Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
PIM Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
PIM Overview
Protocol Description
Configuring PIM
Sample Topology
Default Settings
SEFOS1 Configuration
SEFOS2 Configuration
Enable PIM
Reducing Data Transmission Time Using the SPT
Specify the PIM Threshold That Triggers SPT Switching
Specify the PIM SPT Switch Period
Specify the PIM RP Threshold That Triggers Source-Specific Switching
Specify the PIM RP Switch Period
Monitor the Data Transfer Rate After a Register Stop Message
Configuring PMBR Status
Enable PMBR Status Reporting
Disable PMBR Status Reporting
Enabling Static RP Configurations
Enable Static RP
Disable Static RP
Associate an Interface to a PIM Component
Delete a PIM Interface
Configuring Designated Routers
Prioritize Router Messaging With PIM DR-Priority
Restore the Default Router Priority Designation
Configuring the PIM Override Interval
Specify the Interval to Delay Override Messages
Restore the Default Override Messaging Interval
Configuring PIM LAN Delay
Delay LAN Message Propagation
Restore the Default LAN Delay Interval
Configuring LAN Prune Delay
Enable LAN Prune Delay
Disable LAN Prune Delay
Configuring BSR Candidates
Prioritize BSR Candidates
Restore the Default BSR-Candidate Value
Configuring PIM Query Intervals
Specify the Hello Messaging Interval
Restore the Default Hello Messaging Interval
Configuring PIM Join and Prune Messaging
Specify the Join and Prune Messaging Interval
Restore the Default Message Interval
Managing PIM Components
Create a PIM Component
Delete a PIM Component
Configuring PIM Component Data Routing Modes
Specify a Data Routing Mode
Configuring RP-Candidate Behavior
Specify the Address for the Candidate RP
Delete an RP Candidate
Configuring RP Candidate Hold Time
Specify RP Candidate Hold Time
Restore the Default Candidate RP Hold Time
Configuring Static RPs
Specify the Address for the Static RP
Delete a Static RP
Display RP Details
Enable PIM Neighbor Recognition
Display PIM Multicast Information
Associating an interface with PIM doesn't necessarily enable PIM on that interface. To enable PIM over an interface, you must configure a PIM query interval (see Configuring PIM Query Intervals).
This example associates VLAN 5 to PIM 1.
  1. Enable PIM globally.
    SEFOS# configure terminal
    SEFOS(config)# set ip pim enable
  2. Enter Interface Configuration mode for the interface.
    SEFOS(config)# interface vlan 5
  3. Associate the interface with PIM component.
    SEFOS(config-if)# ip pim componentId 1
    SEFOS(config-if)# end
  4. View the PIM interface status.
    SEFOS# show ip pim interface detail
    Vlan5 33 is up
      Internet Address is 10.1.0.1
      Muticast Switching : Enabled
      PIM : Enabled
      PIMv6 : Disabled
        PIM version : 2, mode: Sparse
        PIM DR : 10.1.0.1
        PIM DR Priority : 1
        PIM Neighbour Count : 0
        PIM Hello/Query Interval : 30
        PIM Message Interval : 60
        PIM Override Interval : 0
        PIM Lan Delay : 0
        PIM Lan-Prune-Delay : Disabled
        PIM Component Id : 1
        PIM domain border : enabled
