Specify the Endeca Workbench host, the port Endeca Workbench listens to, and associate instance configuration files with the application you select.
| Option | Description |
Host |
The host the Endeca Workbench is running on. |
Port |
The port the Endeca Workbench is listening to. |
Application |
Select an application from the list. When you finish configuring your project and click Set Instance Configuration, the instance configuration files are associated with the application you select. If the application you want is not in this list, the application has not been provisioned on the EAC Central Server. |
