Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
DHCP Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
DHCP Server
DHCP Client
DHCP Relay Agent
Configuring DHCP
Two-Switch Configuration
Multiple-Switch Configuration
Configuration Guidelines
Default Configurations
Enabling and Disabling the DHCP Server
Enable the DHCP Server
Disable the DHCP Server
Enable ICMP Echo
Specify the Amount of Time After Which an IP Address Is Made Available
Configure the Next Server
Configure the Boot File Name
Configuring DHCP Global Options
Configure DHCP Global Options
Delete DHCP Global Options
Configuring Address Pools
Configure DHCP Address Pools
Configure the End IP for the Address Pool
Configure the Lease Time
Configure the Utilization Threshold
Create an Excluded Address in the Pool
Configuring Pool-Specific Options
Configure a Domain Name Option
Configure the DNS Option
Configure the NetBIOS Name Server
Configure the NetBIOS Node Type
Configure the Default Router
Remove a Configured Default Router Subnet Option
Configure Options Specific to Address Pools
Configure Host-Specific Options
Enabling and Disabling Debug Traces for the DHCP Server
Enable Debug Traces for the DHCP Server
Disable Debug Traces for the DHCP Server
Configuring an Interface to Acquire or Use an IP Address
Configure an Interface to Acquire a Dynamic IP Address
Delete a Binding Entry From the Server
Configure an Interface to Use a Manual IP Address
Enable DHCP Relay
Configure a DHCP Server Address
Configuring Relay Agent Options
Enable the Relay Agent Information
Configure Relay Agent Suboptions
Enable Traces for the DHCP Relay Agent
Acquire an IP Address From a Server Residing Outside the Client Network
This figure shows the topology for a multiple-switch configuration. In this example, switch 1 is the DHCP server, switch 2 is the DHCP relay, and switch 3 is the DHCP client, except for cases where the Sun Network 10GbE Switch 72p is used.
image:Figure showing multiple-switch configuration
