Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
XVLAN Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Principal XVLAN
Restricted XVLAN
XVLAN Port Types
Supported CLI Commands
Configuring XVLAN
Single-Switch Configuration
Single-Switch Topology
Configure External and Internal Ports in a Solitary-Restricted XVLAN
Configure Ports in Solitary- and Group-Restricted XVLANs
Allowing Regular VLAN on XVLAN Ports
Configure Regular VLAN on an XVLAN Port
Display Port VLAN Properties
Configure Regular VLAN 100 With Ports Used in an XVLAN
Multiple-Switch Configuration
Multiple-Switch Topology
Connect Two Switches With Two Restricted XVLANs
Connect XVLANs Across SEFOS1 and SEFOS2
Use these CLI commands to enable or disable regular VLANs on XVLAN ports:
This example shows how to enable regular VLANs on XVLAN ports for the sample configuration presented in this guide.
  1. Disable GVRP.
    SEFOS# conf t
    SEFOS(config)# xvlan 10
    % GVRP/GARP Has to disabled for Exclusive Vlan configuration
    SEFOS(config)# set gvrp disable
    SEFOS(config)# set gmrp disable
  2. Create the principal VLAN and add ports to it.
    SEFOS(config-xvlan)#
    SEFOS(config-xvlan)# port internal ext 0/15-24 extern extreme-ethernet 0/3-6 inter-switch ext 0/11
    SEFOS(config-xvlan)# xvlan 30 solo ports internal ext 0/15-19 extern extreme-ethernet 0/3-6 inter-switch ext 0/11
    SEFOS(config-xvlan)# xvlan 60 group port intern ext 0/21-24 extern extreme-ethernet 0/3-6 inter-switch ext 0/11
    SEFOS(config-xvlan)# end
  3. View the configuration.
    SEFOS#
    SEFOS# show xvlan
    Exclusive Vlan database
    XVlan ID : 10
    Type : Principal
    Principal XVlan : 10
    External Ports : Ex0/3, Ex0/4, Ex0/5, Ex0/6
    Internal Ports : Ex0/15, Ex0/16, Ex0/17, Ex0/18, Ex0/19, Ex0/20
    Ex0/21, Ex0/22, Ex0/23, Ex0/24
    ISWTrunk Ports : Ex0/11
    Name :
    XVlan ID : 30
    Type : Restricted: Solitary
    Name :
    XVlan ID : 60
    Type : Restricted: Group
    Internal Ports : Ex0/21, Ex0/22, Ex0/23, Ex0/24
    Name :
