Define a list of words or phrases that will return results for each other when searched.
The Two-way Thesaurus Entry editor contains the following fields:
| Option | Description |
| To | The list of words or phrases that will have a mutual equivalence relationship. Searches on any of the words in the list will return hits for the other words in the list as well. |
| Add | Adds the word or phrase entered in the field above to the To list. |
| Modify | Used to modify a word or phrase in the To list. To modify an entry, select it in the To list, make your changes in the editing field, and click Modify. |
| Remove | Removed the selected word or phrase from the To list. |
