A Shell brick runs the operating system commands (DOS or shell) that you specify.
Shell bricks are frequently used to do pre- or post-processing, or for tasks for which no standard brick exists. Each line in a Shell brick is executed individually in sequence.
It is possible to write Shell bricks that run scripts that are external to the control script. If you write such a Shell brick, the external script it references must be stored locally on the machine on which it will be executed.
Setting |
Description |
stdout |
Where to redirect stdout for the brick. By default, stdout is sent to the screen. Specifying a value for stdout overrides the stdout_base setting. |
stderr |
Where to redirect stderr for the brick. By default, stderr is sent to the screen. Specifying a value for stderr overrides the stderr_base setting. |
arch01 : Shell rm /archive/4/* mv /archive/3/example1* /archive/4/ mv /archive/2/example1* /archive/3/ mv /archive/1/example1* /archive/2/ ln /run/example1* /archive/1/
