projects:
In a browser, select PeopleTools, Utilities, Administration, PreLoad Cache, Select Preload Objects.
Select the Add a New Value tab, and in the Project Name edit box, enter the name of the project that will contain the definitions you select, and click Add.
Note. All project names used to contain definitions for preloaded cache must contain the "PLC_" prefix.
On the Select Preload Objects page, enter a Description, and select the Object Type to add.
Object Type refers to the definitions you create with PeopleTools, such as components, menus, pages, Application Engine programs, and so on.
Use the Key fields, to refine the selection of the definition as needed.
The keys will differ depending on the Object Type selected.
Note. Project definitions support up to four keys for identification, so you can use up to four keys when selecting objects for the preload cache project.
Click Save.
Click Build Project Definition.
On the Process Scheduler Request page, click OK.
This invokes an Application Engine program (PTCHPLC_PRJ) that creates the project definition in the database and populates it with the definitions you selected. The PTCHPLC_PRJ also automatically includes all related definitions in the project.
Note. Cache projects can be created manually in Application Designer, without running the PTCHPLC_PRJ program. The project name must include "PLC_".
Deleting Cache Projects
To delete a preload file cache project:
Select PeopleTools, Utilities, Administration, Preload Cache, Delete Preload Project.
On the Find an Existing Value page, click the appropriate project name.
On the Delete Preload Project page confirm that you have selected the appropriate project and click Delete the preload project.
Preloading Cache Projects
To preload a cache project:
Shut down the application server domain.
Edit the PSAPPSRV.CFG configuration file for the appropriate domain.
In the [Cache Settings] section, uncomment the PreloadCache= parameter, and enter the name of the pre-load project for this application server domain.
For example:
PreloadCache=PLC_PROJECTA
On the PeopleSoft Domain Administration menu in PSADMIN, select 9) Preload Cache.
When preloading cache, keep the following in mind:
Preload Cache does not work when shared caching is enabled.
If database caching is enabled, Preload Cache loads the cache project into the database cache.
Preloading Memory Cache
To preload the memory cache:
In the [Cache Settings] section, uncomment the PreloadMemoryCache= parameter, and enter the name of the preload project that should be preloaded on this application server for memory cache.
For example:
PreloadMemoryCache=PLC_PROJECTB
See Also
Cleaning Domain IPC Resources
Use the Clean IPC Resources of this domain option to clear the interprocess communication (IPC) resources utilized by a domain. When a domain shuts down normally, the IPC resources it was using get released as part of the shut down process. However, if a domain terminates abnormally, in many cases the IPC resources are still assigned to the previous domain instance. This option enables you to clean any orphaned IPC resources assigned to a domain.
Using the Process Scheduler Menu
PeopleSoft Process Scheduler is used to schedule and run batch processes against the database. Process Scheduler domains are managed by Tuxedo, just as application server domains are. You only need to configure PeopleSoft Process Scheduler on a server where you intend to run batch processes. The menu options are identical to those provided for administering an application server domain, except where the options are not applicable to a Process Scheduler domain.
-------------------------------------------- PeopleSoft Process Scheduler Administration -------------------------------------------- Domain Name: QEDMO 1) Boot this domain 2) Domain shutdown menu 3) Domain status menu 4) Configure this domain 5) TUXEDO command line (tmadmin) 6) Edit configuration/log files menu 7) Clean IPC resources of this Domain q) Quit Command to execute (1-7, q) :
The Process Scheduler PSADMIN options differ from the application server PSADMIN options for these items.
Function |
Difference |
Booting |
The Process Scheduler domain boot does not provide the option to select a serial or parallel boot. All Process Scheduler domains start in serial mode. |
Viewing//Editing log files and configuration files |
The Process Scheduler Edit/View Configuration/Log Files Menu does not display options for viewing the PSAPPSRV and PSSAMSRV SQL trace files. |
Configuring Integration Broker (messaging) servers |
For Process Scheduler domains there is no option to import a Master IB Domain nor is there the option to configure messaging servers. |
Caching |
For Process Scheduler domains there are not options to purge or preload file cache. |
All of the Process Scheduler server configuration information for a specific domain is contained in the PSPRCS.CFG file, and PSADMIN provides an interface for and prompts you to edit the PSPRCS.CFG file.
Although you typically edit the PSPRCS.CFG file through PSADMIN, you can find the PSPRCS.CFG file in the following directory:
Windows: PS_CFG_HOME\APPSERV\PRCS\domain
UNIX: PS_CFG_HOME/appserv/prcs/domain
See Also
Using the Search Server MenuIf you are setting up a remote search domain for Verity, you use the Search Server menu options to configure your search domain. The configuration and administration options used in implementing a search domain are identical to those used in setting up an application server domain.
Important! You use the Search Server menu to configure remote search domains for the Verity search engine only. These options to not apply to any Oracle Secure Enterprise Search (SES) components.
See Also
Configuring Verity Search Options
Using the Web (PIA) Server Menu
Access the PeopleSoft web server options.
Create a PIA domain.
Delete a PIA domain.
Boot a PIA domain.
Shut down a PIA domain.
Check PIA domain status.
Configure a PIA domain.
Edit PIA configuration files.
View PIA log files.
Administer a PeopleSoft site.
Delete a PeopleSoft site.
Manage Windows Services to start PIA domains.
Understanding PeopleSoft Web Server Administration Using PSADMINUsing PSADMIN you can complete the majority of the web server administrative tasks related to your PeopleSoft Internet Architecture installation. While you can perform these tasks outside PSADMIN, using PSADMIN provides a centralized interface from which you can install, delete, configure, tune, and manage your PeopleSoft web domains and PeopleSoft sites.
For example, you can install PeopleSoft Internet Architecture domains and sites using the PeopleSoft install program (setup.exe), but you would need to run a separate BAT or SH file to start it, and navigate to log files manually to confirm it has started. Using PSADMIN you can install the domain and site, but also configure that domain, boot that domain, confirm it has started, and view log files all from the same interface. The centralized PSADMIN options provide a convenient alternative for system administrators.
Important! By default, the system installs your PeopleSoft Internet Architecture installation within the current PS_CFG_HOME location on the web server host. If you have the PIA_HOME environment variable set, this overrides the use of PS_CFG_HOME for PIA installations.
Note. PSADMIN only manages single-server PIA installations. If you intend to implement multi-server installations, those need to be created and managed using traditional methods, such as the PsMpPIAInstall program and the delivered scripts for starting and stopping domains.
See Also
PeopleTools 8.52 Installation for your platform
Accessing the Web Server OptionsTo access the PSADMIN web server options, select 4) Web (PIA) Server from the main PeopleSoft Server Administration menu.
----------------------------- PeopleSoft PIA Administration ----------------------------- PIA Home: D:\PT_SERVER\8.52 1) Administer a domain 2) Create a domain 3) Delete a domain q) Quit Command to execute:
PIA Home |
Displays the location of your PeopleSoft Internet Architecture domains. The default location is PS_CFG_HOME. If your application server and web server run on the same machine, they will share the PS_CFG_HOME location, by default. |
Create a domain |
Select to create a PeopleSoft Internet Architecture domain. |
Delete a domain |
Select to delete a PeopleSoft Internet Architecture domain |
Creating a PIA DomainYou create a PIA domain by selecting Create a domain from the PeopleSoft PIA Administration menu.
--------------------------------------------- PeopleSoft PIA Administration - Create Domain --------------------------------------------- PIA Home: D:\PT_SERVER\8.52 1) Create a domain 2) Replicate a domain q) Quit Command to execute:
Creating a Domain
Creating a PIA domain using PSADMIN provides an option to using the PeopleSoft Multiplatform PIA install program.
Note. You cannot create a multi-server PIA installation using PSADMIN.
--------------------------------------------- PeopleSoft PIA Administration - Create Domain --------------------------------------------- PIA Home: D:\PT_SERVER\8.52 1) Domain name :[peoplesoft] 2) Web server :[weblogic] 3) Web server root directory :[c:\oracle] 4) Web server login id :[system] 5) Web server password :[Passw0rd] 6) Website name :[ps] 7) Application server :[RTDC79623VMC] 8) JSL Port :[9000] 9) HTTP Port :[80] 10) HTTPS Port :[443] 11) Authentication Token Domain :[] 12) Web profile :[PROD] 13) Web profile user id :[PTWEBSERVER] 14) Web profile password :[PTWEBSERVER] 15) PeopleSoft reports directory :[c:\psreports] c) Create the domain as shown q) Quit Command to execute:
Enter the number of the menu option to edit the values.
PIA Home |
Ensure that the appropriate location is displayed. By default, PSADMIN installs the PIA domain into the PS_CFG_HOME environment setting. |
Domain name |
Enter the name for your domain, such as PeopleSoft_HR. |
Web server |
Select the appropriate web server type. Enter 2 to toggle between weblogic and websphere. |
Web server root directory |
Enter the location where you have installed your web server, such as D:\oracle\WebLogic103464bit. |
Web server login id |
Enter the administrative user ID for logging into the web server. This would be the same user ID you use to log in to the administrative console. |
Web server password |
Enter the password associated with the web server login ID. |
Website name |
Enter the name of the initial website, such as PSHR. Note. Using PSADMIN you can only add one site. To add additional sites, you need to use the PsMpPIAInstall program. |
Application server |
Enter the application server host machine, such as SERVER01. |
JSL port |
Enter the JSL port on which the appropriate application server domain listens for Jolt requests. |
HTTP port |
Enter the HTTP port for your web server installation |
HTTPS port |
Enter the HTTPS port for your web server installation. |
Authentication Token Domain |
Enter the domain used for your authentication tokens, if implemented, such as .yourcompany.com. See PeopleTools 8.52 Installation for <your platform>: "Setting Up the PeopleSoft Pure Internet Architecture in GUI Mode," Using Authentication Domains in the PeopleSoft Pure Internet Architecture Installation See PeopleTools 8.52 PeopleBook: PeopleTools Portal Technologies, "Configuring the Portal Environment," Understanding the Authentication Domain |
Web profile |
Choose the name of the web profile you intend to use. A web profile is a named group of configuration property settings that the portal applies throughout your PeopleSoft system to control all portal-related behavior. The web profile name will be used to configure this web site. You can specify one of the predelivered web profiles, PROD, DEV, TEST, or KIOSK. See PeopleTools 8.52 PeopleBook: PeopleTools Portal Technologies, "Configuring the Portal Environment," Configuring Web Profiles |
Web profile user ID |
Enter the user ID associated with the web profile you've entered. |
Web profile password |
Enter the password associated with the web profile user ID. |
PeopleSoft reports directory |
Specify the root directory for the Report Repository, where Process Scheduler writes report output. Make sure that the report repository directory is shared. The user that starts PIA must have write access to the Report Repository directory. |
Replicating a Domain
Replicating a PIA domain enables you to copy a PIA domain configuration from another location into the current PS_CFG_HOME. This enables you to tune and configure a single PIA domain, and replicate that configuration in multiple locations. Or, you may simply need to move a configuration to a newer or different server.
Note. You can copy domains from one operating system to another, as in from Windows to Linux, but you cannot copy domains between web server types, as in from Oracle WebLogic to IBM WebSphere.
--------------------------------------------- PeopleSoft PIA Administration - Create Domain --------------------------------------------- PIA Home: D:\PT_SERVER\8.52 1) Source Domain home :[D:\PT_SERVER\8.52] 2) Source Domain name :[PSHR1] 3) Target Domain name :[PSHR2] 4) Target Web server :[weblogic] 5) Target Web server home :[c:\oracle] 6) Target Web server user id :[system] 7) Target Web server password :[Passw0rd] 8) PeopleSoft reports directory :[c:\psreports] r) Replicate the domain as shown q) Quit Command to execute:
Source Domain home |
Enter the PS_CFG_HOME where the domain you want to copy is installed.
Note. The source domain home can be on the local host or a remote host. |
Source Domain name |
Enter the name of the domain to replicate. |
Target Domain name |
Enter the name for the new, replicated domain. Note. The name must be unique if you are replicating within the same PS_CFG_HOME. |
Target Web server |
Specify the web server type installed on both the target and source host. Enter 4 to toggle between weblogic and websphere. |
Target Web server home |
Enter the location where the web server software is installed. |
Target Web server user ID |
Enter the administrative user ID for the target web server (the user ID used to login to the administrative console). |
Target Web server password |
Enter the password associated with the administrative user ID on the target web server. |
Enter the location of the Report Repository on the target web server. |
Deleting a PIA DomainYou delete PIA domains by selecting Delete a domain from the PeopleSoft PIA Administration menu.
------------------------------------------------------ PeopleSoft PIA Domain Administration - Choose a Domain ------------------------------------------------------ 1) PT852802 2) ptools852 q) Quit Command to execute:
To delete a PIA domain:
From the PeopleSoft PIA Administration menu, select 3) Delete a domain.
From the PeopleSoft PIA Domain Administration - Choose a Domain menu, select the PIA domain to delete.
When prompted to continue, enter y.
View the screen messages to verify the system has deleted the domain successfully.
------------------------------------------------------ PeopleSoft PIA Domain Administration - Choose a Domain ------------------------------------------------------ 1) PT852802 2) ptools852 q) Quit Command to execute: 1 This operation will delete the configuration files for the domain. If the domain is currently running it will be stopped. Do you want to continue? [Y/N]: y Verifying domain status.................................... Removing the domain.................................. The domain has been removed.
Booting a PIA DomainTo boot a PIA domain:
From the PeopleSoft PIA Administration menu, select 1) Administer a domain.
Choose the PIA domain from the domain list.
From the PeopleSoft PIA Domain Administration menu, select 1) Boot this domain.
This will boot the domain and verify its status.
View the screen messages to verify the system has booted the domain successfully.
------------------------------------ PeopleSoft PIA Domain Administration ------------------------------------ PIA Home: D:\PT_SERVER\8.52 PIA Domain: ptools852 1) Boot this domain 2) Shutdown this domain 3) Get the status of this domain 4) Configure this domain 5) Edit configuration files 6) View log files 7) Administer a site 8) Delete a site 9) Windows Service Setup q) Quit Command to execute: 1 Starting the domain................ Server state changed to STARTING................ Server state changed to STANDBY. Server state changed to STARTING................ . Server state changed to ADMIN. Server state changed to RESUMING.. Server state changed to RUNNING. Verifying domain status.............. The domain has started.
Note that the subsequent display of the PeopleSoft PIA Domain Administration menu indicates Domain Status: started.
------------------------------------ PeopleSoft PIA Domain Administration ------------------------------------ PIA Home: D:\PT_SERVER\8.52 PIA Domain: ptools852 Domain Status: started 1) Boot this domain 2) Shutdown this domain 3) Get the status of this domain 4) Configure this domain 5) Edit configuration files 6) View log files 7) Administer a site 8) Delete a site 9) Windows Service Setup q) Quit Command to execute:
Shutting Down a PIA DomainTo shut down a PIA domain:
From the PeopleSoft PIA Domain Administration menu, select 2) Shutdown this domain.
This will stop the domain and verify its status.
View the screen messages to verify the system has shut down the domain successfully.
------------------------------------ PeopleSoft PIA Domain Administration ------------------------------------ PIA Home: D:\PT_SERVER\8.52 PIA Domain: ptools852 1) Boot this domain 2) Shutdown this domain 3) Get the status of this domain 4) Configure this domain 5) Edit configuration files 6) View log files 7) Administer a site 8) Delete a site 9) Windows Service Setup q) Quit Command to execute: 2 Stopping the domain........... Verifying domain status........................ Command to execute: Server "PIA" was force shutdown successfully ... Done
Checking PIA Domain StatusTo verify status of a PIA domain:
From the PeopleSoft PIA Domain Administration menu, select 3) Check the status of this domain.
View the Domain Status: line at the top of the menu to verify the domain status.
For example,
or
Domain Status: stopped
Configuring a PIA DomainTo configure a PIA domain, select 4) Configure this domain from the PeopleSoft PIA Domain Administration menu. You use the PeopleSoft PIA Administration - Quick Configure Domain menu to modify PIA domain settings.
------------------------------------------------------ PeopleSoft PIA Administration - Quick Configure Domain ------------------------------------------------------ PIA Home: D:\PT_SERVER\8.52 PIA Domain: ptools852 Domain Status: stopped 1) HTTP Port :[80] 2) HTTP SSL Port :[443] 3) Min Heap Size :[512m] 4) Max Heap Size :[512m] 5) Max Threads :[50] 6) Auth Token Domain :[] s) Save q) Quit Command to execute:
HTTP Port |
The HTTP port for your web server. |
HTTPS Port |
The HTTPS port for your web server. |
Min Heap Size |
The minimum JVM Heap size for the web server instance occupied by your PIA domain. Note. For WebLogic include the 'm' as in 512m, but for WebSphere exclude the 'm' as in 512. |
Max Heap Size |
The maximum JVM Heap size for the web server instance occupied by your PIA domain. Note. For WebLogic include the 'm' as in 512m, but for WebSphere exclude the 'm' as in 512. |
Max Threads |
Specify the maximum number of simultaneous transactions that the PIA domain web server instance can handle. |
Auth Token Domain |
Enter the Authentication Token Domain. See PeopleTools 8.52 PeopleBook: PeopleTools Portal Technologies, "Configuring the Portal Environment," Understanding the Authentication Domain |
After making configuration changes and saving, PSADMIN responds differently, displaying different prompts, depending on the state of your domain, and the configuration options you've modified.
Configuration Option |
Description |
Standard |
Can be modified while the server is running. A reboot is required for the change to take effect. |
Dynamic |
Can be modified while the server is running. Takes effect immediately with no reboot required. |
Volatile |
Cannot be modified while the server is running. The server must be stopped before the change can be saved. |
Editing PIA Configuration FilesTo view and edit PIA configuration files, select 5) Edit configuration files from the PeopleSoft PIA Domain Administration menu.
Note. These files are provided for informational purposes. In most cases, you will not be required to modify these files unless asked to do so by a Global Customer Support representative.
----------------------------------------------------------- PeopleSoft PIA Domain Administration - Choose a Config File ----------------------------------------------------------- 1) setEnv 2) config.xml 3) portal/weblogic.xml 4) pspc/weblogic.xml 5) logging.properties q) Quit Command to execute:
setEnv |
Opens the setEnv file in your text editor. This file contains environment properties that the system initializes when you start the web server. |
config.xml |
Opens the config.xml file for the PIA domain web server instance. The config.xml file contains numerous web server settings. |
portal/<web server type>.xml |
Opens the <web server type>.xml file associated with the PeopleSoft Internet Architecture portal deployment. |
pspc/<web server type>.xml |
Opens the <web server type>.xml file associated with the PeopleSoft Portlet Container. |
logging.properties |
Opens the logging.properties file for adjusting global and handler-specific logging levels. |
Viewing Log FilesTo view PIA domain log files, select 6) View log files from the PeopleSoft PIA Domain Administration menu.
-------------------------------------------------------- PeopleSoft PIA Domain Administration - Choose a Log File -------------------------------------------------------- 1) PIA_access.log 0 2) PIA_stderr.log 0 3) PIA_stdout.log 7951 4) PIA_weblogic.log 384999 5) ptools852.log 57793 q) Quit Command to execute:
PIA_access.log |
Opens the PIA_access.log in your text editor. |
PIA_stderr.log |
Opens the PIA_stderr.log in your text editor. |
PIA_stdout.log |
Opens the PIA_stdout.log in your text editor. |
PIA_weblogic.log |
Opens the PIA_weblogic.log in your text editor. |
<domain name>.log |
Opens the log for the current domain in your text editor. |
Administering a PIA SiteTo administer a PIA site:
From the PeopleSoft PIA Administration menu, select 7) Administer a site.
Choose the PIA site from the site list.
---------------------------------- PeopleSoft PIA Site Administration ---------------------------------- PIA Home: D:\PT_SERVER\8.52 PIA Domain: ptools852: stopped PIA Site: PT852803 1) Configure this site 2) Edit configuration file q) Quit Command to execute:
Configuring a PIA Site
To configure a PIA site, select 1) Configure this site from the PeopleSoft PIA Site Administration menu.
---------------------------------------------------- PeopleSoft PIA Administration - Quick Configure Site ---------------------------------------------------- PIA Home: D:\PT_SERVER\8.52 PIA Domain: ptools852 Domain Status: stopped PIA Site: PT852803 1) Application Server Connect String :[RTDC79623VMC:9010] 2) Jolt Pooling :[Enabled] 3) Parallel Loading :[Disabled] 4) AppServer Password :[{V1.1}6O5vpwGxd5o=] 5) Dynamic Config Reload Setting :[0] 6) Web Profile :[PROD] 7) Web User Id :[PTWEBSERVER] 8) Web Password :[PTWEBSERVER] 9) Report Repository File Path :[d:/psreports] s) Save q) Quit Command to execute:
Application Server Connect String |
Specifies the application server(s) from which this web site will accept connections if Jolt failover and load balancing is implemented. This modifies the psserver setting in the configuration.properties file. |
Jolt Pooling |
Select to toggle Jolt Pooling [Enabled | Disabled]. This modifies the joltpooling setting in the configuration.properties file. |
Parallel Loading |
To enable/disable parallel loading of pagelets, as opposed to loading them sequentially. This setting applies only if Jolt Pooling is enabled. This modifies the parallelLoading setting in the configuration.properties file. |
AppServer Password |
Set the domain connection password, which is required for connecting to the application server domain. This modifies the DomainConnectionPwd setting in the configuration.properties file. |
Dynamic Config Reload Setting |
This setting enables the psserver string (Application Server Connect String) to be reloaded dynamically. That is, the domain does not need to be restarted for the changed values to take effect. Set Dynamic Config Reload Setting to 1 enables the feature, while setting it to 0 disable the feature. Default value is 0. This modifies the DynamicConfigReload setting in the configuration.properties file. Note. This setting applies only to the Application Server Connect String. See Configuring Dynamic Reloading of the Application Server Connection String. |
Web Profile |
Specify the web profile used to store the configuration settings for this web site. This modifies the WebProfile setting in the configuration.properties file. |
Web User ID |
The user ID that the Portal uses to access the web profile. This modifies the WebUserId setting in the configuration.properties file. |
Web Password |
The user password that the Portal uses to access the web profile. This modifies the WebPassword setting in the configuration.properties file. |
Report Repository File Path |
The location of the Report Repository. Note. The system uses this setting value only if a Report Repository location is not specified in the current web profile. This modifies the ReportRepositoryPath setting in the configuration.properties file. |
Save |
After you have made your changes, select S) Save to save your changes to the PIA site. |
To edit the configuration.properties file directly in your text editor, select 1) Edit configuration file from the PeopleSoft PIA Site Administration menu.
Deleting a PIA SiteTo delete a PIA site:
From the PeopleSoft PIA Domain Administration menu, select 8) Delete a site.
Note. The domain must have at least two sites for the delete operation to succeed. If only one site exists in the domain, the system will not allow you to delete the only remaining site. A domain must contain at least one site.
When prompted to make sure you want to delete the site, enter y.
---------------------------------------------------- PeopleSoft PIA Domain Administration - Choose a Site ---------------------------------------------------- 1) PSHR 2) PT852803 q) Quit Command to execute: 1 Are you sure you want to remove the site [Y/N]: y Removing the site................. The site has been removed.
Managing Windows Services for PIA DomainsThis section discusses:
Installing a Windows Service for a PIA Domain.
Uninstalling a Windows Service for a PIA Domain.
To install a Windows Service for starting a PIA domain, select 9) Windows Service Setup from the PeopleSoft PIA Domain Administration.
To install the Windows Service, select 1) Install Service from the Windows Service Setup menu.
--------------------- Windows Service Setup --------------------- PIA Home: D:\PT_SERVER\8.52 PIA Domain: ptools852: stopped 1) Install Service 2) Uninstall Service q) Quit Command to execute: 1 Defining NT service for WebLogic admin server PIA ptools852-PIA installed.
Check the Services console to ensure the service appears.
To uninstall a Windows Service for starting a PIA domain, select 9) Windows Service Setup from the PeopleSoft PIA Domain Administration.
To uninstall the Windows Service, select 2) Uninstall Service from the Windows Service Setup menu.
--------------------- Windows Service Setup --------------------- PIA Home: D:\PT_SERVER\8.52 PIA Domain: ptools852: stopped 1) Install Service 2) Uninstall Service q) Quit Command to execute: 2 ptools852-PIA removed.
Switching Configuration Homes (PS_CFG_HOME)By default, when you install application servers, Process Scheduler servers, search servers (Verity), and PIA domains, the system installs them in the current PS_CFG_HOME location. If you do not modify or override the PS_CFG_HOME location, and you install all of these server types on the same host, all of these server types will exist and be managed by PSADMIN in the same PS_CFG_HOME location. With all of the server types installed in the same PS_CFG_HOME, you would not need to use the Switch Config Home feature. This is the recommended approach.
PSADMIN supports multiple PS_CFG_HOME locations, but you need to make sure to set the PS_CFG_HOME variable correctly before installing domains, and use the Switch Config Home option to specify the appropriate PS_CFG_HOME when performing administrative and configuration tasks.
Note. You can set the appropriate PS_CFG_HOME outside of PSADMIN manually, or from a BAT or shell script, or you can set it using the Switch Config Home feature.
To switch configuration homes:
Navigate to the main PSADMIN PeopleSoft Server Administration menu.
Select option 5) Switch Config Home.
-------------------------------- PeopleSoft Server Administration -------------------------------- Config Home: D:\HR_SERVER\8.52 1) Application Server 2) Process Scheduler 3) Search Server 4) Web (PIA) Server 5) Switch Config Home 6) Service Setup 7) Replicate Config Home q) Quit Command to execute (1-7, q): 5
At the prompt, enter the complete path to the desired PS_CFG_HOME location, and press ENTER.
Note. If the directory structure does not currently exist, PSADMIN creates it.
Please provide new Config Home location or q to quit: D:\PT_SERVER\8.52
Verify that the correct Config Home value appears on the PeopleSoft Server Administration menu.
Note. For PIA domains, you can set the PIA_HOME environment variable prior to starting PSADMIN. If this variable is set, PSADMIN recognizes it, and will install your PIA domains in the PIA_HOME location. You can switch to this location using the Switch Config Home feature.
Setting Up the PeopleSoft Windows Service to Start an Application Server
Domain
Configure the PeopleSoft service.
Test the service.
Edit the service configuration file.
Note. This section applies only to Microsoft Windows servers. It involves setting application server, Process Scheduler server, and search server domains to start as PeopleSoft Windows services.
Understanding Microsoft Windows ServicesA Microsoft Windows service is a Microsoft-standard package that automatically starts and stops a process when you boot or shut down a Windows system. You can also start and stop Microsoft Windows services manually through the Administrative Tools - Services utility, which you can access through the Control Panel. A service uses a standard application programming interface (API) so that it can interact with the Control Panel and log messages to the standard event log.
For PeopleSoft domains, the service starts in an environment that is separate from any users who are signed in to the system (or to the server machine). If using the Windows service, administrators do not need to log on to a machine, start PSADMIN, and enter the proper commands to start a domain. In addition, if you use the PeopleSoft service, an administrator's logon session does not need to remain open while the domain runs.
If you have multiple application server domains, Process Scheduler servers, or search servers on the same machine, you can start them all by using the same service setup.
Note. The PeopleSoft service supersedes the method that is provided in the Microsoft Windows resource kit. Do not use SRVANY.EXE or AT commands to start PeopleSoft domains.
Configuring the PeopleSoft Service
The following procedure assumes that you have already installed and configured a domain on the Microsoft Windows server.
After completing this procedure, the specified PeopleSoft domains start and shut down automatically when the operating system recycles.
To set up the Microsoft Windows service:
Open the System utility within the Control Panel, and make sure the following variables are set on the Environment tab in the System Variables section:
Variable |
Value |
TEMP |
Specify the location of the TEMP directory on the Microsoft Windows server, as in C:\TEMP. |
In PSADMIN utility, select Service Setup from the main menu.
Select Configure a Service from the PeopleSoft Services Administration menu.
Enter y to indicate that you want to change configuration values.
Enter the names of the application server domains, the Process Scheduler databases, or search server domains that you want to include as part of the Microsoft Windows service.
To add multiple values, separate each value with a comma and a space.
For example,
Application Server Domains=HRDOM1, HRDOM2, HRDOM3
Select Install a Service from the PeopleSoft Services Administration menu.
Note. All of the domains and databases that you specified are part of a single Windows service called PeopleSoft PS_CFG_HOME, where PS_CFG_HOME is the location of the domain installations.
Return to the Windows Control Panel, and start the Administrative Tools, Services utility.
In the Services utility, scroll to find the entry that adheres to the PeopleSoft PS_CFG_HOME naming convention and access its properties.
On the General tab of the service properties, select a startup type of Automatic.
Note. The default startup mode is Manual.
On the Log On tab, the Log On As setting must match the Log On As setting that's defined for the Oracle ProcMGR service, which was created when you installed Tuxedo.
Both services should either be configured to Log On As Local System Account, or to Log On As This Account (referring to the same account).
On the General tab of the service properties, click Start.
Note. If using a secure, remote PS_HOME, the user ID that starts the Oracle ProcMGR service and the PeopleSoft service must be same domain user ID and have sufficient privileges to at least read-execute the remote resources. Also, the TM_IPC_MAPDRIVER environment variable needs to be set appropriately. The PeopleSoft Windows Service must run under the same user id as the ProcMGR service because the PeopleSoft Windows service executes the PSADMIN command line options to start and stop domains.
See Securing PS_HOME and PS_CFG_HOME.
Service Start Failure
It's possible that one or more of the domains or databases that are configured as part of the PeopleSoft service will fail to start, for reasons unrelated to the service.
The service is marked as started even if only one of its assigned domains starts. A message is written to the Windows event log for each domain, indicating whether it has started or not. If you experience problems with any domain or database, check the event log to see if it started successfully.
If all of the assigned domains and databases fail to start, the service is marked as stopped, and the following message is written to the event log:
Unable to start any of the domains configured for service service_name.
Testing the Service
To test the Microsoft Windows service, reboot the server, and make sure that the appropriate server executables are running.
For example, for the application server, use the Microsoft Windows Task Manager or the Server status option from the Domain status menu to see that the following executables are running:
PSAPPSRV.EXE
PSSAMSRV.EXE
BBL.EXE
WSL.EXE
Also make sure that any additional server processes that you have configured, such as PSQCKSRV.EXE, are running.
Editing the Service Configuration File
The Windows Services section of PSADMIN modifies the PSWINSRV.CFG file in the PS_CFG_HOME\appserv directory. You can edit the file directly by selecting 4 (Edit a Service Configuration File) from the PeopleSoft Services Administration menu. This opens the PSWINSRV.CFG file in a text editor, where you can enter and save your changes.
The following sections describe each parameter.
When a domain resides on the same machine as the database server, consider using the Service Start Delay setting. By using this feature, you can avoid the situation where the database server is booting and is not ready to process requests at the time that the service attempts to boot the domain. In this scenario, without a delay set, the connection fails.
You can configure a Service Start Delay parameter that specifies a delay, in seconds, that elapses before a service attempts to start any domains. This allows the RDBMS enough time to boot and become available to accept requests.
The default is 60 seconds.
Specify the names of the domains that you want to start automatically when you boot the application server machine.
If you specify multiple domains, separate each domain with a comma and a space.
Enter the databases with which a Process Scheduler server is associated. For each database that you specify, the associated Process Scheduler server starts when you boot the Microsoft Windows server.
If you specify multiple databases, separate each database with a comma and a space.
Specify the names of the domains that you want to start automatically when you boot the search server machine.
