Chapter 1 Oracle ZFS Storage Appliance Overview
Chapter 3 Initial Configuration
Chapter 4 Network Configuration
Network IP MultiPathing (IPMP)
Network Performance and Availability
Network Configuration Using the BUI
Network Configuration Using the CLI
Network Configuration Tasks Using the BUI
Creating a single port interface
Creating a single port interface, drag-and-drop
Creating an LACP aggregated link interface
Creating an IPMP group using link-state only failure detection
Creating an InfiniBand partition datalink and interface
Creating a VNIC without a VLAN ID for clustered controllers
Creating VNICs with the same VLAN ID for clustered controllers
Network Configuration Tasks Using the CLI
Changing the multihoming property to strict
Chapter 5 Storage Configuration
Chapter 6 Storage Area Network Configuration
Chapter 8 Setting ZFSSA Preferences
Chapter 10 Cluster Configuration
Chapter 12 Shares, Projects, and Schema
Do not use probe-based failure detection when there no systems (other than the cluster peer) on the same subnet as the IPMP test addresses that are configured to answer ICMP echo requests.
icon.
