These steps are used to set up the configuration in Example Configuration.
SEFOS# conf t SEFOS(config)# set lldp enable SEFOS(config)# no shutdown lldp
SEFOS(config)# no shutdown evb
Note - By default EVB module is enabled on the switch.
SEFOS(config)# interface ex 0/1 SEFOS(config-if)# lldp tlv-select dot1evbtlv SEFOS(config-if)# set vdp enable SEFOS(config-if)# exit SEFOS(config)# interface ex 0/2 SEFOS(config-if)# lldp tlv-select dot1evbtlv SEFOS(config-if)# set vdp enable SEFOS (config-if)# end SEFOS#
