This shows the property or dimension by which records are sorted. Specify record sort order.
Option | Description |
Current property or dimension |
Indicates the current property or dimension used to define the sort order of record results. Records are sorted according to their values for the specified property or dimension. |
New property or dimension |
Indicates the new property or dimension used to define the sort order of record results. |
Sort records in descending order |
Indicates the order of the sort. For example, sorting by Price, descending displays the most expensive items first. |
