sunHwTrapSensorNonCritThresholdExceeded |
Upper noncritical threshold exceeded |
Minor.
A sensor has reported that its value has gone above an upper noncritical
threshold setting or below a lower noncritical threshold setting. This generic 'sensor' trap is
generated when the SNMP agent does not recognize the component type. The sunHwTrapThresholdType
object indicates whether the threshold was an upper or lower. |
/SYS/VPS_CPUS/SYS/VPS_MEMORY |
sunHwTrapSensorThresholdOk |
Upper noncritical threshold no
longer exceeded |
Informational. A sensor has reported that its value is in the normal operating
range. This generic 'sensor' trap is generated when the SNMP agent does not
recognize the component type. |
sunHwTrapComponentFault |
event fault.cpu.intel.quickpath.link_slow |
Major. A component is suspected of causing a fault. This
generic 'component' trap is generated when the SNMP agent does not recognize the
component type. |
/SYS/MB |
sunHwTrapComponentFaultCleared |
Informational. A component fault has been cleared. This generic 'component' trap
is generated when the SNMP agent does not recognize the component type. |
/SYS/MB |
event fault.cpu.intel.quickpath.unknown-errcode |
Major.
A component is suspected of causing a fault. This generic 'component' trap is
/SYS/MB |
Informational. A
component fault has been cleared. This generic 'component' trap is generated when the SNMP
/SYS/MB |
event fault.memory.intel.dimm.none |
of causing a fault. This generic ‘component' trap is generated when the SNMP agent
/SYS/MB |
component type. |
/SYS/MB |
event fault.memory.intel.dimm.memtest-failed |
Major. A component is suspected of causing a fault. This generic 'component'
trap is generated when the SNMP agent does not recognize the component type. |
/SYS/MB |
Informational.
A component fault has been cleared. This generic 'component' trap is generated when
/SYS/MB |
event fault.memory.intel.dimm.quadrank-3rd-slot |
of causing a fault. This generic 'component' trap is generated when the SNMP agent
/SYS/MB |
component type. |
/SYS/MB |
event fault.memory.intel.dimm.ddr3u-unsupported |
/SYS/MB |
Informational.
/SYS/MB |
event fault.memory.intel.mrc.unknown-errcode |
/SYS/MB |
component type. |
/SYS/MB |
sunHwTrapMemoryFault |
event fault.memory.intel.dimm.udimm-unsupported |
Major. A memory component is suspected of causing a fault. |
/SYS/MB/P/D |
sunHwTrapMemoryFaultCleared |
Informational. A memory
component fault has been cleared. |
/SYS/MB/P/D |
event fault.memory.intel.dimm.sodimm-unsupported |
/SYS/MB/P/D |
Informational.
A memory component fault has been cleared. |
/SYS/MB/P/D |
event fault.memory.intel.dimm.4gb-fused |
a fault. |
/SYS/MB/P/D |
Informational. A memory component fault has been cleared. |
/SYS/MB/P/D |
event fault.memory.intel.dimm.8gb-fused |
/SYS/MB/P/D |
/SYS/MB/P/D |
event fault.memory.intel.dimm.incompatible |
Major. A memory
/SYS/MB/P/D |
/SYS/MB/P/D |
event fault.memory.intel.dimm.incompatible-maxranks |
Major.
/SYS/MB/P/D |
been cleared. |
/SYS/MB/P/D |
event fault.memory.intel.dimm.incompatible-quadrank |
/SYS/MB/P/D |
/SYS/MB/P/D |
event fault.memory.intel.dimm.numranks-unsupported |
/SYS/MB/P/D |
Informational.
/SYS/MB/P/D |
event fault.memory.intel.dimm.speed-slow |
a fault. |
/SYS/MB/P/D |
/SYS/MB/P/D |
event fault.memory.intel.dimm.disable-quadrank |
/SYS/MB/P/D |
/SYS/MB/P/D |
event fault.memory.intel.dimm.population-invalid |
Major. A memory
/SYS/MB/P/D |
/SYS/MB/P/D |
event fault.memory.intel.dimm.out-of-order |
Major.
/SYS/MB/P/D |
been cleared. |
/SYS/MB/P/D |
event fault.memory.intel.dimm.category-unknown |
/SYS/MB/P/D |
/SYS/MB/P/D |
