Oracle Financial Services Behavior Detection Platform 6.2 Patch/Hotfix Readme File June 2014 Release: 6.2.3.0.0 (only for FCCM installed on Linux 5.8 and 6.4 OS versions) This document provides information to upgrade the Oracle Financial Services Behavior Detection Platform version 6.2.0.0.0 to the latest release 6.2.3.0.0. For more information about Oracle Financial Services Software, Inc., visit http://www.oracle.com/industries/financial_services/index.html. ------------------------------------------------------- HOW TO USE THIS DOCUMENT ------------------------------------------------------- To view the readme.txt on-screen in Notepad, maximize the Notepad window. To print the readme.txt, open it in Notepad or another word processor, and then, on the File menu, click Print. ------------------------------------------------------------------------------------------------------------------------------------------ CONTENTS ------------------------------------------------------------------------------------------------------------------------------------------ 1.0 Overview 2.0 Prerequisites 3.0 Oracle Financial Services Behavior Detection Platform Resolved Issues and enhancements (addressed in this patch) 4.0 Oracle Financial Services Behavior Detection Platform Known Issues 5.0 Steps to apply Oracle Financial Services Behavior Detection Platform 6.2.3.0.0 6.0 Uninstalling and re-applying the 6.2.3.0.0BD patch 7.0 Documents impacted in this release 8.0 Files Included in This Patch ------------------ 1.0 Overview ------------------ 1.1 This patch upgrades OFSBDF 6.2.0.0.0 or 6.2.1.0.0 or 6.2.2.0.0 to latest release 6.2.3.0.0. 1.2 This patch also contains fixes for Issues and enhancements. For more details, see section 3.0 1.3 This release is only for FCCM installed on Linux 5.8 and 6.4 OS versions. --------------------- 2.0 Prerequisites --------------------- 2.1 Before applying Oracle Financial Services Behavior Detection Platform 6.2.3.0.0 patch, it is required to install OFSBDF 6.2.0.0.0 or 6.2.1.0.0 or 6.2.2.0.0 2.2 Before applying Oracle Financial Services Behavior Detection Platform 6.2.3.0.0 patch, it is required to apply OFSAA 7.3.4.1.0 patch. 2.3 This patch requires the prior installation of Patch Installer Utility 1.0.2.0.0 (PIU 1.0.2.0.0) ----------------------------------------------------------------------------------------------------------------------------------------- 3.0 Oracle Financial Services Behavior Detection Platform Resolved Issues and enhancements (addressed in this patch) ----------------------------------------------------------------------------------------------------------------------------------------- 3.1 Enhancement 18146704: Added a field to Account and Customer reference data that can optionally be used to specify a geographic jurisdiction. This field can be used by Oracle Financial Services FATCA to establish different criteria for determining FATCA status across geographic regions. 3.2 Enhancement 18050281: The Purge Utility has been updated to allow for specification of exclusion criteria that can be used to set an indicator on an alert or case such that it will not be purged even if it meets the general requirement for purging. 3.3 Enhancement 17441546: Implement change log process in BDF subsystem 3.4 Enhancement 17194653: Each time an institution is identified in transaction data the Oracle derived Institution Master Table is updated to ensure the latest information with respect to the institution's name and/or address is maintained by the system. 3.5 Enhancement 14550170: Added additional Oracle derived fields to the following tables to support aggregation of Remote Deposit Capture activity: Account Profile, Account Daily Profile - Transaction, Correspondent Bank Profile, Account Peer Group Monthly Transaction Profile, Correspondent Bank Peer Group Transaction Profile 3.6 Enhancement 14324861: Added in visual display of networks for the Network of Accounts and Hidden Relationship scenarios. 3.7 Enhancement 18097006: A third-party product used as the database abstraction layer within the BD Algorithms subsystem (Rogue Wave) has been replaced with an internally-developed API built directly upon the OCI 3.8 Issue 17502029: Watchlist task fails with an ‘ORA-00942: table or view does not exist’ error. 3.9 Issue 17499761: The Scenario loading utility (sm_load.sh) deletes any custom jobs which have job_id more than the product.id.range.min=113000000 as set in the install.cfg file. 3.10 Issue 17444163: HDC jobs should use dbms_gather_stats in the P_ANALYZE procedure. 3.11 Issue 17385429: HDC job has been updated for better performance. 3.12 Issue 16674424: For attestation, Outside Business Activity/ Private Security Transaction datamap files has been added for ingestion. 3.13 Issue 17230705: The UNRLTD_PARTY_CD flag derivation should use the UseTaxIDForUnrelatedParty configuration for back office transactions. 3.14 Issue 14330715: The Customer.xml is missing the CustomerGender and CustomerNAICSCode fields. 3.15 Issue 16623270: Logic errors generating for BOT.UNRLTD_PARTY_CD. 3.16 Issue 16511979: Performance issues for RUNUTILITY.SH INVESTMENTADVISORPROFILE. 3.17 Issue 16366315: There is incorrect metadata in mantas_schema.kdd_analyze_param that tells the Analyze jobs which tables to analyze. 3.18 Issue 4400624: AccountProfileTransaction utility failed with ORA error. 3.19 Issue 16281685: The NameMatchStaging datamap is generating an error. 3.20 Issue 14639967: The following error occurs when executing shutdownWatchList.sh. javax.xml.soap.SOAPException: java.net.SocketTimeoutException: Read timed out. 3.21 Issue 14079963: An error displays on KDD_CODE_SET_TRNLN in the installer.log file. 3.22 Issue 14617024: SQL scripts with lines that are more than 2499 characters are generating errors. ---------------------------------------------------------------------------------------------- 4.0 Oracle Financial Services Behavior Detection Platform Known Issues ---------------------------------------------------------------------------------------------- Note: For more information on the following Known Issues, contact the Oracle support team. 4.1 Issue 17420981: Date is not getting inserted in "INTERESTED_PARTY_EMP" table 4.2 Issue 18644855: Error coming while running scenarios on Solaris. 4.3 Issue 18649193: Batch assessment not created for ACCT/CUST which has more than one domain. 4.4 Issue 18641720: Post process is not working in 623 AIX. 4.5 Issue 18541024: Issue coming while running BDF DATAMAPS ACCOUNT through FSDF. 4.6 Issue 18804636: Large reportable transactions scenario end with missing expression error. 4.7 Issue 18815654: Account registration -115400006- scenario end with error code ora-0092011. 4.8 Issue 18815683: Customers who have experienced a large loss recently end with error. 4.9 Issue 18804685: Structuring: deposits/withdrawals -116000043 scenario end with error. 4.10 Issue 18804714: Structuring: deposits/withdrawals scenario end with error. 4.11 Issue 18480137: Scenarios having sql_tx with ~70,000 characters is getting chopped. 4.12 Issue 18815761: Trading ahead of material event scenario end with error. 4.13 Issue 18815797: Trading ahead of material event scenario end with error. 4.14 Issue 18815830: Trading ahead of material event scenario end with error. 4.14 Issue 18871712: bex-mifidpricedisimprov -114697003- scenario ended with error. ------------------------------------------------------------------------------------------------------------------------------------------ 5.0 Steps to apply Oracle Financial Services Behavior Detection Platform 6.2.3.0.0 ------------------------------------------------------------------------------------------------------------------------------------------ a. PATCH CONTENTS ------------------ The following files are included with this patch/hotfix: 6.2.3.0.0BD.tar.gz (This readme file) b. The following subsystem is affected by this patch/hotfix: ------------------------------------------------------------ ingestion_manager database behavior_detection services bdf c. The Patch instructions refer to the following directories: ------------------------------------------------------------ Name Description --------------------------- -------------------------------- Directory containing installed Oracle Behavior Detection Framework components Directory containing patch installer component Directory containing the patch tar.gz file d. To apply this patch/hotfix, follow the below instructions: ------------------------------------------------------------------------------------------------------ 1. Take the backup of the directory 2. Take the backup of AM, CM, KYC, FSDF and OFSAA (Configuration) database schemas. 3. Stop all the processes (Dispatcher, Batch) before applying the patch on Behavior Detection Platform. 4. In this release we have added support for external tables. To this end we need to create a directory object at database level. Edit the db_variables.cfg file located at /database/db_tools/mantas_cfg and /patch_installer/mantas_cfg directory: a) Add the following tokens at the end of the file: ## Added for CR 18387933 ############################## # External Table Directory # ############################## ext_tab_dir_name=@INGEST_USER@_DIR ext_tab_dir_path=@USER_INSTALL_DIR@/bdf/inbox NOTE: i) For "ext_tab_dir_name" @INGEST_USER@_DIR, @INGEST_USER@ needs to be replaced with value of variable "ingest_user_name" given in /database/db_tools/mantas_cfg/db_variables.cfg. Besides this no further changes should be done to the value of "ext_tab_dir_name" variable. ii) For "ext_tab_dir_path"=@USER_INSTALL_DIR@/bdf/inbox, @USER_INSTALL_DIR@ needs to be replaced by path. As such this path can be edited/changed by clients. "ext_tab_dir_path" can be any directory that both the database server and application server have access to and Oracle user (user with which Oracle Database is installed) must have read/write access to this named directory. b) Add the following tokens as mentioned: ## Under section "--Platform Product Tablespaces" fatca_data_tablespace=FATCA_DATA fatca_index_tablespace=FATCA_INDEX ## Under section "# Data File Names #" fatca_data_file=//fatca_data_01.dbf fatca_index_file=//fatca_idx_01.dbf Replace the with the absolute path where the database dbf files are to be created. ## Under section "# Data File Sizes #" fatca_data_size=512M fatca_index_size=512M 5. Edit the install.cfg file located at /database/db_tools/mantas_cfg and /patch_installer/mantas_cfg directory and locate the "Database Builder Utility Configuration" section. Search for "Oracle.ObjectExists" and add ",1543" (without quotes) to it. The final entry would look as follows: Oracle.ObjectExists=955,2260,2275,1430,1442,1451,957,1408,2261,1543 6. Change to the /patch_installer directory. 7. Type "patchUtil.sh install" to install the patch. 8. When prompted, provide the complete directory path where the hotfix tar.gz file is located. Enter Patch Archive name (with full path)(N to stop entering more patches) : /6.2.3.0.0BD.tar.gz Note: The patch utility will also prompt for various tokens, provide values as mentioned below: Install Patch: Applying this patch will override any customizations/changes done on the existing functionalities offered in the default product release. Also the database updates performed by this patch cannot be uninstalled by the Patch Installer. The Patch Installer will only uninstall the file system files and thus a backup is recommended before this installation. confirm by entering 'Y' (N to stop execution) : 6.2.3.0.0BD.properties file not Found in path Press Enter to continue without this file, else please provide the full file path of 6.2.3.0.0BD.properties file. : Enter Installation comments(optional) for '6.2.3.0.0BD' : Do you want to execute script 'delta_plat6.2.3.cfg' press Enter {N not to run particular script} : Enter password for : Re-Enter password for : Password accepted for Enter database username for user : Enter password for s: Re-Enter password for : Password accepted for Enter database username for 'ingest' user : Enter password for : Re-Enter password for : Password accepted for Enter password for : Re-Enter password for : Password accepted for Enter database username for 'report' user : Enter password for : Re-Enter password for : Password accepted for Do you want to execute script 'mantas6.2.3_delta.cfg' press Enter {N not to run particular script} : Enter password for : Re-Enter password for : Password accepted for Note: If installer did not ask to execute config scripts (mantas6.2.3_delta.cfg, delta_plat6.2.3.cfg) and gives the message "Patch '/6.2.3.0.0BD.tar.gz ' installed successfully !! Please run run_dbbuilder_utility.sh command from database/db_tools/bin directory along with the config scripts to complete the installation. Refer the DB builder logs to ensure the scripts have run successfully", then follow steps #(10.a) and provide the values for the tokens asked as given in step #9 for config files. 9.a. While installing, if run_dbbuilder_utility did not run config scripts(mantas6.2.3_delta.cfg,delta_plat6.2.3.cfg), then run the config scripts with run_dbbuilder_utility.sh located at /database/db_tools/bin as given below: /database/db_tools/bin/run_dbbuilder_utility.sh /database/bus_mkt_schema/delta/oracle/delta_plat6.2.3.cfg /database/db_tools/bin/run_dbbuilder_utility.sh /database/mantas_schema/delta/oracle/mantas6.2.3_delta.cfg b. Navigate to the path /patch_installer/logs and check PatchUtil.log for any error while installing patch. If any error occurs during patch installation contact oracle support. c. If patch fails and needs to be re-applied then please refer section "6.0 Uninstalling and re-applying the 6.2.3.0.0UI patch" 10. If patch is applied successfully, then take the backup of the below given files for any future uninstallation activity to avoid checksum errors. For more details on uninstallation activities refer section "6.0 Uninstalling and re-applying the 6.2.3.0.0UI patch". /bdf/fuzzy_match/bin/fuzzy_match.sh /bdf/fuzzy_match/mantas_cfg/install.cfg.fuzzy /bdf/config/install/BDF.xml /bdf/config/custom/BDF.xml /ingestion_manager/fuzzy_match/bin/fuzzy_match.sh /ingestion_manager/services/conf/server.xml Perform following steps for BDF subsystem: ------------------------------------------------------ 11. Run command "chmod 755 *" in the given below directories: /bdf/scripts /bdf/fuzzy_match/lib /bdf/fuzzy_match/bin 12. For the token replacements, the following needs to be replaced in fuzzy_match.sh located at /bdf/fuzzy_match/bin: @KDD_FUZZY_PRODUCT_HOME@ with /bdf/fuzzy_match @ORACLE_HOME@ with Oracle Home The token @JVM_PATH@ should be replaced as per below: For LINUX: replace @JVM_PATH@ with $jdk_home$/jre/lib/amd64:$jdk_home$/jre/lib/amd64/server (where $jdk_home$ is the path to the JDK) 13. Rename the file install.cfg.fuzzy to install.cfg located at /bdf/fuzzy_match/mantas_cfg 14. The following needs to be replaced in install.cfg located at /bdf/fuzzy_match/mantas_cfg: @STOPWORD_PATH@ with /bdf/fuzzy_match/share @LOG_DIR@ with $fuzzy_log_dir$ (where $fuzzy_log_dir$ is the desired path for the fuzzy matcher log files) @FUZZY_TEMP_DIR@ with /bdf/data/temp 15. Edit the BDF.xml file located at /bdf/config/install and ensure the following tokens are replaced correctly with the corresponding values. @DB_URL@ - Database URL for JDBC connections made by BDF components. The content and format of this value is specific to the database vendor and the vendor database driver. Example: jdbc:oracle:thin:@solitaire.mantas.com:1521:D1O9L2 @DB_INSTANCE@ - Database instance to connect to on the database servers. Typically, the instance name matches the database name portion of the DB.Connection.URL. Example: D1O9L2 @DB_USER@ - Database User that Data Ingestion components user when connecting with the database. Example: INGEST_USER @ALG_DB_USER@ - Database user for running Behavior Detection post-processing jobs. Example: KDD_ALG @MANTAS_SCHEMA@ - Schema name for the Oracle Mantas database schema. Typically, an Oracle client uses the default name of "MANTAS." BDF accesses the MANTAS schema when allocating sequence IDs to ingested records. Example: MANTAS @MARKET_SCHEMA@ - Schema name for the MARKET database schema. Typically, an Oracle client uses the default name of "MARKET." Data Ingestion stores market data related records in the MARKET schema. Example: MARKET @FIRM_SCHEMA@ - Schema name for the BUSINESS database schema. Typically, an Oracle client uses the default name of "BUSINESS." Data Ingestion stores business data related records in the BUSINESS schema. Example: BUSINESS @CONFIG_SCHEMA@ - Schema that the OFSAAI uses to connect to the database. Example: REVELEUS In case for OFSAAI has already been installed using separate user then provide SAME user id for this parameter. @CASE_SCHEMA@ - Schema that the Web Application uses to connect to the database for Cases. Example: CMREVMAN @ACCT_TRUST_FROM_CUST@ - Flag that tells the Data Ingestion process whether the account risk should be exempt or trusted based on the exempt or trusted status of the customers risk. Y BDF process will consider the customer exempt and trust risk in calculating the account risk. N BDF process will not consider the customer exempt and trusted risk in calculating the account risk. @JURISDICTION@ - Default Jurisdiction to assign the derived entities and derived addresses. Example: AMEA @USETAXID@ - Instruction to Ingestion Manager when to use tax identifiers(both account and customer) in determining unrelated journals. If a substitute tax identifier is used when the accounts or customers tax identifier is unknown, then unrelated accounts may appear to be related when tax identifiers are considered. This variable enables the Ingestion Manager to ignore substitute tax identifiers. Y Ingestion Manager is to use tax identifiers N Ingestion Manager is not to use tax identifiers @BASE_COUNTRY@ - ISO country code to use during data ingestion to record institution derived geography risk on parties on transactions that are internal to the OFSBDF client. Example: base_country=US @PROCESS_FOREIGN_FL@ - Flag that tells the Data Ingestion process whether it should populate the Foreign field in the front office transaction table or if it should leave it blank for the firm to populate. Y Run the OFSBDF mappings. N Use the provided Value. @PROCESS_BANK_TO_BANK@ - Flag that tells the Data Ingestion process whether it should populate the bank to bank transfer field in the front office transaction table or if it should leave it blank for the firm to populate. Y Run the OFSBDF mappings. N Use the provided Value. @PROCESS_TRXN_XREF@ - Flag that tells the Data Ingestion process whether it should populate BUSINESS.TRXN_PARTY_XREF TABLE or leave it blank Y Populate the BUSINESS.TRXN_PARTY_XREF TABLE N Do not populate the BUSINESS.TRXN_PARTY_XREF TABLE @TP_RISK_REVIEW_FLAG@ - This variable should not be set to Y when trusted pairs are loaded through the DIS file. Y Datamaps for trusted pair risk review is executed. N Datamaps for trusted pair risk review is not executed. 16. Execute the following command: /bdf/scripts/changePasswords.sh This prompts for the passwords of the required application users as shown below. The passwords entered are not output to the screen and the same password must be re-entered in order to be accepted. All passwords must be entered; it is not be possible to skip a password. Enter password for : Re-Enter password for : Password set for Data Ingest User Enter password for : Re-Enter password for : Password set for Algorithm User 17. Edit the env.sh file located at /bdf/scripts and append $BDF_ROOT/fuzzy_match/bin to the PATH variable. So the PATH variable should be: PATH=$ORACLE_HOME/bin:$BDF_ROOT/fuzzy_match/bin:$PATH ------------------------------------------------------ Perform following steps for Ingestion Manager subsystem: ------------------------------------------------------ 18. Run command "chmod 755 *" in the given below directories: /ingestion_manager/scripts /ingestion_manager/fuzzy_match/lib /ingestion_manager/fuzzy_match/bin 19. For the token replacements, the following needs to be replaced in fuzzy_match.sh located at /ingestion_manager/fuzzy_match/bin: @KDD_FUZZY_PRODUCT_HOME@ with /ingestion_manager/fuzzy_match @ORACLE_HOME@ with Oracle Home The token @JVM_PATH@ should be replaced as per below: For LINUX: replace @JVM_PATH@ with $jdk_home$/jre/lib/amd64:$jdk_home$/jre/lib/amd64/server (where $jdk_home$ is the path to the JDK) 20. Following tokens needs to be replaced in server.xml file located at /ingestion_manager/services/conf directory: @WLS_SHUTDOWN_PORT@ - provide value as given in tag "wls_shutdown_port" in Silent Property file under section "Data Ingest Variables" @WLS_HTTP_PORT@ - provide value as given in tag "wls_http_port" in Silent Property file under section "Data Ingest Variables" @WLS_HTTPS_PORT@ - provide value as given in tag "wls_https_port" in Silent Property file under section "Data Ingest Variables" Provide the values for the port number as given in the section "Data Ingest Variables" in Silent Properties file used for Oracle Behavior Detection Platform Installation. ------------------------------------------------------ Perform following steps for Behavior Detection subsystem: ------------------------------------------------------ 21. Run command "chmod 755 *" in the given below directories: /behavior_detection/algorithms/bin /behavior_detection/algorithms/lib /behavior_detection/algorithms/MTS/bin ------------------------------------------------------ Perform following steps for Database subsystem: ------------------------------------------------------ 22. Edit the install.cfg file located at /database/db_tools/mantas_cfg directory and add the following tokens: a. locate the following section: # Specify product version purge_product_verion= Update the above to: # Specify product version purge_product_version= b. Locate the "LOAD" sub section under "GENERAL SCENARIO MIGRATION SETTINGS" section. Add the below line: load.score.update=N The above flag should be set to N if a scenario should be loaded without wiping out the existing scoring rules. It should be set to Y if the scoring rules should be updated. c. Replace the following line: dbscript.execution.users=(system|business|mantas|market|miner|ingest|report|kdd|algorithms|case|config|fatca|ctr|kyc) with the following line: dbscript.execution.users=(system|business|mantas|market|miner|ingest|report|kdd|algorithms|case|config|fatca|ctr|kyc|fsdf) d. Add the following token under section "COMMON CONFIGURATION ENTRIES" schema.business.password= 23. Execute the following command: /changePasswords.sh all This prompts for the passwords of the required application users as shown below. The passwords entered are not output to the screen and the same password must be re-entered in order to be accepted. All passwords must be entered; it is not be possible to skip a password. Enter password for Data Ingest User: Re-Enter password for Data Ingest User: Password set for Data Ingest User Enter password for Database Utility User: Re-Enter password for Database Utility User: Password set for Database Utility User Enter password for Data Miner User: Re-Enter password for Data Miner User: Password set for Data Miner User Enter password for Business User: Re-Enter password for Business User: Password set for Business User Enter password for Purge Utility User: Re-Enter password for Purge Utility User: Password set for Purge Utility User Enter password for Web Service User: Re-Enter password for Web Service User: Password set for Web Service User Enter password for Algorithm User: Re-Enter password for Algorithm User: Password set for Algorithm User Enter password for Web Application User: Re-Enter password for Web Application User: Password set for Web Application User 24. Remove the control M characters from the files given below using the command specific to your OS: /database/db_tools/bin/run_update_ora_seq.sh 25. Execute the following command before starting the ingestion process: /database/db_tools/bin/run_update_ora_seq.sh KDD_APRVL_ACTVY_AUDIT 26. Keep a record of the builds and patches applied to each Oracle Behavior Detection Platform server, and the date/time they were applied. 27. Send an email message to mantas_support_us@oracle.com indicating that the patch/hotfix has been applied. ------------------------------------------------------------------------------------------------------------------------- 6.0 Uninstalling and re-applying the 6.2.3.0.0.BD patch ------------------------------------------------------------------------------------------------------------------------- A. Uninstalling the patch. 1. All the post installation steps performed manually after the successful application of patch needs to be reverted back. For any check sum error on any file while uninstalling the patch, take the original file taken as a backup in Step 5.0.d.10 and put it at the required location. 2. To uninstall the patch , run the below command in the putty from /patch_installer Directory, provide the patch name and comments that need to be uninstalled . ./patchUtil.sh uninstall Patch Uninstallation: Enter the Patch Name to be UnInstalled : 6.2.3.0.0BD Patch Uninstallation: Enter the Comments for the Patch to be Uninstalled : B. Re-apply the 6.2.3.0.0BD patch as per section 5.0.d ----------------------------------------- 7.0 Documents impacted in this release ----------------------------------------- For information on documents that are updated as a part of Oracle Financial Services Financial Crime and Compliance Management release 6.2.3, see http://docs.oracle.com/cd/E41197_01/homepage.htm. ------------------------------------------------------------------------------------------------------------------------- 8.0 Files Included in This Patch ------------------------------------------------------------------------------------------------------------------------- 6.2.3.0.0BD.xml AccountProfile_Trade.xml ApprovalActionsAudit_TrustedPair.xml BDF.xml FrontOfficeTransactionPartyRiskStage_EntityActivityRiskInsert.xml LoanProfile_LoanProfileStage.xml message.dat TrustedPair_StatusRRCInsert.xml BDF.xml.template Account.xml AccountAddress.xml AccountATMDailyProfile.xml AccountBalance.xml AccountBalance_Acctposn.xml AccountBalance_AcctPosnPair.xml AccountChangeLogSummary.xml AccountChannelWeeklyProfile.xml AccountCustomerRole.xml AccountDailyProfile-Trade.xml AccountDailyProfile-Transaction.xml AccountGroup.xml AccountGroupProductAllocation.xml AccountGroupProductAllocation_old.xml AccountGroup_InvestmentObjectiveUpd.xml AccountListMembership_WatchListStage2Insert.xml AccountManagementStage.xml AccountPeerGroupMonthlyTransactionProfile.xml AccountPhone.xml AccountPosition.xml AccountPositionDerived.xml AccountPosition_PercentofPortfolioUpd.xml AccountProductAllocation.xml AccountProfile_Balance.xml AccountProfile_Balance_citi.xml AccountProfile_Position.xml AccountProfile_Stage.xml AccountProfile_Trade.xml AccountProfile_Transaction.xml AccountToClientBank_AIIMSInstitutionInsert.xml AccountToClientBank_AnticipatoryProfile.xml AccountToClientBank_FOTPSInstitutionInsert.xml AccountToClientBank_InstitutionInsert.xml AccountToClientBank_InstitutionUpd.xml AccountToClientBank_InsuranceTransaction.xml AccountToClientBank_SettlementInstruction.xml AccountToClientBank_ThomsonDataInstitutionInsert.xml AccountToCustomerChangeLogSummary.xml AnticipatoryProfile_AccountToClientBank.xml ApprovalActionsAudit_TrustedPair.xml BackOfficeTransaction.xml BackOfficeTransaction_CancelledTransactionReversalCreditUpd.xml BackOfficeTransaction_CancelledTransactionReversalDebitUpd.xml BackOfficeTransaction_CollateralUpd.xml BackOfficeTransaction_EffectiveAcctivityRiskUpd.xml BackOfficeTransaction_OriginalTransactionReversalUpd.xml BackOfficeTransaction_TrustedFlagsUpd.xml BackOfficeTransaction_UnrelatedPartyCodeUpd.xml Borrower.xml CashTransaction_FrontOfficeTransaction.xml CashTransaction_FrontOfficeTransactionRevAdj.xml ChangeLog_AcctProfileInactivity.xml ChangeLog_Derived.xml CorrespondentBankListMembership_WatchListStage2Insert.xml CorrespondentBankPeerGroupTransactionProfile.xml CorrespondentBankProfile.xml CorrespondentBankToPeerGroup.xml CorrespondentBank_FrontOfficeTransactionPartyStageInsert.xml Customer.xml CustomerAccountStage_FrontOfficeTransactionParty.xml CustomerAddress.xml CustomerBalance_ActiveOTCTradeCtUpd.xml CustomerChangeLogSummary.xml CustomerDailyProfile_BOT.xml CustomerDailyProfile_CorpAction.xml CustomerDailyProfile_DEAL.xml CustomerDailyProfile_FOTPS.xml CustomerDailyProfile_INST.xml CustomerDailyProfile_Trade.xml CustomerIdentificationDocument.xml CustomerListMembership_WatchListStage2Insert.xml CustomerPhone.xml CustomerProfile.xml CustomerToCustomerRelationship.xml Customer_WatchListStage2EffectiveRisk.xml Customer_WatchListStage2ListRisk.xml DailyAggregateStage.xml DataMap.xsd DerivedAddressListMembership_WatchListStage2Insert.xml DerivedAddresstoInternalAccount_LinkStage.xml DerivedAddress_FrontOfficeTransactioPartyStageInsert.xml DerivedAddress_FrontOfficeTransactioPartyStageUpd.xml DerivedAddress_InsuranceTransactionInsert.xml DerivedAddress_SettlementInstructionInsert.xml DerivedAddress_WatchListNewCountries.xml DerivedEntityLink_LinkStage.xml DerivedEntityListMembership_WatchListStage2Insert.xml DerivedEntitytoDerivedAddress_LinkStage.xml DerivedEntitytoInternalAccount_LinkStage.xml DerivedEntity_FrontOfficeTransactionPartyInsert.xml DerivedEntity_InsuranceTransactionInsert.xml DerivedEntity_SettlementInstructionInsert.xml Employee.xml EmployeeControlledAccount.xml FinancialInstitution_AIIMSPopulation.xml FinancialInstitution_AnticipatoryProfile.xml FinancialInstitution_FOTPSPopulation.xml FinancialInstitution_InsuranceTransaction.xml FinancialInstitution_SettlementInstruction.xml FinancialInstitution_ThomsonDataInstitutionInsert.xml FrontOfficeTransaction.xml FrontOfficeTransactionParty.xml FrontOfficeTransactionPartyRiskStage_EntityActivityRiskInsert.xml FrontOfficeTransactionParty_HoldingInstnSeqID.xml FrontOfficeTransactionParty_SecondaryNames.xml FrontOfficeTransaction_UnrelatedPartyUpd.xml HouseholdBalance.xml InstitutionalAccountDailyProfile_CorpAction.xml InstitutionalAccountDailyProfile_DEAL.xml InstitutionalAccountDailyProfile_INST.xml InstitutionalAccountDailyProfile_Trade.xml InstitutionalAccountProfile.xml InsurancePolicyDailyProfile_InsTrxnInsPolicyBal.xml InsurancePolicyProfile_InsurancePolicyDailyProfile.xml InterestedPartyToEmployee.xml InvestmentAdvisorProfile.xml InvestmentAdvisor_MangdAcctUpd.xml LinkStaging_FrontOfficeTransactionParty.xml LinkStaging_InstructionDerivedEntDerivedAdd.xml LinkStaging_InsTrxnDerivedEntDerivedAdd.xml LoanProfile_LoanProfileStage.xml ManagedAccountDailyProfile_BOT.xml ManagedAccountDailyProfile_SameDayTrade.xml ManagedAccountDailyProfile_Trade.xml ManagedAccountProfile.xml MonetaryInstrumentTransaction_FrontOfficeTransaction.xml MonetaryInstrumentTransaction_FrontOfficeTransactionRevAdj.xml MonetaryInstrumentTransaction_TrustedFlagsUpd.xml NameMatchStaging.xml OffsettingAccountPairStage.xml OutsideBusinessActivity.xml PortfolioManagerPosition.xml PreviousWatchList_WatchList.xml PrivateSecurityTransaction.xml ReferenceTableDetail.xml RegisteredRepresentativeProfile.xml RegOToBorrower.xml Security_CIRRatingUpd.xml ServiceTeam_SprvsncdUpd.xml TradeDailyTotalCountStage.xml TrustedPairMember_StatusRRCInsert.xml TrustedPair_StatusRRCInsert.xml UncoveredOptionExposureDaily.xml WatchList.xml WatchListAudit_StatusUpd.xml WatchListEntry.xml WatchListEntryAudit_WatchListEntryUpdate.xml WatchListEntry_WatchListAuditUpd.xml WatchListEntry_WatchListEntryCurrDayInsert.xml WatchListStagingTable2_AcctListMembershipUpd.xml WatchListStagingTable2_CBListMembershipUpd.xml WatchListStagingTable2_CustListMembershipUpd.xml WatchListStagingTable2_DAListMembershipStatusUpd.xml WatchListStagingTable2_DAListMembershipUpd.xml WatchListStagingTable2_EEListMembershipStatusUpd.xml WatchListStagingTable2_EEListMembershipUpd.xml WatchListStagingTable2_WatchListStage.xml WatchListStagingTable2_WatchListStage2AcctExistence.xml WatchListStagingTable2_WatchListStage2CBExistence.xml WatchListStagingTable2_WatchListStage2CustExistence.xml WatchListStagingTable2_WatchListStage2DAExistence.xml WatchListStagingTable2_WatchListStage2EEExistence.xml WatchListStagingTable2_WatchListStage2IntrlIdUpd.xml WatchListStagingTable2_WatchListStage2SeqIdUpd.xml WatchListStagingTable_NameMatchStageInsert.xml WatchListStagingTable_WatchListInstnIDUpd.xml WatchList_WatchListSourceAuditUpd.xml WatchList_WatchListSourceUpd.xml WireTransactionInstitutionLeg_FrontOfficeTransaction.xml WireTransaction_FrontOfficeTransaction.xml WireTransaction_FrontOfficeTransactionRevAdj.xml WireTransaction_TrustedFlagsUpd.xml WLMProcessingLock.xml AccountEffectiveRisk.sql AdjustedMarginBalanceBase.sql AdjustedMarginBalanceReporting.sql DisplayName.sql MinorityProtectedClassCode.sql CustomerEffectiveRisk.sql DisplayName.sql DisplayName.sql EntityIdentifier1Text.sql EntityIdentifier2Text.sql EntityIdentifier3Text.sql EntityIdentifier4Text.sql BDF.xml.template Account.STG_ANNUITY_CONTRACTS.sql Account.STG_BILLS_CONTRACTS.sql Account.STG_BORROWINGS.sql Account.STG_CARDS.sql Account.STG_CASA.sql Account.STG_CORRESPONDENT_ACCOUNT.sql Account.STG_FUTURES.sql Account.STG_FX_CONTRACTS.sql Account.STG_GUARANTEES.sql Account.STG_INVESTMENTS.sql Account.STG_LC_CONTRACTS.sql Account.STG_LEASES_CONTRACTS.sql Account.STG_LOAN_CONTRACTS.sql Account.STG_MERCHANT_CARDS.sql Account.STG_MM_CONTRACTS.sql Account.STG_MUTUAL_FUNDS.sql Account.STG_OD_ACCOUNTS.sql Account.STG_OPTION_CONTRACTS.sql Account.STG_REPO_CONTRACTS.sql Account.STG_RETIREMENT_ACCOUNTS.sql Account.STG_SWAPS_CONTRACTS.sql Account.STG_TD_CONTRACTS.sql Account.STG_TRADING_ACCOUNT.sql Account.STG_TRUSTS.sql AccountBalance.STG_TRADING_ACCOUNT.sql AccountGroup.sql BackOfficeTransaction.STG_ANNUITY_TXNS.sql BackOfficeTransaction.STG_BORROWINGS_TXNS.sql BackOfficeTransaction.STG_CARDS_PAYMENT_TXNS.sql BackOfficeTransaction.STG_CARDS_SETTLEMENT_TXNS.sql BackOfficeTransaction.STG_CASA_TXNS.sql BackOfficeTransaction.STG_CUSTODIAN_ACCOUNT_TXNS.sql BackOfficeTransaction.STG_FOREX_TXNS.sql BackOfficeTransaction.STG_INTERBANK_TXNS.sql BackOfficeTransaction.STG_INVESTMENT_TXNS.sql BackOfficeTransaction.STG_LEASES_TXNS.sql BackOfficeTransaction.STG_LOAN_CONTRACT_TXNS.sql BackOfficeTransaction.STG_MERCHANT_CARDS_TXNS.sql BackOfficeTransaction.STG_OD_ACCOUNTS_TXNS.sql BackOfficeTransaction.STG_OTHER_SERVICES_TXNS.sql BackOfficeTransaction.STG_RETIREMENT_ACCOUNTS_TXNS.sql BackOfficeTransaction.STG_SWAP_ACCOUNT_TXNS.sql BackOfficeTransaction.STG_TERMDEPOSITS_TXNS.sql BackOfficeTransaction.STG_TRADING_ACCOUNT_TXNS.sql BackOfficeTransaction.STG_TRUSTS_TXNS.sql FrontOfficeTransaction.STG_ANNUITY_TXNS.sql FrontOfficeTransaction.STG_BORROWINGS_TXNS.sql FrontOfficeTransaction.STG_CARDS_PAYMENT_TXNS.sql FrontOfficeTransaction.STG_CARDS_SETTLEMENT_TXNS.sql FrontOfficeTransaction.STG_CASA_TRXN.sql FrontOfficeTransaction.STG_CUSTODIAN_ACCOUNT_TXNS.sql FrontOfficeTransaction.STG_FOREX_TXNS.sql FrontOfficeTransaction.STG_INTERBANK_TXNS.sql FrontOfficeTransaction.STG_INVESTMENT_TXNS.sql FrontOfficeTransaction.STG_LEASES_TXNS.sql FrontOfficeTransaction.STG_LOAN_CONTRACT_TXNS.sql FrontOfficeTransaction.STG_MERCHANT_CARDS_TXNS.sql FrontOfficeTransaction.STG_OD_ACCOUNTS_TXNS.sql FrontOfficeTransaction.STG_OTHER_SERVICES_TXNS.sql FrontOfficeTransaction.STG_RETIREMENT_ACCOUNTS_TXNS.sql FrontOfficeTransaction.STG_SWAP_ACCOUNT_TXNS.sql FrontOfficeTransaction.STG_TERMDEPOSITS_TXNS.sql FrontOfficeTransaction.STG_TRADING_ACCOUNT_TXNS.sql FrontOfficeTransaction.STG_TRUSTS_TXNS.sql fuzzy_match.aix fuzzy_match.linux64 fuzzy_match.sh.aix fuzzy_match.sh.linux64 fuzzy_match.sh.solaris10 fuzzy_match.solaris10 fuzzy_match_runner.aix fuzzy_match_runner.linux64 fuzzy_match_runner.solaris10 callbacks.so.aix callbacks.so.linux64 callbacks.so.solaris10 libalert_correlation.so.aix libalert_correlation.so.linux64 libalert_correlation.so.solaris10 libalert_creator.so.aix libalert_creator.so.linux64 libalert_creator.so.solaris10 libalert_scoring.so.aix libalert_scoring.so.linux64 libalert_scoring.so.solaris10 libapr-1.so.0.solaris10 libaprutil-1.so.0.solaris10 libauto_close_alerts.so.aix libauto_close_alerts.so.linux64 libauto_close_alerts.so.solaris10 libDatabase.so.aix libDatabase.so.linux64 libDatabase.so.solaris10 libdb_access.so.aix libdb_access.so.linux64 libdb_access.so.solaris10 libexpressions.so.aix libexpressions.so.linux64 libexpressions.so.solaris10 libfnm.so.aix libfnm.so.linux64 libfnm.so.solaris10 libI18N.so.aix libI18N.so.linux64 libI18N.so.solaris10 libiconv.so.2.solaris10 libjavafnm.so.aix libjavafnm.so.linux64 libjavafnm.so.solaris10 libkdd.so.aix libkdd.so.linux64 libkdd.so.solaris10 liblink_analysis.so.aix liblink_analysis.so.linux64 liblink_analysis.so.solaris10 libmantasxml.so.aix libmantasxml.so.linux64 libmantasxml.so.solaris10 libmatch_augmentation.so.aix libmatch_augmentation.so.linux64 libmatch_augmentation.so.solaris10 libmatch_scoring.so.aix libmatch_scoring.so.linux64 libmatch_scoring.so.solaris10 libquery_def.so.aix libquery_def.so.linux64 libquery_def.so.solaris10 librule_matcher.so.aix librule_matcher.so.linux64 librule_matcher.so.solaris10 libseqmatcher.so.aix libseqmatcher.so.linux64 libseqmatcher.so.solaris10 libservices.so.aix libservices.so.linux64 libservices.so.solaris10 libservices_exec.so.aix libservices_exec.so.linux64 libservices_exec.so.solaris10 libservices_ora11.so.aix libservices_ora11.so.linux64 libservices_ora11.so.solaris10 libutils.so.aix libutils.so.linux64 libutils.so.solaris10 install.cfg.fuzzy.aix install.cfg.fuzzy.linux64 install.cfg.fuzzy.solaris10 actionframework.jar common.jar datamap.jar clone.aix clone.linux64 clone.solaris10 dispatch.aix dispatch.linux64 dispatch.solaris10 jobRecover.aix jobRecover.linux64 jobRecover.solaris10 jobReset.aix jobReset.linux64 jobReset.solaris10 jobStatus.aix jobStatus.linux64 jobStatus.solaris10 mantas.aix mantas.linux64 mantas.solaris10 callbacks.so.aix callbacks.so.linux64 callbacks.so.solaris10 kddcore.jar libalert_correlation.so.aix libalert_correlation.so.linux64 libalert_correlation.so.solaris10 libalert_creator.so.aix libalert_creator.so.linux64 libalert_creator.so.solaris10 libalert_scoring.so.aix libalert_scoring.so.linux64 libalert_scoring.so.solaris10 libapr-1.so.0.solaris10 libaprutil-1.so.0.solaris10 libauto_close_alerts.so.aix libauto_close_alerts.so.linux64 libauto_close_alerts.so.solaris10 libDatabase.so.aix libDatabase.so.linux64 libDatabase.so.solaris10 libdb_access.so.aix libdb_access.so.linux64 libdb_access.so.solaris10 libexpressions.so.aix libexpressions.so.linux64 libexpressions.so.solaris10 libfnm.so.aix libfnm.so.linux64 libfnm.so.solaris10 libI18N.so.aix libI18N.so.linux64 libI18N.so.solaris10 libiconv.so.2.solaris10 libjavafnm.so.aix libjavafnm.so.linux64 libjavafnm.so.solaris10 libkdd.so.aix libkdd.so.linux64 libkdd.so.solaris10 liblink_analysis.so.aix liblink_analysis.so.linux64 liblink_analysis.so.solaris10 libmantasxml.so.aix libmantasxml.so.linux64 libmantasxml.so.solaris10 libmatch_augmentation.so.aix libmatch_augmentation.so.linux64 libmatch_augmentation.so.solaris10 libmatch_scoring.so.aix libmatch_scoring.so.linux64 libmatch_scoring.so.solaris10 libquery_def.so.aix libquery_def.so.linux64 libquery_def.so.solaris10 librule_matcher.so.aix librule_matcher.so.linux64 librule_matcher.so.solaris10 libseqmatcher.so.aix libseqmatcher.so.linux64 libseqmatcher.so.solaris10 libservices.so.aix libservices.so.linux64 libservices.so.solaris10 libservices_exec.so.aix libservices_exec.so.linux64 libservices_exec.so.solaris10 libservices_ora11.so.aix libservices_ora11.so.linux64 libservices_ora11.so.solaris10 libutils.so.aix libutils.so.linux64 libutils.so.solaris10 start_mantas.sh.aix start_mantas.sh.linux64 start_mantas.sh.solaris10 CR_6.2.2_16674068.business.sql CR_6.2.2_17317911.business.sql CR_6.2.2_17483874.business.sql CR_6.2.2_pta.business.sql CR_6.2.2_pta.ingest.sql CR_6.2.3_14550170.business.sql CR_6.2.3_16223685.business.sql CR_6.2.3_17441546.business.sql CR_6.2.3_17441546.ingest.sql CR_6.2.3_18146704.business.sql CR_6.2.3_18387933.system.sql CR_6.2.3_18548100.mantas.sql CR_6.2.3_18557209.business.sql delta_plat6.2.3.cfg FR_NetAcEnCu_NT_JRNL_setup.sql FR_NetAcEnCu_NT_WIREACORIG_setup.sql FR_NetAcEnCu_NT_WIRETRXN_setup.sql IML_HidRel_NT_Inst_setup.sql IML_HidRel_NT_Jrnl_setup.sql IML_HidRel_NT_WireAcBene_setup.sql IML_HidRel_NT_WireAcOrig_setup.sql ML_NetAcEnCu_NT_ACCTADDR_setup.sql ML_NetAcEnCu_NT_ACCTPHONE_setup.sql ML_NetAcEnCu_NT_CUACADDR_setup.sql ML_NetAcEnCu_NT_JRNL_setup.sql ML_NetAcEnCu_NT_WIREACORIG_setup.sql ML_NetAcEnCu_NT_WIRETRXN_setup.sql plat6.2.1_b01.16950586.business.sql plat6.2.1_b01.17303594.business.sql plat6.2.1_b01.17303594.ingest.sql plat6.2.1_b01.17303594.system.sql plat6.2.1_b01.17320355.business.sql PR_16778855.miner.sql PR_6.2.2_17080868.miner.sql PR_6.2.2_17528469.miner.sql PR_6.2.3_17180946.miner.sql PR_6.2.3_18247495.miner.sql PR_6.2.3_18674359.business.sql PR_6.2.3_18674359_2.business.sql rebuild_bus_views.business.sql rebuild_obiee_views.report.sql rebuild_rpt_views.report.sql rebuild_sav_tables.business.sql run_pta_emp_quest_map.sh run_pta_set_rqst_expired.sh run_update_exna_drvd_acct.sh dbtools.jar kddcore.jar mantas_database_message_lib_en.dat HDC_DataBags.xml KeysByTableName.xml CR_6.2.2_17483874.case.sql CR_6.2.2_metadata.mantas.sql CR_6.2.2_pta.mantas.sql CR_6.2.3_14324861.mantas.sql CR_6.2.3_14550170.case.sql CR_6.2.3_18037593.case.sql CR_6.2.3_18050281.case.sql CR_6.2.3_18050281.mantas.sql CR_6.2.3_18146704.case.sql CR_6.2.3_18422702.mantas.sql CR_6.2.3_18422702.system.sql CR_6.2.3_18533579.case.sql CR_6.2.3_fatca.mantas.sql CR_6.2.3_metadata.mantas.sql delta_mts6.2.1_metadata_b01.sql delta_mts6.2.1_metadata_b02.sql mantas6.2.3_delta.cfg pfm6.2.1_b01.16904495.mantas.sql pfm6.2.1_b01.16904495.system.sql pfm6.2.1_b01.16983078.mantas.sql pfm6.2.1_b01.17072461.mantas.sql pfm6.2.1_b01.17239988.mantas.sql pfm6.2.1_b01.17320355.mantas.sql pfm6.2.1_b01.17401685.system.sql PR_16969637.case.sql PR_6.2.2_17339364.case.sql PR_6.2.3_18674359.mantas.sql PR_6.2.3_18791340.mantas.sql DataIngest.xml Account.xml AccountBalance.xml AccountGroup.xml AccountPosition.xml BackOfficeTransaction.xml Country.xml Customer.xml CustomerIdentificationDocument.xml CustomerToCustomerRelationship.xml DerivedTrade.xml EmployeeEmailAddress.xml EmployeeTradingRestriction.xml Execution.xml ExternalInvestmentAccountToAccount.xml FrontOfficeTransaction.xml InvestmentAdvisor.xml OrderSummary.xml Security.xml SecurityInvestmentRating.xml ServiceTeam.xml Trade.xml TradeExecution.xml fuzzy_match.aix fuzzy_match.linux64 fuzzy_match.sh.aix fuzzy_match.sh.linux64 fuzzy_match.sh.solaris10 fuzzy_match.solaris10 fuzzy_match_runner.aix fuzzy_match_runner.linux64 fuzzy_match_runner.solaris10 callbacks.so.aix callbacks.so.linux64 callbacks.so.solaris10 libalert_correlation.so.aix libalert_correlation.so.linux64 libalert_correlation.so.solaris10 libalert_creator.so.aix libalert_creator.so.linux64 libalert_creator.so.solaris10 libalert_scoring.so.aix libalert_scoring.so.linux64 libalert_scoring.so.solaris10 libapr-1.so.0.solaris10 libaprutil-1.so.0.solaris10 libauto_close_alerts.so.aix libauto_close_alerts.so.linux64 libauto_close_alerts.so.solaris10 libDatabase.so.aix libDatabase.so.linux64 libDatabase.so.solaris10 libdb_access.so.aix libdb_access.so.linux64 libdb_access.so.solaris10 libexpressions.so.aix libexpressions.so.linux64 libexpressions.so.solaris10 libfnm.so.aix libfnm.so.linux64 libfnm.so.solaris10 libI18N.so.aix libI18N.so.linux64 libI18N.so.solaris10 libiconv.so.2.solaris10 libjavafnm.so.aix libjavafnm.so.linux64 libjavafnm.so.solaris10 libkdd.so.aix libkdd.so.linux64 libkdd.so.solaris10 liblink_analysis.so.aix liblink_analysis.so.linux64 liblink_analysis.so.solaris10 libmantasxml.so.aix libmantasxml.so.linux64 libmantasxml.so.solaris10 libmatch_augmentation.so.aix libmatch_augmentation.so.linux64 libmatch_augmentation.so.solaris10 libmatch_scoring.so.aix libmatch_scoring.so.linux64 libmatch_scoring.so.solaris10 libquery_def.so.aix libquery_def.so.linux64 libquery_def.so.solaris10 librule_matcher.so.aix librule_matcher.so.linux64 librule_matcher.so.solaris10 libseqmatcher.so.aix libseqmatcher.so.linux64 libseqmatcher.so.solaris10 libservices.so.aix libservices.so.linux64 libservices.so.solaris10 libservices_exec.so.aix libservices_exec.so.linux64 libservices_exec.so.solaris10 libservices_ora11.so.aix libservices_ora11.so.linux64 libservices_ora11.so.solaris10 libutils.so.aix libutils.so.linux64 libutils.so.solaris10 dbutility.jar firmdatatransformer.jar kddcore.jar preprocessor.jar watchlist.jar callbacks.so.aix callbacks.so.linux64 callbacks.so.solaris10 kddcore.jar libalert_correlation.so.aix libalert_correlation.so.linux64 libalert_correlation.so.solaris10 libalert_creator.so.aix libalert_creator.so.linux64 libalert_creator.so.solaris10 libalert_scoring.so.aix libalert_scoring.so.linux64 libalert_scoring.so.solaris10 libapr-1.so.0.solaris10 libaprutil-1.so.0.solaris10 libauto_close_alerts.so.aix libauto_close_alerts.so.linux64 libauto_close_alerts.so.solaris10 libDatabase.so.aix libDatabase.so.linux64 libDatabase.so.solaris10 libdb_access.so.aix libdb_access.so.linux64 libdb_access.so.solaris10 libexpressions.so.aix libexpressions.so.linux64 libexpressions.so.solaris10 libfnm.so.aix libfnm.so.linux64 libfnm.so.solaris10 libI18N.so.aix libI18N.so.linux64 libI18N.so.solaris10 libiconv.so.2.solaris10 libjavafnm.so.aix libjavafnm.so.linux64 libjavafnm.so.solaris10 libkdd.so.aix libkdd.so.linux64 libkdd.so.solaris10 liblink_analysis.so.aix liblink_analysis.so.linux64 liblink_analysis.so.solaris10 libmantasxml.so.aix libmantasxml.so.linux64 libmantasxml.so.solaris10 libmatch_augmentation.so.aix libmatch_augmentation.so.linux64 libmatch_augmentation.so.solaris10 libmatch_scoring.so.aix libmatch_scoring.so.linux64 libmatch_scoring.so.solaris10 libquery_def.so.aix libquery_def.so.linux64 libquery_def.so.solaris10 librule_matcher.so.aix librule_matcher.so.linux64 librule_matcher.so.solaris10 libseqmatcher.so.aix libseqmatcher.so.linux64 libseqmatcher.so.solaris10 libservices.so.aix libservices.so.linux64 libservices.so.solaris10 libservices_exec.so.aix libservices_exec.so.linux64 libservices_exec.so.solaris10 libservices_ora11.so.aix libservices_ora11.so.linux64 libservices_ora11.so.solaris10 libutils.so.aix libutils.so.linux64 libutils.so.solaris10 actionframework.jar alertmgmt.jar common.jar kddcore.jar ================================================================================================================================================================================================================================================================================================================================================== (c) 2014 by Oracle Financial Services Software, Inc. All rights reserved. No part of this publication may be reproduced, stored in a retrieval system, or transmitted in any form or by any means, electronic, mechanical, photocopying, recording, or otherwise without the prior written permission of Oracle Financial Services Software, Inc.
