You can remove an element from a Documaker document simply by using the delete or backspace key.
Note that if you remove a graphic element this way, you will need to refresh the tree view to see your change.
| Tip | See other ways to remove an element. |
© Copyright 2013, Oracle and/or its affiliates. All rights reserved. Legal notices.
