Mining Results Management Window
In the Mining Results Management window, you can view and delete data mining result records and view result accessors and data.
In the Application and Database boxes, you select the preferred application and database.
In the Task Mode box, you select the type of task for which you want to display information.
The following columns display information about the specified type of task, one row per model:
To perform various actions, you click one of the following buttons:
Related Information
