Front Panel Components (Installation)
Rear Panel Components (Installation)
Confirming Server and Site Specifications
Minimum Clearance for Service Access
AC and DC Power Supply Specifications
Overcurrent Protection Requirements
DC Power Source, Power Connection, and Grounding Requirements
Installing the Server in a 4-Post Rack
Installing the Standard 19-Inch Hardmount Kit (4-Post Rack)
Installing the 19-Inch Sliding-Rail Kit (4-Post Rack)
Installing the 600-mm Hardmount Kit (4-Post Rack)
Installing the Server in a 2-Post Rack
Installing the 19-Inch Hardmount Kit (2-Post Rack)
Installing the 19-Inch Sliding-Rail Kit (2-Post Rack)
Installing the 23-Inch Hardmount Kit (2-Post Rack)
Connecting Data and Management Cables
Powering On the Server the First Time
Assembling DC Power Cords and Applying DC Power
Power On the Host for the First Time
Choosing an OS Installation Method
OS Installation Task Map (Oracle Solaris)
OS Installation Task Map (Oracle VM)
OS Installation Task Map (Linux)
OS Installation Task Map (VMware ESXi)
OS Installation Task Map (Windows)
Supported OS Versions and Documentation
Understanding Installation Methods
Configuring the Preinstalled Oracle Solaris OS
Preinstalled OS RAID Limitations
Configuration Worksheet (Oracle Solaris)
Configure the Preinstalled Oracle Solaris OS
Configuring the Preinstalled Oracle VM 3. 0 Software
Configuration Worksheet (Oracle VM Server)
Configure the Preinstalled Oracle VM 3.0 OS
Preparing Your PXE Environment
Accessing Installation Utilities
RAID Configuration Requirements
Post-Installation RAID Volume Creation
Configuring RAID Volumes (LSI BIOS Utilities)
Performing Post-Installation Tasks
(Optional) Assign Boot Drive Priorities
Oracle VM Post-Installation Information
Performing Linux Post-Installation Tasks
Performing VMware ESXi Post-Installation Tasks
Performing Windows Post-Installation Tasks
Understanding Administration Resources
BIOS Overview (Administration)
Hardware RAID Administration Tools
Multiple Server Management Tools
Accessing Administration Tools
Access Add-On Card Configuration Utilities (BIOS)
Change Telco Alarm States Manually
Configuring Power-On and Boot Options
Change the Oracle ILOM Root Password (Oracle ILOM CLI)
Recover the Oracle ILOM Root Password
Configuring Oracle ILOM (Oracle ILOM Web Interface)
Configuring the SP and Oracle ILOM (BIOS)
Configure the SP and Oracle ILOM (OSA)
Configure the Enhanced PCIe Cooling Mode Policy (Oracle ILOM CLI)
Resetting the BIOS to Default Settings
Configuring Legacy Option ROM Allocation
Configuring I/O Resource Allocation
Obtain the Server Serial Number
Locate the Server (Oracle ILOM Web Interface)
Monitoring the Server Health (Oracle ILOM Web Interface)
Updating the Firmware and Software
Obtain and Update Firmware (OSA)
Mounting the Oracle System Assistant USB Flash Drive
Requesting Updates on Physical Media
Component Locations (Storage, Power, and Fans)
Component Locations (Motherboard, Memory, and PCIe3 Cards)
Front Panel Components (Service)
Rear Panel Components (Service)
Understanding Diagnostic Tools Available During Server States
Tools Available When Power Cords Are Attached
Tools Available On Initial Power Up
Tools Available When the BIOS Menu Is Available
Tools Available When the OS Boots
Tools Available When the OS Is Running
Network Management Troubleshooting Guidelines
Troubleshooting (Oracle ILOM /SP Targets)
Enable Oracle ILOM Legacy Targets
Display Active Power Consumption
Display Information About User Sessions
Display the NET MGT Configuration Properties
Display the SP Firmware Version
Troubleshooting (Oracle ILOM /System Targets)
Display Problematic Components
Display PCIe3 Card Information
Display the General Health of Component Systems
Display Health and Information About Specific Components
Oracle ILOM Target Health States
Display Faults (show faulty Command)
Display Faults (faultmgt Shell)
Troubleshooting (Oracle ILOM Legacy Targets)
Display FRUID and Fault State for Specific Components
Oracle ILOM Legacy Targets for Component FRUID and Fault States
Display Component Power Consumption
Oracle ILOM Legacy Targets for Component Power Consumption
Display Component Temperatures
Oracle ILOM Legacy Targets for LED States
Diagnose the Drives and USB Drive
Component Service Task Reference
Removing Power From the Server
Raise the Drive Cage to the Service Position
Remove a PCIe3 Card (Risers 1 and 2)
Install a PCIe3 Card (Risers 1 and 2)
Install a PCIe3 Card (Riser 3)
Install the Drive Signal Cable
Determine if the Drive Backplane Is Faulty
Determine if the LED Board Is Faulty
Determine if the Motherboard Is Faulty
Determine if the PDB Is Faulty
Power On the Server (Oracle ILOM)
-> show /SP/logs/event/list Class==class Type==type
where class and type are chosen from the table in Oracle ILOM Log Entry Filters.
For example, to display log entries pertaining to faults:
-> show /SP/logs/event/list Class==Fault Type==Fault
Event
ID Date/Time Class Type Severity
1741 Tue Mar 6 20:13:05 2012 Fault Fault critical
Fault detected at time = Tue Mar 6 20:13:05 2012. The suspect component:
/SYS/PS1 has fault.chassis.power.ext-fail with probability=100. Refer to
http://www.sun.com/msg/SPX86-8003-73 for details.
->For this example, power supply 1 has had a fault. A URL is provided for more information about the fault.
