Unlike Field, which assigns a static score to cross-field matches, Maximum Field selects the score of the highest-ranked field that contributed to the match.
The Maximum Field (maxfield) module behaves identically to the Field module, except in how it scores cross-field matches.
Because Maximum Field defines the score for cross-field matches dynamically, it does not make use of the <<CROSS_FIELD>> indicator set in the Search Interface editor.
