In addition to the general online help, help is also available for each dialog and task pane. This help includes general information about the dialog, field descriptions, and field naming conventions.
in the upper right corner of a dialog.
-OR-
On some dialogs, both standard Windows field level help and Add-In dialog help are available.
in the upper-right corner to display the standard Windows help.
Tooltips also appear when you hover over most of the buttons in the ribbon and dialogs. These tooltips give you extra information about the function of a particular button.
© Copyright 2013, Oracle and/or its affiliates. All rights reserved. Legal notices.
