This shows the record source for this join entry, and options for adding, modifying, or removing key components of this entry's join key.
| Option | Description |
Record source |
The name of the record source that feeds this join entry. |
Keys |
A list of the key components that make up this join entry's join key. |
Add |
Allows you to add a key component to the join key. |
Edit |
Allows you to edit the selected key component. |
Remove |
Removes the selected key component. |
Up |
Moves the selected key component up in the Keys list. |
Down |
Moves the selected key component down in the Keys list. |
