| Skip Navigation Links | |
| Exit Print View | |
Oracle Solaris Cluster Upgrade Guide Oracle Solaris Cluster 3.3 3/13 |
Upgrade Requirements and Software Support Guidelines
Choosing an Oracle Solaris Cluster Upgrade Method
2. Performing a Standard Upgrade to Oracle Solaris Cluster 3.3 3/13 Software
3. Performing a Dual-Partition Upgrade to Oracle Solaris Cluster 3.3 3/13 Software
4. Performing a Live Upgrade to Oracle Solaris Cluster 3.3 3/13 Software
5. Performing a Rolling Upgrade
This chapter provides the following information and procedures to prepare to upgrade to Oracle Solaris Cluster 3.3 3/13 software:
Note - Applying an Oracle Solaris Cluster 3.3 3/13 Core patch does not provide the same result as upgrading the software to the Oracle Solaris Cluster 3.3 3/13 release.
