| Skip Navigation Links | |
| Exit Print View | |
Oracle Solaris Cluster 4.1 Release Notes Oracle Solaris Cluster 4.1 |
1. Oracle Solaris Cluster 4.1 Release Notes
Support for Oracle Solaris 11.2 OS
New clsetup Wizards to Create a Zone Cluster
Support for solaris10 Brand Zone Clusters
Support for Exclusive-IP Zone Clusters
Support for Trusted Extensions With Zone Clusters
Resource Dependencies Can Be Defined on a Per-Node Basis
Support for Kernel Cage Dynamic Reconfiguration (DR)
Cluster Security Framework Is Enhanced
Support for Socket Direct Protocol Over the Cluster Interconnect
Faster Failure Detection and Response by Storage Monitors
New clsetup Wizard to Configure the Oracle PeopleSoft Application Server Data Service
New clsetup Wizard to Configure the Oracle WebLogic Server Data Service
Support for MySQL and MySQL Cluster Data Services
New Data Service for PostgreSQL
New Data Service for SAP liveCache
New Data Service for SAP MaxDB
New Data Service for Siebel 8.2.2
New Data Service for Sybase ASE
New Data Service for Oracle Traffic Director
New Data Service for Oracle TimesTen
New Manual for SAP NetWeaver Data Service
New Data Service for Oracle External Proxy
New Data Service for Oracle PeopleSoft Enterprise Process Scheduler
New Data Service for Oracle Web Tier
Support for Oracle E-Business 12.1.1 Data Service
Support for Sun ZFS Storage Appliance Data Replication With Geographic Edition
Support for EMC Symmetrix Remote Data Facility With Geographic Edition
Support for MySQL Replication With Geographic Edition
New Man Pages for the ccradm and dcs_config Advanced Maintenance Commands
Selected Support for Non-Global Zones
What's Not Included in the Oracle Solaris Cluster 4.1 Software
Solaris Volume Manager Disk Sets in a Zone Cluster
Commands Modified in This Release
Logical Host Does not Fail Over with Public Net Fault (16979921)
Oracle ASM With Solaris Volume Manager Mirrored Logical Volumes
osysmond Core Dumps in S10 Brand Zone During GI root.sh and Starting of CRS (14456069)
Oracle Clusterware Fails to Create All SIDs for ora.asm Resource (12680224)
Oracle Solaris 11 SRU Installation Might Fail Due to Out-of-Date pkg Command
Adding Main Adapter to IPMP Group Removes DNS Configuration (7198718)
SAP JAVA Issue Affects HA for SAP NetWeaver Ability to Fail Over in Unplanned Outage (7191360)
Cannot Set the Jumbo Frame MTU Size for the clprivnet Interface (16618736)
Public Net Failure Does Not Fail Over DB Server Resource with SCAN Listener (16231523)
Removing a Node From an Exclusive-IP Zone Cluster Panics Cluster Nodes (7199744)
Nonexisting privnet Stops Zone Clusters From Booting Despite Good privnet (7199431)
Cluster File System Does Not Support Extended Attributes (7167470)
Cannot Create a Resource From a Configuration File With Non-Tunable Extension Properties (6971632)
Disabling Device Fencing While Cluster Is Under Load Results in Reservation Conflict (6908466)
Removing Nodes From the Cluster Configuration Can Result in Node Panics (6735924)
More Validation Checks Needed When Combining DIDs (6605101)
Active-Standby Configuration Not Supported for HA for TimesTen (16861602)
SUNW.Proxy_SMF_failover sc_delegated_restarter File Descriptor Leak (7189211)
When set Debug_level=1, pas-rg Fails Over to Node 2 And Cannot Start on Node 1 Anymore (7184102)
Scalable Applications Are Not Isolated Between Zone Clusters (6911363)
clresource show -p Command Returns Wrong Information (7200960)
Cluster Node Does Not Have Access to Sun ZFS Storage Appliance Projects or iSCSI LUNs (15924240)
DR State Stays Reporting unknown on One Partner (7189050)
Takeover to the Secondary Is Failing Because fs umount Failed On the Primary (7182720)
Multiple Notification Emails Sent From Global Cluster When Zone Clusters Are in Use (7098290)
ASM Instance Proxy Resource Creation Errored When a Hostname Has Uppercase Letters (7190067)
Wizard Won't Discover the ASM SID (7190064)
RAC Proxy Resource Creation Fails When the Cluster Node's Hostname Has Uppercase Letters (7189565)
cacao Cannot Communicate on Machines Running Trusted Extensions (7183625)
Autodiscovery Should Find Only One Interconnect Path for Each Adapter (6299097)
Logical Hostname Failover Could Create Duplicate Addresses, Lead To Outage (7201091)
sc_delegated_restarter Does Not Take Into Account Environment Variable Set in Manifest (7173159)
Unable to Re-enable Transport Interface After Disabling With ipadm disable-if -t interface (7141828)
Failure of Logical Hostname to Fail Over Caused by getnetmaskbyaddr() (7075347)
x86: scinstall -u update Sometimes Fails to Upgrade the Cluster Packages on an x86 Node (7201491)
Oracle Solaris Cluster 4.1 Documentation Set
HA for Oracle Solaris Zones Guide
Geographic Edition Data Replication Guide for Oracle Solaris Availability Suite
This section describes the software and memory requirements for Oracle Solaris Cluster 4.1 and Oracle Solaris Cluster Geographic Edition 4.1 software, as of the time of publication. For the latest information about supported products and product versions for this release, see the Oracle Solaris Cluster 4 Compatibility Guide.
The following data replication products are supported in this release:
Availability Suite feature of Oracle Solaris
EMC Symmetrix Remote Data Facility (SRDF)
Oracle Data Guard – Support is limited to configurations that use Oracle Database 11g release 2 software.
Oracle Solaris Cluster Geographic Edition script-based plug-ins.
Sun ZFS Storage Appliance – When used with Geographic Edition software, support requires a minimum of Sun ZFS 7000 Storage Appliance 2011.1.5 software.
The following table describes the volume managers that are supported in this release for each data replication software product.
1For information about additional supported storage management options, see Storage Management Requirements in Oracle Solaris Cluster Data Service for Oracle Real Application Clusters Guide.
At the time of publication, data services for the following applications are supported with Oracle Solaris Cluster 4.1:
Apache
Apache Tomcat
DHCP
DNS
MySQL
MySQL Cluster
NFS
Oracle eBusiness Suite
Oracle GlassFish Server Message Queue
Oracle Database single-instance on version 11g release 2 only
Oracle iPlanet Web Server
Oracle Real Application Clusters on version 11g release 2 only
Oracle VM Server for SPARC
Oracle Web Tier
PostgreSQL
Samba
SAP liveCache
SAP MaxDB
SAP NetWeaver
Siebel
Sybase ASE
The following table describes the file systems that work with the Oracle Solaris Cluster 4.1 software on SPARC and x86 platforms.
The Oracle Solaris Cluster Geographic Edition (Geographic Edition) 4.1 software runs only on either Oracle Solaris Cluster software version 4.1 or 4.0.
A cluster running Geographic Edition 4.1 software can be in a partnership only with another cluster that runs either Geographic Edition software version 4.1 or 4.0.
The Oracle Solaris Cluster 4.1 software requires the following memory requirements for every cluster node:
Minimum of 1.5 Gbytes of physical RAM (2 Gbytes typical)
Minimum of 6 Gbytes of available hard drive space
Actual physical memory and hard drive requirements are determined by the applications that are installed. Consult the application's documentation or contact the application vendor to calculate additional memory and hard drive requirements.
The Oracle Solaris Cluster 4.1 and Quorum Server software require the Oracle Solaris 11.1 OS. The Oracle Solaris 11.0 release is not supported for Oracle Solaris Cluster 4.1 software.
In addition, to upgrade directly to Oracle Solaris 11.1 software, before upgrade the system must run a minimum of Oracle Solaris 11 with SRU 10. Oracle Solaris software does not support direct upgrade to Oracle Solaris 11.1 from less than Oracle Solaris 11 with SRU 10.
This Oracle Solaris Cluster release works with Oracle VM Server for SPARC 2.1, 2.2, and 3.0. This software was formerly called Sun Logical Domains (LDoms).
The following describe the supported and restricted uses of the SR-IOV feature of Oracle Solaris 11.1 for use with Oracle VM Server for SPARC 2.2:
An SR-IOV device is not supported for live migration of the HA for Oracle VM Server for SPARC data service. This restriction exists as of initial release of the Oracle Solaris Cluster 4.1 software. Contact your Oracle support representative to learn whether support for the SR-IOV feature becomes available.
An SR-IOV device is supported for normal migration of the HA for Oracle VM Service for SPARC data service. This support requires that the SR-IOV device path is identical on all potential primaries of the data service's resource group.
An SR-IOV device is supported with an Oracle VM Server for SPARC logical domain that is configured to run as a cluster node.
The following table describes the volume managers that work with Oracle Solaris 11.1 on the SPARC and x86 platforms. Veritas Volume Manager (VxVM) is not supported for the Oracle Solaris Cluster and Oracle Solaris Cluster Geographic Edition 4.1 software.
