Skip Navigation Links
Exit Print View
Oracle Solaris Cluster 4.1 Security Guide     Oracle Solaris Cluster 4.1
search filter icon
search icon
Document Information
Preface
1.  Introduction to Oracle Solaris Cluster Security
Index
Preface
The Oracle Solaris Cluster 4.1 Security Guide contains security information about the Oracle Solaris Cluster software product.
Note - This Oracle Solaris Cluster release supports systems that use the SPARC and x86 families of processor architectures. In this document, “x86” refers to the larger family of x86 compatible products. Information in this document pertains to all platforms unless otherwise specified.
Bash is the default shell for Oracle Solaris 11. Machine names shown with the Bash shell prompt are displayed for clarity.
How This Book Is Organized
The Oracle Solaris Cluster 4.1 Security Guide contains the following chapter:
Using UNIX Commands
This document contains information about commands that are specific to installing and configuring Oracle Solaris Cluster data services. The document does not contain comprehensive information about basic UNIX commands and procedures, such as shutting down the system, booting the system, and configuring devices. Information about basic UNIX commands and procedures is available from the following sources:
Typographic Conventions
The following table describes the typographic conventions that are used in this book.
Table P-1 Typographic Conventions
Typeface
Description
Example
AaBbCc123
The names of commands, files, and directories, and onscreen computer output
Edit your .login file.
Use ls -a to list all files.
machine_name% you have mail.
AaBbCc123
What you type, contrasted with onscreen computer output
machine_name% su
Password:
aabbcc123
Placeholder: replace with a real name or value
The command to remove a file is rm filename.
AaBbCc123
Book titles, new terms, and terms to be emphasized
Read Chapter 6 in the User's Guide.
A cache is a copy that is stored locally.
Do not save the file.
Note: Some emphasized items appear bold online.
Shell Prompts in Command Examples
The following table shows UNIX system prompts and superuser prompts for shells that are included in the Oracle Solaris OS. In command examples, the shell prompt indicates whether the command should be executed by a regular user or a user with privileges.
Table P-2 Shell Prompts
Shell
Prompt
Bash shell, Korn shell, and Bourne shell
Bash shell, Korn shell, and Bourne shell for superuser
C shell
machine_name%
C shell for superuser
machine_name#
Related Documentation
Information about related Oracle Solaris Cluster topics is available in the documentation that is listed in the following table. All Oracle Solaris Cluster documentation is available at http://www.oracle.com/technetwork/indexes/documentation/index.html.
Topic
Documentation
Hardware installation and administration
Oracle Solaris Cluster 4.1 Hardware Administration Manual
Individual hardware administration guides
Concepts
Software installation
Data service installation and administration
Data service development
System administration
Software upgrade
Error messages
Command and function references
Compatible software
Access to Oracle Support
Oracle customers have access to electronic support through My Oracle Support. For information, visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=info or visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=trs if you are hearing impaired.
Getting Help
If you have problems installing or using Oracle Solaris Cluster, contact your service provider and provide the following information.
Use the following commands to gather information about your system for your service provider.
Command
Function
prtconf -v
Displays the size of the system memory and reports information about peripheral devices
psrinfo -v
Displays information about processors
pkg list
Reports which packages are installed
prtdiag -v
Displays system diagnostic information
/usr/cluster/bin/clnode show-rev -v
Displays Oracle Solaris Cluster release and package version information for each node
Also have available the contents of the /var/adm/messages file.
