In the Mining Templates Management window, you can view, execute, or delete algorithms that are used in data mining models.
To specify what information is displayed in the window:
In the Application and Database boxes, select the preferred application and database.
In the Task Mode box, select a type of task.
As directed by your selections, information (which is stored with the algorithm metadata) is displayed in the following columns, one row per algorithm:
Name—Template names
Algorithm—Algorithm names
Task—Names of tasks in which templates are used
Source—Applications and databases used as the sources of templates
Owner—IDs of the people who created templates
Creation Time—Dates and times that templates were created
To delete or execute a selected algorithm, you click, respectively, the Delete or Execute buttons.
