Circular References
Circular references within a model are supported as long as Iteration is checked on the Tools, then Options, then Calculation tab in Microsoft Excel.
(In Microsoft Excel 2007 or later, click the Office button and choose Microsoft Excel Options, then Formulas, and then check Enable Iterative Calculation in the Calculation Options group.)
If Crystal Ball detects a circular reference and Iteration is not checked, this error is displayed:
However, if a circular reference is non-converging, its results can differ greatly when run at both Extreme and Normal speed, regardless of the Iteration setting. If a circular reference is non-converging, this error message is displayed:
Simulations with circular references run in non-vectorized mode. For this reason, they will probably run more slowly than simulations without circular references.
